How to Make Air Muscles!
185,051
631
245
About: I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let me know!
I needed to create some actuators for an animatronics project I'm working on. Air muscles are very powerful actuators that work very similar to a human muscle and have a phenomenal strength to weight ratio- they can exert a pulling force up to 400 times their own weight. They will work when twisted or bent and can work under water. They're also easy and cheap to make!
Air muscles (also known as a McKibben artificial muscle or braided pneumatic actuators) were originally developed by J.L. McKibben in the 1950's as an orthotic appliance for polio patients.
Here's how they work:
The muscle consists of a rubber tube (bladder or core) that is surrounded by a tubular braided fiber mesh sleeve. When the bladder is inflated the mesh expands radially and contracts axially (since the mesh fibers are inextensible), shortening the overall length of the muscle and subsequently producing a pulling force.
Air muscles have performance characteristics very similar to human muscles- the force exerted decreases as the muscle contracts. This is due to the change in the interweave angle of the braided mesh as the muscle contracts- as the mesh expands radially in a scissors like motion it exerts less force due to the weave angle becoming increasingly shallow as the muscle contracts (see the diagram below- figure A shows that the muscle will contract to a greater degree than figure C given an equal increase in bladder pressure).The videos show this effect as well. Air muscles can contract up to 40% of their length, depending on the method and materials of their construction.
Gas law states that if you increase pressure you also increase the volume of an expandable cylinder (provided temperature is constant.) The expanding volume of the bladder is ultimately constrained by the physical properties of the braided mesh sleeve so in order to create a greater pulling force you need to be able to increase the effective volume of the bladder- the pulling force of the muscle is a function of the length and diameter of the muscle as well as its ability to contract due to the properties of the mesh sleeve (construction material, number of fibers, interweave angle) and bladder material.
I constructed two different sized muscles using similar materials to demonstrate this principle- they both were operated at the same air pressure (60psi) but had different diameters and lengths. The small muscle really starts to struggle when some weight is put on it while the larger muscle has no problems at all.
Here are a couple of videos showing both of the constructed air muscles in action.
Now let's go make some muscles!
Step 1: Materials
All of the materials are readily available on Amazon.com, with the exception of the 3/8" braided nylon mesh- it is available from electronics suppliers. Amazon does sell a braided sleeving kit with several sizes of braided mesh but the exact material is not stated-
Amazon
You'll need an air source:
I used a small air tank with a pressure regulator but you can also use a bicycle air pump (you will have to make an adapter to make it work with the 1/4" poly hose.
Air tank- Amazon
Pressure regulator (will require a 1/8" NPT female to 1/4" NPT male adapter)- Amazon
1/4" high pressure poly tubing- Amazon
multitool (screwdriver, scissors, pliers, wire cutters)- Amazon
lighter
for the small muscle:
1/4" silicone or latex tubing- Amazon
3/8" braided nylon mesh sleeve (see above)
1/8" small hose barb (brass or nylon)- Amazon
small bolt (10-24 thread by 3/8 in length works well)- Amazon
steel safety wire- Amazon
for the large muscle:
3/8" silicone or latex tubing- Amazon
1/2" braided nylon mesh sleeve- Amazon
1/8" or similar sized drill bit- Amazon
21/64" drill bit- Amazon
1/8" x 27 NPT tap- Amazon
1/8" hose barb x 1/8" pipe thread adapter- Amazon
small hose clamps- Amazon
3/4" aluminum or plastic rod to construct the muscle ends- Amazon
Safety note- make sure you wear safety glasses when testing your air muscles! A high pressure hose that pops off a loose fitting could cause a serious injury!
Step 2: Making the Small Muscle
First cut a small length of the 1/4" silicone tubing. Now insert the small bolt into one end of the tubing and the hose barb into the other end.
Now cut the 3/8" braided sleeve about two inches longer than the silicone tube and use a lighter to melt the ends of the braided sleeve so it doesn't fray apart.
Slide the braided sleeve over the silicone tubing and wrap each end of the tube with the safety wire and tighten it.
Now make some wire loops and wrap them around each end of the braided sleeve. As an alternative to using wire loops on the ends of the muscle, you can make the sleeve longer and then fold it back over the end of the muscle, forming a loop ( you have to push the air fitting through)- then tighten the wire around it.
