How to Make a Wort Chiller for Homebrewing
469,150
277
30
About: Just your average handyman.
In this instructable, I am going to demonstrate how I built a wort chiller for homebrewing beer.
A wort chiller is a device that cools down wort (unfermented beer) after boiling. Cooling down wort rapidly is important because it helps to reduce the chances of bacteria from growing before you pitch the yeast. Yeast needs a certain temperature to live - too hot and you will kill the yeast, too cold and it may not ferment properly. Rapidly cooling wort is also important because it will help to discourage certain off-flavors in the finished brew.
There are mainly four methods of cooling wort rapidly. Immersion chillers are put into the wort and cold water is passed through to cool the wort. Counter-flow chillers are the opposite. They pass hot wort through cold water. Immersing the hot pot of wort in an ice bath is another way. You can also pour hot wort into cold water. The goal is to cool it as quickly as possible. Home brewers using partial-mash and all grain recipes typically find that wort chillers produce the best results.
My wort chiller passes hot wort through a copper coil submerged in a cooler filled with ice water and out through a ball valve on the side. The wort will drain out into a primary fermenting bucket where I can pitch the yeast and ferment the beer.
Step 1: Installing the Ball Valve on a Cooler
The first step is to install a ball valve on the cooler. I decided not to include instructions here since I made a separate instructable demonstrating how I did it. You can find that instructable here:
https://www.instructables.com/id/Installing-a-ball-valve-on-a-Coleman-cooler/
Step 2: A Word on Safety
The golden rule of making homebrewing equipment is that you should be having a tasty homebrew while doing it! I didn't make this rule, I just follow it.
However, you should make sure to have all the materials you need on hand before beginning. You don't need to be driving a car to the hardware store for forgotten parts after following the golden rule.
Step 3: Materials
Now that the ball valve is in place on my cooler, I can begin to transform my ordinary cooler into a wort chiller.
I used:
- 18' of 3/8" soft copper tubing
- (1) 3/8" compression fitting with a 3/8" male end
- (1) 3/8" compression fitting with a 3/8" female end
- (1) 3/8" brass hose barb adapter with a 3/8" male end (not pictured here)
- teflon tape
The tools I used were:
- Two wrenches
- a 3/8" soft copper tubing bender
- a drill with a 1-1/2" hole saw
- a pipe cutter
Step 4: Bending the Copper Tubing
The goal is to coil the copper into a tube that will pass through the cold water and allow the heat from the wort to dissipate rapidly. Using many coils creates more surface area for the hot wort to touch on its path through the chiller.
I used a tubing bender to safely bend my copper without any kinks. Don't be like me and underestimate how much copper tubing you will need. I ran out and had to get more and use a coupling to continue. I wound up needing almost 18 feet. Buy the right amount the first time and you won't need to worry about it.
To keep my coils relatively equal, I used a 3 liter plastic soda bottle to check my progress.
The coil itself begins straight so it can go to the ball valve. I turned it about 90 degrees to begin the coils. I made about 9 coils and then did another 90 degree bend straight up.
It's difficult to describe just how I shaped the pipe. If this step's description doesn't make sense, continue anyway and see how it will function.
Step 5: Connecting to the Ball Valve
On the inside of the cooler will be a coupling that the copper coil will attach to. Take the 3/8" compression fitting with the male end and remove the nut and compression ring. Screw the fitting into the coupling and tighten with a wrench.
Now, connect the copper coil. Slide the nut and compression ring over the tube and re-connect it to the compression fitting. Snug with a wrench.
Step 6: Making the Wort Inlet
There should be extra tubing sticking straight up out of the cooler now. I used a pipe cutter and trimmed it so there would be about four inches sticking up.
I lowered the lid and marked where the inlet would come out of the lid. I then took a hole saw and cut a hole. The four inches of tubing should stick out of the lid a bit when closed.
