How to Make a Simple Electric Guitar
This is a step by step instruction of how to make an one-string simple electric guitar.
This was originally experimented by Paul in the museum's Curiosity Lab .
Children should work with a responsible adult helping your with your project!
What you need:
    (1) 1x2 White Pine lumber approx. 12" in length
    24 AWG magnet wire
    Winding Jig (Instructable coming soon)
    Epoxy
    220 Grit sand paper
    (1) Neodymium magnet 1/4" x 1/4" cylinder
    (1) Jumbo craft stick
    (1) #12 Screw eye
    Security cable 22 AWG strand
    (1) 3.5mm (1/8") Mono plug
    Steel wire
    Wire strippers
    Screwdriver
    Guitar pick
(Other tools + materials not shown in the image)
    Medium binder clip
    Soldering iron
    Solder
    Scissors
    Hot glue gun
Step 1: Glueing Magnet Sandwich
1. Roughen up both sides of your neodymium magnet by scraping on your sand paper.
2. Cut your jumbo craft stick to make two 1" x 1" square pieces.
3. Epoxy the magnet to your craft stick piece.
*Please read hazards + instructions for using epoxy.
4. Epoxy both sides of magnet to create magnet craft stick sandwich.
Step 2: Winding Magnet Sandwich
1. Slap magnet craft stick sandwich on the disk of winding jig.
2. Send copper wire through eye of needle.
3. Tape copper wire to the spinning disc.
4. Wind the copper wire around the magnet.
*100+ windings is recommended. Try and see what works best for yourself!
5. Cut the wire from the spool with a few inches of wire unwound from magnet.
6. Scrape enamel coating off of magnet wire about 1" from the end of wire.
Your magnet sandwich should now have a copper winding with two ends of wire dangling out and both ends exposed.
Step 3: Preparing the Plug
1. Solder the security cable to the 3.5mm plug.
Your cable should look like the second picture below.
Step 4: Building Guitar
1. Pre-drill a pilot hole in your guitar body (white pine) and screw in your screw.
2. Cut your steel wire approx. 8" longer than your guitar body.
3. Wrap the steel wire around your screw head.
4. Place your medium binder clip under your steel wire.
5. Wrap your wire around the side of the loop to your #12 screw eye.
6. Pre-drill a 1/16" pilot hole and screw your #12 screw eye into your guitar body. Use the screw eye to "tune" your string.
*Don't over tighten your string.
This is your single string guitar! It should closely resemble the last image shown below.
Step 5: Attaching Pickup to Guitar
1. Attach the exposed wires of your magnet sandwich to your security cable with 3.5mm plug.
2. Hot glue your pickup (magnet sandwich) to the guitar.
3. Staple the security cable to the guitar body.
Step 6: Playing the Guitar
1. Plug your electric guitar into the microphone jack of your computer.
2. Open Audacity or sound recorder and play your guitar!
That's it! Have fun jamming on your electric guitar.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    34 Discussions
    Ortzinator
    6 years ago on Introduction
    Where'd you get your giant scissors? I have some too. Mine were used in a tire factory to cut sheets of rubber.
    aemj
    Has anyone tried to link this up into a circuit with a light bulb? I'm hoping to show that electric guitars generate electricity and thought it would be visual way to do this. I dont know whether enough electricity is generated to do this though? Any thoughts or adivce woudl be great!
    n0ukf
    8 years ago on Introduction
    I have found that at least some sound cards need you to use a three terminal (stereo) plug into the mic input, otherwise the barrel will short out the ring connection to shield and you'll get no sound.
    I also found when plugging a regular electric guitar into the computer's mic-in that the volume and/or tone controls would be noisy. I traced this problem to the DC put out the mic jack for powering the condenser mics. This could also potentially cause trouble (burn out the voice coil, or just alter the frequency response) for dynamic mics plugged in unless you add a DC-blocking capacitor in-line.
    frikkie
    8 years ago on Step 6
    Sounds cool.how about a video so we can hear what it sounds like?
    gbryanmiller
    This instrument is also known as a Diddley Bow. http://en.wikipedia.org/wiki/Diddley_bo
    Hi pquin3. That's a good question. I have only seen the pick-up not work with less than 100 windings, though I recommend that you try different numbers and see what works best.
    Khord
    Good work, reminds me of Jack White's introduction in the documentary "It Might Get Loud" http://www.youtube.com/watch?v=xCFXeChXfcI
    landru
    8 years ago on Step 2
    you've written "scrapping" and "scrap" where i think u want "scraping" and "scrape" ... in case u care
    fretted
    Love the Winder Could ahve saved 350 bucks if i would have just built my own great ible great for someone who wants to understand the basics of how a guitar works ....
    Great Job
    spark masterfretted
    lindseys publications used to have a booklet on how to build a coil winder (think tube/ham radio needs). But the scale is whatever you like. I would want as fine a wire as I could get to make the coil more sensitive. (you can get more turns on the core)
    mental man
    HOWDY hey ya gotta look up Diddley BOW on you tube and it will show you how to make what may be the oldest type of instrument in the world which is a one string guitar.
    landru
    have you experimented with different amounts of winding on the pickup? the i'ble doesn't give me a clear indication of whether the wire is wound around the pickup for two complete loops or 20 (or whatever)... but it is a great instructable!
    also, is there a magnet field strong enough to be concerned about proximity between the instrument & a laptop's hard disk, e.g.?
    duct tape
    Could you share a recording of it? I just want to hear what it sounds like before deciding to build it.