Now connect your 1/4" high pressure tubing and pump a little air into the muscle to make sure it inflates without leaking.
To test the air muscle you have to stretch it to its full length by putting a load on it- this will allow it maximum contraction when it's pressurized. Start adding air (up to about 60psi) and watch the muscle contract!
Step 3: Making the Large Air Muscle
To make the large muscle I turned some barbed ends from some 3/4" aluminum rod- plastic will also work. One end is solid. The other end has a 1/8" air hole drilled in it and then is tapped for a 1/8" hose barb pipe thread adapter. This is done by drilling a 21/64" hole perpendicular to the 1/8" air hole. Then use a 1/8" pipe thread tap to tap the 21/64" hole for the hose barb fitting.
Now cut a 8" length of 3/8" rubber tubing for the air bladder and slide one end over one of the machined fittings. Then cut some 1/2" braided sleeve 10" long (remember to melt the ends with a lighter) and slide it over the rubber tube. Then slide the opposite end of the rubber tube over the remaining machined air fitting. Now securely clamp each end of the tubing using hose clamps.
The larger muscle works just like smaller version- just add air and watch it contract. Once you put it under load you'll immediately realize this larger muscle is much stronger!
Step 4: Testing and Additional Info
Now that you've made some air muscles it's time to put them to use.
Stretch out the muscles so they reach their maximum extension by adding weight. A good test rig would be to use a hanging scale- unfortunately I didn't have access to one so I had to use some weights. Now slowly start adding air in increments of 20psi until you reach 60psi.
The first thing you notice is that the muscle contracts a progessively smaller amount with each incremental increase in air pressure until it fully contracts. Next you'll find that as the load is increased the ability of the muscle to contract decreases at an increasing rate until it can no longer lift the increased load. This is very similar to how a human muscle performs.
It is immediately noticeable that a change in the size of the muscle has a huge effect on the performance of the muscle. At 22lbs. @60psi, the smaller muscle can still lift, but it is nowhere near obtaining full contraction while the larger muscle can very easily obtain full contraction.
The dynamics of air muscles are fairly difficult to mathematically model, especially given the number of variables in their construction. For further reading I recommend having a look here:
http://biorobots.cwru.edu/projects/bats/bats.htm
Several applications of air muscles include robotics (especially biorobotics), animatronics, orthotics/rehabilitation and prosthetics. They can be controlled by microcontrollers or switches using three way solenoid air valves or by radio control using valves operated by servos. A three way valve works by first filling the bladder, holding the air pressure in the bladder and then venting the bladder to deflate it.
The thing to remember is that air muscles must be under tension to work properly. As an example two muscles are often used in conjunction to balance each other to move a robotic arm. One muscle would act as the bicep and the other as the tricep muscle.
Overall, air muscles can be constructed in all sorts of lengths and diameters to suit a wide variety of applications where high strength and light weight are critical. Their performance and longevity varies according to several parameters regarding their construction:
1) Length of muscle
2) Diameter of muscle
3) Type of tubing used for bladder- testing I've read states that latex bladders tend to have a longer service life than silicone bladders, however some silicones have greater expansion rates (up to 1000%) and can hold higher pressures than latex (much of this will depend on the exact tubing specification.)
4) Type of braided mesh used- some braided meshes are less abrasive than others, improving bladder life span. Some companies have used a spandex sleeve between the bladder and mesh to reduce abrasion. A tighter woven mesh allows for more even pressure distribution on the bladder, reducing stress on the bladder.
5) Pre stressing of the bladder (the bladder is shorter than the braided mesh)- this causes a reduction of contact area (and hence abrasion) between the bladder and braided mesh sleeve when the muscle is at rest and allows the braided mesh to fully reform between contraction cycles, improving its fatigue life. Pre stressing the bladder also improves the initial contraction of the muscle due to initial lower bladder volume.
6) Construction of muscle end housings- radiused edges reduce stress concentrations on the bladder.
All in all, given their power to weight ratio, ease/low cost of construction and ability to mimic the dynamics of human muscles, air muscles offer an attractive alternative to traditional means of motion for mechanical devices.
Have fun building them! :D
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    245 Discussions
    HTSystems
    1 year ago
    Also to make up air, same as electric car braking, high pressure air pump in legs. May be use the air out to the pump's intake too.
