How to Make Cannabis Coconut Oil (canna Oil)
703,874
373
37
About: we're a couple of medical cannabis farmers that believe in responsible and educated use of cannabis for all! we hope our instructables will teach you useful skills that you can use to grow, process, and medi...
Cannabis coconut oil is a really versatile way to consume cannabis. It's great taken alone or baked into all kinds of edibles - most strains of cannabis beautifully complement the flavor of coconut oil! Canna oil makes medicating super accessible, too - you can use indica, sativa, or even high CBD strains to get the desired effect you want.
It's also super easy to make, and a great way to use up excess trim, kief or hash from harvest. In this instructable I'll show you my favorite way to do it - simmering on the stove top! But I'll tell you how to do it in a crockpot too.
This is a very fast and no-fuss version of canna oil - through lots of reading and quite a few experiments I really don't believe it's necessary to simmer it for-ev-errr and over complicate it. This method will give you a potent, tasty and fancy canna oil.
Step 1: What You'll Need
tools:
  • cheesecloth
  • metal strainer/sieve
  • bowl or large measuring cup
  • jar or bowl to store the canna oil
materials:
  • decarboxylated cannabis (buds, trim, kief, hash - 40 grams)
  • unrefined coconut oil (2 cups)
We'll talk a little about dosing on the next step.
Unsure how to decarboxylate cannabis? Click here to find out!
Step 2: Dosing + Strains + Expectations
(Pictured above - Doctor Who water hash, Doctor Who in bud form - so purple!!, Doctor Who sugar leaf trim)
What I'm using for this batch:
  • 2 cups unrefined coconut oil
  • 40 g Doctor Who trim, decarboxylated
This is a fairly strong dose - about 1.5 g of trim per tablespoon of canna oil. The medibles this canna oil makes will be used primarily for combating migraines so stronger is better!
Guidelines for dosing:
I recommend using anywhere from 0.5-1.5 g of trim/bud/hash/etc per tablespoon of oil. If this is your first time experimenting with canna oil, try using 16 grams of cannabis to 2 cups of oil.
When using buds, it's okay to use less than you would if you were using trim as there will be more trichromes present and therefore more THC. If I was using buds instead of trim in this batch, I probably would have used 0.5 grams of bud per tablespoon of coconut oil.
For more information on dosing cannabis, I really recommend picking up a copy of The Ganja Kitchen Revolution by Jessica Catalano. The book includes a very nice dosing chart and explains how to demystify making edibles with the right amount of THC for you.
This article on The Cannabist also includes a helpful way of figuring out the THC content in edibles.
What to expect when using canna oil:
Cannabis taken orally a totally different beast - it can take you much longer to feel it, and the effects can linger much longer on average. Canna oil is often quite potent and can make you super sleepy, so never try a new dose when you have obligations later. ;)
You can try to combat sleepiness by using only sativas in your canna oil, or by choosing a strain high in CBD. But it might still make you a teeny bit tired (edibles always do that to some folks!), so always use caution.
What to do if you take too much canna oil:
If you ever take too much while trying to figure out the proper dose, don't worry! You may feel anxious or wonder why you ever thought this was a good idea - but I promise it will pass and the benefits are worth it.
Your best bet is to drink a glass of water and lie down. Sleeping is always the best possible way to handle having a bit too much cannabis.
If sleep seems unreachable, try dimming the lights and putting on music or the TV. You can try talking to someone too. Whatever relaxes you! Just keep in mind that it will pass in a few hours at most.
Step 3: Combine the Coconut Oil and Cannabis and Simmer
Combine the cannabis and coconut oil in a small saucepan over the lowest heat you can manage.
Once the coconut oil has melted, let the mix simmer uncovered (stirring ever so often) for an hour.
HEY! If you'd like to do this in a crockpot you definitely can. Just let it go on low for a couple hours. It's not necessary to take it longer than that.
If your canna oil turns out super green or not green at all, that's fine. The green-ness relates only to the chlorophyll present, not how strong the canna oil is.
Step 4: Strain
For straining, use cheesecloth in a sieve over a large measuring cup. A sieve normally isn't fine enough on its own! It won't matter too much if you end up with particulates in the oil, but it always looks nicer without them.
