How to Make a Wooden Toy Winchester Rifle
90,732
220
29
This is as requested a DIY on, how to make a wooden toy Winchester rifle with a functioning lever action. NOTE: The lever is designed a bit different, than the real ting, for stability reason.
Supplies:
Step 1: The Principle Drawings
First I drew up the different layers in illustrator based on a real picture. Notice, that the trigger is included in the lever - that is done for stability reason...
Step 2: Preparing the Pieces
After printout in 1:1, I drew up the different templates on the 5 mm, 15 mm and 3 mm plywood according to the plan. I cut the pieces out with at electrical jigsaw.
Step 3: Assembling
You assemble the 1 layer to the stock but not the lever. (2. layer) with glue and maybe a couple of screws for the non-moving parts. Important. If you use screws, place them close to the middle so that you will still be able to rasp the stock into a nice round shape without hitting the screws...
The thickness of the lever has to be reduced just a little with sanding paper, so it will move smoothly. Then you attach some screws or otherwise carve two hooks to attach the rubber band to.
Drill a 6 mm hole in the turning center of the lever, then attach it to the stock/1-layer piece with a screw. You do it from the outside and the screw must be long enough to pass through the entire thickness of the rifle. (I actually sanded the screw down to mach the thickness)...
Step 4: Paint It
Well after rasping and final sanding, you are set to paint the gun. Important. Don't paint the moving parts. They might get stuck! You can use a black speed marker to draw some accenting lines to enhance or "make up" details if you like...
Just a layer of varnish and you are ready to make a little boy or girl the proud owner of a western rifle... Have fun.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    29 Discussions
    Pazzerz
    2 years ago
    You can scale the drawings on here with one of two programs: The Big Picture, which is free, or buy Matthias Wandel's Big Print, which is a much better program that allows you to take a measurement from a real item and use that to make a 1:1 (or any size) template from your silhouette drawings. It will allow you to print on several pages, if need be to get the complete drawing.
    monkeywork
    2 years ago
    I made this for a show I'm in! Great design. Made a couple 'hero' versions and several dummy versions for set pieces.
    https://www.instructables.com/id/Lever-Action-Rifle-Prop/
    Zenoscope
    2 years ago
    I made a cardboard version of this, and will make some wooden ones sometime. thanks for the 'ible and the idea if tracing gun shapes.
    inspiredwoodZenoscope
    Reply 2 years ago
    Cool. I would be happy if you'd share a picture or two :-)
    PeterW33
    3 years ago
    schade das kein Plan zum ausdrucken dabei ist!
    inspiredwoodPeterW33
    Reply 3 years ago
    Na, ja... aber die Zeichnungen sin massstabsgetreu abgebildet. Du musst sie nur in der gewünschten Grösse ausdrukken, dann gehts los :-)
    JoeDiCara
    4 years ago on Introduction
    Great design and plan. Do the PDF download include dimensions for overall rifle and each part? I'm wondering about signing up. Is the a way to buy just this one plan instead of signing up as Pro?
    inspiredwoodJoeDiCara
    Reply 4 years ago on Introduction
    Hi! My instructable doesn't include dimensions – it's ment as a generic idea :-) – to show what's possible – sorry :-) But if you print out the picture really big you should be able to trace your own blueprint on paper.
    If you cut out the paper parts, you should be able to check if everyting will work, once it's done i wood. – Hope that helped :-)
    JoeDiCarainspiredwood
    ok. If you don't mind telling, what's the overall length of the rifle you made? Or length of the "barrel" past wood part just to give a sense of length? Thanks.
    The barrel is about 35 cm. I scaled it to fit a 10 year old. If it's for an adult, you might make it a bit longer - say 40-45 cm...
    dr.who4
    4 years ago
    That's cool, I'm going to use that design and make the rosebox shotgun from terminator.
    inspiredwooddr.who4
    Reply 4 years ago
    Awesome! Please do post a picture when your are done :-)
    inspiredwoodWatboys04
    Reply 6 years ago on Introduction
    In this model, the rubber band is purely used to retract the lever back into the idle position, but you are on to a nice idea for version two :-) ...
    LiftAndLove
    Has anyone shot one of these or a similar gun? I shot a .44 lever-action rifle, and it was probably my most favorite gun Ive shot!
    Cyclone1764
    thats cool, my friends always saying f i make him a winchestor prop he'll pay me €5, but i would charge atleast €100 for 1