Step 7: Making the Wort Inlet Cont'd
Take the 3/8" compression fitting with the female end and remove the nut and compression ring. I used a pair of clothespins to hold the tube in place and to prevent the nut and ring from sliding down into the cooler.
Tighten the nut and compression ring onto the fitting and put on the hose barb adapter.
This is where the wort will enter the chiller via clear tubing that will slide onto the barb.
Step 8: Testing the Wort Chiller for Leaks
In this video, I'm demonstrating how the wort chiller will work and checking for leaks.
Soft copper and compression fittings can be tricky sometimes. If you have a leak, make sure everything has been tightened properly. This will usually do the trick. If you notice the leak is coming from the threads of a fitting, try teflon tape on the threads. I had to go back and use a little tape on the fittings.
Step 9: Using the Wort Chiller
Now that the wort chiller is in good working order, it is time to test it out. I began boiling two gallons of water to simulate boiling wort and once it was almost there, I filled up the cooler with ice water. Since I try not to waste a lot of water, I used little frozen bottles since I can reuse them next time. Ice water temperature was 55 degrees F. I dumped the boiling water into a bucket with a plastic valve. Temperature in the bucket was 204. I opened up the plastic valve and the ball valve on the wort chiller.
When the bucket was nearly empty, I tilted it to get all the water I could out. Once it was empty, I tilted the cooler a little (don't spill the icewater!) to get as much "wort" out as possible. Final temperature of the two gallons of boiled water was 84.
This worked pretty well. I could have packed a lot more ice in there and that would have brought down the temperature of the wort to within the 60's no problem. I also liked how I could use the ball valve to kind of control the temperature of the water leaving the chiller - open wider for warmer, close it more for colder. I think this will have no problem on brewing day.
And of course, if this were real wort and not water, I'd flush out the coil during cleanup.
Step 10: Wort Chiller Maintenance and Cleaning
Before using the wort chiller on brewing day, test it out to make sure all the fittings are tight and that it is clean and ready to go.
Cleaning the inside of the coil can be done with PBW (Powdered Brewery Wash). Follow the instructions on the package. Sanitize with StarSan or the sanitizer of your choice.
If there are any leaks, you should notice it during cleaning and sanitizing. Fix before using the chiller or else you may contaminate the wort.
Step 11: Summary
That's my wort chiller. I'm really proud of the design and happy with the way it works. I think it will be very useful when I step up to partial-mash and all-grain beer techniques. Be on the lookout for my future instructable where I will show how I make my mash tun.
Cheers!
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    30 Discussions
    tt1987
    2 years ago
    i like .thank
    JamesGannon
    4 years ago on Step 4
    I was looking to buy a wort chiller when I came acroos your instructable, I am the type of person where if I can make something myself I will. I do not know very much about brewing but the wort chillers I have seen all have tighter coils (vertically), is there any drawback or improvement having your coils spaced so far apart?
    AKNeal
    5 years ago on Step 3
    What are the part numbers for the 3/8" compression fittings (male and female)? Thanks!!
    babeladyj
    6 years ago on Introduction
    WONDERFUL SYSTEM - CONSERVES WATER - ACHIEVES CONTROL OF HOW COOL THE WORT GETS - BRILLIANT EASY TO FOLLOW PICTURES & DIRECTIONS.
    THANK YOU
    newflavour
    6 years ago on Step 9
    This instructable is great. Had you thought about using a small aquarium pump to could cycle the wort until you've crashed cooled it to the temp you need. With the final drain going in to your fermentor. You could use the pump in your flush cleaning also with star san or similar.
    BeeRich
    9 years ago on Introduction
    This is basically a "counterflow" chiller.  Immersion chillers are much better for 5 gallon systems.  Here's an explanation:
    - A similar coil is constructed to run cold water through the coil which is immersed into the wort at the last part of the boil.
    - Wort is on the outside, so sterilization comes instantly when the heat shock hits the copper.  Also very easy to clean.
