How to Make an Alcohol Lamp
2,164
58
4
I turned a small jam jar into a palm-sized alcohol lamp in less than an hour.
Supplies:
Step 1: Materials
Materials needed
1. A glass jar with a metal lid( I used a small jam jar)
2. A string for the wick
Step 2: Sanding Off the Paint (optional)
Tools
Sandpaper
I did this for looks, but this step is optional. I used some sandpaper to sand off the paint on the lid and expose the steel. Finally, let's use a sanding sponge to buff the lid so that it'll look a bit more shiny.
Step 3: Punching Hole
Tools
Hammer
Smaller nail
Larger nail
A drill would work best for drilling a hole in the lid, but since I don't have a drill, I used nails. I used a marker to mark the center of the lid, then placed the smaller nail on the mark and hit it with a hammer for a few times. Then I pulled out the nail and repeated the process with the larger nail.
Step 4: Test Your Alcohol Lamp!
Tools
Toothpick
I used a toothpick to help insert the wick into the hole, then poured some alcohol into the lamp and lit it with a match. After using the lamp, use something like a soda cap to cover the wick to reduce evaporation.
Step 5: Enjoy!
Now you can use your mini alcohol lamp to do experiments and set everything on fire! :)
Step 6: Vote!
This Instructable has entered a few contests, so if you find this useful, please vote for me! Thanks:)
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    SHOE0007
    5 weeks ago
    I used to get expensive alcohol lamps from Prolab, etc but now I get a 250 ml paint can put a hole in it then put in a wick for microbiology stuff. Here a picture of it. I use 99 percent Isopropanol alc.
    fred3655
    4 years ago
    Do I buy a special alcohol for this? Could I use lamp oil, cooking oil or anything else?
    andytangtskfred3655
    Reply 4 years ago
    I think any type of fuel should work but oil might take a little longer to light, I am using 75% rubbing alcohol (isopropyl alcohol) but you can use denatured alcohol or alcohol of higher concentration for better results.
    Andy
    Pointyhead
    4 years ago
    Nice Instrictable that is really easy to make. Lots of possibilities for this.