Place two layers of cheesecloth in the sieve and put it over the measuring cup.
Pour the hot oil and cannabis mixture into the cheesecloth.
Let it drip for an hour or so and then squeeze the rest out by hand.
You can use the processed cannabis in other things once you've squeezed out the oil, but it shouldn't have much THC left in it at all. One of the most awesome ways is to mix it with softened butter - you end up with an awesome cannabis compound butter that you can use on toast or maybe even put a dollop on a steak or under the skin of a chicken.
However, don't feel bad if you just compost it or throw it out - nearly all the good stuff is in the canna oil now!
Step 5: Cool and Store
Pour the canna oil into a glass jar or bowl and leave uncovered until room temperature and beginning to solidify. (Leaving it uncovered is very important because we want to avoid condensation forming in the jar)
Once entirely cooled, close the container and store in the fridge or in a cool dark place. This will keep for up to a year!
See how dark it is before and how light it is when it solidifies? That's what it should look like if you don't simmer it too long and you're not too rough with it. If you poked it a ton it might be more green.
Step 6: Using Cannabis Coconut Oil
You can consume this coconut canna oil on its own or use it in edibles!
If this is your first time trying it, I recommend taking 1/4-1/2 tablespoon by mouth to start. Wait at least 3-4 hours before taking more. How you feel after this will let you know if you need to increase or decrease your dose. It will also give you a baseline for edibles.
If making edibles, try using recipes you've made before. Knowing how many cookies, muffins, slices of cake, etc. that a recipe produces will allow you to figure out about how much THC per serving there is. (Because we know we're using a certain amount of cannabis per tablespoon of coconut oil - you can determine the strength based on the amount of oil you used in the recipe and how many servings it makes)
Another good thing to keep in mind: you can even do half canna oil and half butter if you need the edibles to be a little less strong.
6 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
  • Tape Contest
    Tape Contest
37 Discussions
NancyS253
Question 2 months ago on Introduction
i have 4 bags of trim... can i bake all of it & store it or do u only bake as u need it? if I can store it, glass canning jars ok? thank u Nancy
LindaB414
Question 3 months ago on Introduction
I tried following how to make CBD oil using coconut oil but I thought it was going to take out the THC But it didn’t my reaction are extremely server I have a over reaction from a medical condition I cannot take medication due to reactions but I have serious pain how can I get thc out after it’s already made?
AlexanderS314
Tip 4 months ago on Step 3
When simmering you should maintain a temp of 220 degrees. This will not burn your bud or effect the oils taste. it will also make sure that the buds are fully decarbed as you will see bubbles form if there is thcA present still.
tanyainspace
Question 1 year ago
I followed the directions to the letter and my oil turned out burnt, it is darker than the photos and has a slightly burnt smell. Can I still use it or will I get sick?
ChristopherR143tanyainspace
Answer 7 months ago
It sounds like you "cooked" your herb a bit too long or perhaps your oven has many heat spikes, which I would say is the answer if you followed the instructs. When the oven has to heat itself back up to 220 or240, whatever temps you use, it is possible that these spikes caused the burning. When I decarb, I pretty much sit beside the oven and monitor the heating cycle, as these can be tricky. Try setting your heat for around 200 and heat for as long as normal, but TRY WITH A SMALL AMOUNT> Good luck!!! It can be tricky but it is very possible!
AlexanderS314ChristopherR143
Reply 4 months ago
A sure fire method of infusing and decarbing is to heat the oil to 220 degrees and steep for an hour like normal and strain. but then put back on the heat at 220 until there is no more bubbles. which is the carbon gas escaping from the thcA. when no more bubbles the thing is done. I usually put the bud to decarb in the oven for half the normal time to get the ball rolling. 250 for 17 or so min.
