How to Make an Alcohol Stove
5,122
65
4
An stove made from a tin for survival or camping purposes
Supplies:
Step 1: Get a Suitable Tin
Get a tin that you can use for your stove. Make sure that you choose one that can hold a pot comfortably.
Step 2: Create Circle for Hole Placement
Draw a circle the size of the tin lid. Divide that cicle into 16 pieces.
Step 3: Make Holes in the Cicle
Use a toothpick to make holes on the edge of every line and inbetween the two lines
Step 4: Attach the Circle to the Lid
Roll up a piece of tape with the sticky side on the outside. Place the tape in the middle of the circle. Place the circle on the lid.
Step 5: Marking the Holes
Take a permanent marker and mark the holes onto the lid.
Step 6: Making the Holes
Take a hammer and nail and hammer a hole where all the permanent maker dots are.
Step 7: Pouring the Alcohol
Pour alcohol into the tin
Step 8: Lighting the Stove
Hold a lighter below the stove. Wait for a few moments then place a lighter on the top of the stove. The stove will then ignite.
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    4 Discussions
    ToutHackAmon
    4 years ago on Introduction
    Good job ,, thanks for sharing :) ,,,
    How much time this stove should work?
    IdahoDavid
    Go to the plant store and get a bag of perlite. Put it inside your tin. The perlite absorb the alcohol and you get a more even release of the flammable gases. Also, it slows down spills if you know your stove over. Nice design.
    xpozitron
    Ok, and you put the pot on this covering the holes extinguishing the flame. Paráda!
