How to Make a Torch for Less Than a Dollar
244,947
214
144
With only a few "household items" you can make a torch that's relatively safe* that can last for up to an hour.
with the end of the world coming you might just need a steady source of light and heat.
*I am not responsible for anything you do with the information provided in this guide ... not that you couldn't figure this out on your own or anything ;)
Supplies:
Step 1: Supplies
For this project you will need an piece of 100% cotton cloth* (I used an old under shirt) a sturdy stick or a scrap piece of wood a stapler a hammer and tiki  torch oil or kerosene
*Has to be 100% cotton (or Kevlar ) materials such as cotton blend/polyester/rayon ect will melt when heated up and cause huge problems  (think melted plastic 1-3 degree burns ! )
Step 2: Wrapping the Torch
the first thing you want to do is get a rag that's about twelve inches wide and roughly twenty four inches long
Now fold it width wise until its about seven inches wide, and staple one end to the stick with a few staples
*You can use wire or wire mesh to affix the cloth instead of staples ( I used staples cause I had them and it took the least time to use) Do not use zip ties unless they are metal core. (the wire mesh will also help keep the ash together when the wick starts charring.)
Step 3: Tightly Wraping Torch
You want to make sure you wrap the rag tightly around the torch so when it burns the rag doesn't fall off . to keep the rag taught put staples every two inches or so as you wrap. also try to tuck in the "frills" it will burn longer.
the tighter you wrap the wick the better it will hold up during burn time.
Step 4: Soaking the Torch
You want to soak the torch in the tiki® torch oil or kerosene about ten minutes or more before use to make sure all of the fabric is covered with the fuel.
any dry portions of the fabric will result in charring and early failure due to burning of the wick material.
Step 5: Lighting the Torch
The torch can be lit many ways including sparks or embers
*pro tip !   light from the tip of the torch and let the flames do the work by tilting the torch.
Step 6: Now Go Crazy , Not Too Crazy
The torch can now be used for most any of your lighting and heat needs !
it's a great tool for lighting stubborn bonfires.
Be very careful using in enclosed spaces as an open flame can not only pose a fire hazard but also puts you at risk for carbon monoxide poisoning and even death .
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    144 Discussions
    wolfgang64
    6 years ago on Introduction
    An old farm trick. If you use cotton fabric, pork or beef fat (poultry fat burns too fast) use a hardwood stick and wrap it in iron bailing wire you have a much better torch. Dip the top quarter in the fat and light. and you have a solution that goes back to the middle ages. It will burn for hours. with no petro chemicals.
    imanwolfgang64
    Reply 6 years ago on Introduction
    That is a great idea thanks for the tip ! and that would be another way to find fuel in case of the apocalypse haha
    arynn mckenzie
    6 years ago on Step 6
    I have been looking for an economical torch for my brides maids to carry. This is probably the one. How quickly does it go up? Is there a way to make is makes it flare up quickly?
    imanarynn mckenzie
    sorry for the late reply , you can light them easily by putting them straight in a fire or with a blow torch.
    ARVash
    12 years ago
    Could be useful for when the power goes out and zombies attack :D
    just as long as the brain is destroyed-- shoving a crowbar through the eyesocket and using a swirling motion will suffice. haha, there should be a list of "zombie prevention" instructables.
    why would you prefer a crowbar? yes, its good in survival situations, but if a zombie running is at you, I think your knee-jerk response would be to keep it as far away as possible. So the best thing would be to use a semi-auto rifle of some sort strong enough to pierce the skull to the brain, like a M1- Gerund or the Henry .44. wow, A zombie-education rant. Doesn't happen on this site too often, does it?
    Tayl90mmrocksalt2342
    as i stated earlier, guns are nice but they require ammunition. if you read "the zombie survival guide" by max brooks you will be very well prepared.
    rocksalt2342Tayl90mm
    so, a gun isn't better or worse then a club, or vice-versa, it's all in the situation really. If you're being attacked by a horde of zombies, like 20 or more, then you don't want to go charging with your crowbar. you'll just get surrounded. but if it's a small group, or individuals, then hack them away. shooting them will waste ammo. unless if it's a really big zombie.
    toogersrocksalt2342
    the best would be a crossbow with a string tied to the arrow, and the other end to the crossbow. no need for extra ammo, yet it's effective from a range.
    datgnattoogers
    Various weapons fill various needs. I need clothing made out of lots of different weapons--ouch; they're sharp and scrapy and hot--best to wear my bacon underwear beneath!