    HTSystems
    1 year ago
    Not sure if my post went up or not but make a voltage controlled air regulator. A solenoid coil pulling on the spring or acting like the spring of a regulator.
    HTSystemsdmartinez2560
    Reply 1 year ago
    I've thought about doing this for the past 30 years. After seeing how a building automation systems works and control the air. You'll have to control the air pressure. Make a voltage controlled regulator for air. A small coil controlling a regulator spring, now you'll have to make many one for each muscle. You might have to make a pilot type valve so you can move much more air faster.
    Also the paint ball air high pressure tanks (4500 psi) hold more air than co2 I think. Don't forget about pressure safety use a pressure relief valve 4500 in most things = bad!!!!!!! Even from co2 at 800 or 900 psi can bad very bad!!!!
    To get more air added to your tank think about adding a high pressure pump to legs???? It could pump air if going down stairs like electric car braking, right? Even take air coming out of muscles to intake of pump or have a higher than outside air tank for pump intake to help pump. Even having air at 20 or 40 psi will help the pump. Now this might hurt in other ways and you may need to dump air in that tank over 20 or 40 psi to keep air moving as fast as it needs.
    tatebullrider
    1 year ago
    I have been thinking of building an exo-suit, and these might just be the ticket. I bet paintball CO2 tanks would work great for this too.
    KevinK274tatebullrider
    Reply 1 year ago
    i've been working on prototypes for over 5 years now. designing and redesigning parts. the problem with these is they need constant replenishment of lost air, because when the muscle deflates, the air escapes, it doesn't return to the tank. having more power with these would require a fair amount of pressure. which means a more powerful compressor. how are you not only gonna carry it, but power it as well? in all honesty, a linear motor design for the joints still works best. the only limiting factor here being how are you gonna carry enough power with you for extended use? and let me know if you figure that one out...
    tatebullriderKevinK274
    Reply 1 year ago
    Hmm, these are interesting points. Thank you for the advice! I don't know much about these, but I would assume a regulated SCUBA or CO2 tank would last at least a little while. With linear motors, you would still have to carry a battery pack, and linear motors move much slower than air muscles. I guess each has there pros and cons. Thanks again!
    Reply 1 year ago
    A faster displacement can be achieved with a wider thread. this would come at the cost of power. In creating such a suit you'll have to balance power and speed. imho, if the actuators used can support running at roughly 18 km/h (or 11 mph) they are fast enough, the rest of the gears should be configured to provide additional strength. it's all about how much energy can you pack on board and how you convert it. assuming you're wanting the same as me, about the size of medieval armor, the most efficient way we know goes out the window, fuel, next in line is electricity, which comes in batteries, which can packed in pretty much everywhere, and linking them in a specific way can make 2 1,5V batteries 1 3V battery, etc. if you'd like to discuss the topic further, i'm on facebook, my name is Kevin Kuyl, i'm from the netherlands. that should be enough to find me. there's just way too much material to cover and i'd love to talk about this with some one, all my friends think i'm nuts :P
    CalebGreer
    2 years ago
    That's a lot simpler than I thought it would be. I can't imagine how I'd find a use for those, but someone is gonna figure out how to put those to work!
    rsaelens
    2 years ago
    Hey there, I made an exo arm in which is like to include a pneumatic muscle. Probably the small one. But I was really wondering if I could you co2? Mainly because I can fit the cartridges right into the arm. Please let me know and I greatly appreciate it.
    Honusrsaelens
    Reply 2 years ago
    I can't see any reason why that wouldn't work.
    rsaelensHonus
    Reply 2 years ago
    Okay great! This is my first attempt as this air muscle stuff, so I was wondering if you could please tell me how I'd go about the co2 cartridges instead of air tank? Sorry for being a pest, I just want to make sure it's done correctly. Thank you!
    Shanethefilmmaker.
    2 years ago
    Ok I get how to make the muscle but how do you go abouts making an exo-arm
    Honus
    2 years ago
    They should easily handle 2 bar pressure.
    XYZAidanLeonardodiserdavincy
    Reply 3 years ago
    i've actually done such a thing. You can see a video of it here: https://www.youtube.com/watch?v=ehh1ldim8H4
    AronR
    3 years ago
    Ola Im brasilian..minha duvida e se a capa de nailon tem que ser espesifica