TraciW14
Question 8 months ago on Step 1
Why unrefined coconut oil?
tanyainspace
1 year ago
I just made this last night, and burned it. Wasted 1/2 of some premo medicine and can't re up my prescription. Can I still use the burnt oil or will I get sick? I've made edibles with butter countless times and never had a problem as long as I added water to the butter and bud mixture. Since I never used coconut oil I thought it might be different so I followed these instructions. Wish I had just used my tried and true method instead :-(
JulieW135
Question 1 year ago on Introduction
Attempting this recipe now and it looks too thick in crockpot now Yo be able to strain later. It’s been on low for over one hour now. I used a coconut butter product and thought it would be okay. If it doesn’t become more viscous should I add another oil or something else? Help is appreciated ✌️
izzyspeaks123
1 year ago
For mine I used an induction stove top set at 220F for 90 minutes with four cups of water and two sticks of butter. This was low dose so it was 1/4 per stick of butter. Naturally decarb it. For straining I used a fine mesh metal coffee filter and pressed it through using the back of a spoon. To clean up I use a warm piece of bread and dab up the butter.
DaveW173
1 year ago
Some Tips:
Instead of just a pan, I use stove top, but I use a double boiler, this way there is less chance of burning or scalding the mixture. I add water and just keep it just below a simmer. I've found s crock pot can also burn as it's heating up and cooling down. Also I "cook" it for 3 or 4 hours. That seems about right for me, not 12 hours, not 8, but 3 or 4.
When I decarboxylate (in oven 240 degrees) I only do about 25 minutes as my weed is a little dryer by the time I make the oil. Enjoy!
Steven Linder
1 year ago
Been makin' it! Like the old butter extracts, I use boiling water to aid preparation.
To 70 grams of Coconut oil in about 1 quart of boiling water is added 1 ounce of Cannabis. This is stirred at times for at least two hours. Overnight on low also works good after initial roiling boil. The hot Cannabis/Coconut oil/water mixture is filtered through cheesecloth into a large pyrex measure. Then the mark is rinsed with more boiling water and pressed with a tool to aid removal of all the oil extract. Placed in the fridge overnight, the top layer puck is easy to remove and blot dry. 1/4th teaspoon seems to be a good dose for high CBD medicine. Be careful with high THC Cannabis. This dose might be too high for the unaware.
iameka
2 years ago
Trying this now!
Andrew tackor
2 years ago
Great article. I read this and found the best process how to make Cannabis Coconut Oil (canna Oil). My friend suggested me to checked cbdoilempire[dot]com, for CBD Oil, offers the best selection of the top cannabis oil, CBD products all in one place.
thedeklerks
3 years ago
I am from South Africa
I am new at this and I am looking at it helping me in the control
of pain. I have had thirteen lumber spinal operations. I have a Morphine pump inserted
in my abdomen that feeds my spine via a catheter and I take thirty seven tablets-capsules
a day.,I go,to a GP bi weekly for s cocktail of drugs which he administers intravenously via a drip. I need this to work so that I can cut down on the medication especially
the bi weekly Morphine cocktails. Do you think that I am doing the correct
thing.?
That cannabis that I used was a low grade head with a lot of
pips. Do you think that I must remove
the pips before starting the process?
How strong must I’ make it? I purchased a plastic shopping
bag full for R200.
Anyway to cut a long story short I dumped the whole lot imt cooker with three kilograms of coconut oil. It has boiled for the best part of
the day and it still looks quite clear. Please help are there any tips to save
my brew?
MelanieS106thedeklerks
Reply 2 years ago
ek maak die kapsules van die resep as jy sou belangstel om te koop. R400 vir 31. Soek my op Facebook. Melanie Melaantjie Schoeman
LisaL141
2 years ago
I cut the recipe in half for my first try lol I'll be using it for sugar cookies and banana bread
RickS179
2 years ago
Our Cannabis Oil is Pure and potent.Never watered down or diluted,just 100% pure cannabis oil extracted from top quality marijuana grown by us and other professional cultivators in California,laboratory tested,then offered for sale here.Our cannabis oil is packaged in 1gram and 3.5 gram disposable syringes for easy dispensing.If you aren’t sure how to get the cannabis oil out of the syringe,For orders and more information,Kindly contact us on our Email: ricksimpsoncurecancer1@gmail.com
Kim Macrazy
2 years ago
We're set up and excited to make our first batch! We have a convection oven, but the temp only goes down to 250 degrees and the instructions say 220 degrees. Will the higher temp ruin it? Thanks!
Marcyroy
3 years ago
If my oil comes out black does that mean I burned it? It still seems pretty potent but it is black....very effective recipe, Thanks