    - 15 minutes to cool wort
    - manual whirlpool puts hot trub into a cone, and not into your fermenter
    - Easier to make as you don't need a separate unit like an insulated cooler.
    - Cold all the way through the chilling process, and not a gradual change to warmer coolant, which reduces efficiency.  Yeast like cool wort.
    gumbytigBeeRich
    I'd have to say a true counterflow is much better for a 5 gallon than an immersion. my homebuilt counterflow can drop a 5 gallon batch from near boil to near room temp in around 5 minutes with cold tap water. I've even used rain barrel water to chill with though that took about 10 -15 minutes
    I actually started with something similar to this project but with a 5 gallon bucket instead of a cooler but made the mistake of using smaller tubing and got a thick stout almost stuck in it. So i converted it to an immersion for a while but then decided to go with a whole new counterflow chiller. I'll have to put an instructable on it up some time. It was a royal pain in the rear to make, but with some small changes to procedure, wouldn't be that bad.
    BeeRichgumbytig
    15 minutes to chill wort is a really good time. You're not going to get any more hot break out of reducing that time to 10 or 5 minutes. Could you imagine how long it takes large commercial breweries to chill wort, considering they have a 3-hour brew cycle? Even though you can chill faster, your hot break is inside your primary, and that's what you want to avoid. That's the very reason for the whirlpool in multi-batch brewhouses. The goal is to get the hot break out, not have a race with chilling times.
    Let's not forget the goal.
    gumbytigBeeRich
    Yeh but as i move up to 10 gallon batches and bigger, the counterflow will then only take 10 to 15 minutes instead of 30 or more with the immersion.
    BeeRichgumbytig
    You still miss my point. You can take 2 hours to cool something using immersion. With only slight movement of your wort, an immersion can always compete with counterflow, while taking out cold break from your primary. And hot break as well. You're chasing reducing time to chill your wort. That is only valuable in separating break from your wort. If you race through it only to include it in your primary, you've not really gained much. The quality of your product will be much better with an immersion. I've seen it for over 20 years.
    iPodGuyBeeRich
    I was doing a little research online, and I this is halfway between a counterflow chiller and a jockey box.
    BeeRichiPodGuy
    They are different tools altogether. A chiller is used in the brewhouse, and the Jockey Box is used to chill beer just before it hits the tap.
    moritzr
    7 years ago on Step 4
    If you don't have a tubing bender, try filling the copper tube with sand before bending. This will help to keep the tube from kinking.
    ParkRoadGuy
    7 years ago on Step 9
    What is the amount of time that it takes the wort to travel through the chiller? Is a good seal on the cooler really an issue? I am considering using this design as a mash tun/wort chiller, but would be apprehensive about putting a hole in the lid because of the sensitivity of the mash (avoiding any fluctuation beyond a couple of degrees).
    jsgraham
    You say that you used a 3-liter bottle as a pattern to check your progress. Why not just use the 3-liter bottle as a mandrel from the very beginning? Fill the bottle with water to make it rigid. Then while the coil is still on the bottle, you can adjust your spacing between coils to your liking.
    xmobisx
    i know your other 'ables is a beer tun, is there any way to modify the beer tun so that it works as a wort chiller too. like have an easy way to take off/put on the stailess steel mesh and replace it with the copper coil.
    iPodGuyxmobisx
    By "beer tun" I'm assuming you mean mash tun.
    I suspect that after you're finished with the mashing process, you can use a part called a "Quick Disconnect" to switch out whatever you're using as a filter and replace it with the chiller coil. Stainless QD's are often expensive.
    YMMV, I've never tried it before.
    octopornopus
    How would you compare using a rectangular cooler to a cylindrical one? It seems like the cylinder would allow the coils to stand upright and prevent any wort from remaining inside. I haven't seen any quite as large as the rectangular coolers, though, so I guess you would need more ice or add rock salt to lower the temperature?
