How to Make Laser Projection Virtual Keyboard
42,496
128
31
The laser projection virtual keyboard designed in this thesis is based on OpenCV combine with image camera, 980nm linear laser, 980nm infrared filter and Keyboard projection laser, the image camera detection used with 980nm infrared filter is caused by shielding finger to make 980nm linear laser diffuse reflection the light . By detecting and locating the center position of the light outline to discern and detect the position of finger and then map to keyboard position to achieve relative keyboard key events. With OpenCV vision library, it is fast to find the finger outline which is get by image camera, the position of finger location and revise the image surface distortion which is caused by image camera. By using OpenCV, the bottom hardware drive code written can be reduced, and invoke built-in function can directly face to hardware write code to fasten the difficult and speed of program development. By experiment and test, this virtual keyboard can correctly and accurately locate and detect the finger position, on the other hand, this keyboard also have fault-tolerant treatment, and finally realize the function of key input.
Supplies:
Step 1: The Laser Projection Virtual Keyboard Designed
You need:
Image camera: $ 20 (USD)
Keyboard projection laser: $ 38(USD)
Infrared filter: $ 6.1 (USD)
linear laser: $ 54 (USD)
Step 2: How to Work
At the bottom of the infrared laser emission from a surface of a covering space in the infrared range, of course this plane to cover the entire keyboard, a keyboard in the center of the keyboard is the projection contour shape of the keyboard is mainly used for calibration, at the top of the real-time camera outside the graphics and pass data to the computer, because the laser light is a horizontal and parallel so no object occlusion camera is unable to detect the infrared signal, but if there are objects in the infrared laser region when the occluded objects' surface will be covered with the infrared camera will detect the infrared signal, computer access to the signal sent by the camera after after a certain the algorithm to obtain coordinates in the picture of infrared spot and then put the coordinate mapping to real keyboard position so as to realize its function.
Step 3: Choose Camera Lens
The camera of detection of the same area, ‘Camera2’ is angle of view 150°need height is 'h2', and the ‘Camera1’is angle of view 90°need height is 'h1', in order to narrow the project size and choose the lens of angle of view 150°.
Step 4: Calibration the Camera Lens
The picture taken by use the angle of view 150 camera is a distortion, and in order to Calibration the distortion of the picture using Matlab camera Calibration tool ‘Calibration Toolbox Camera’.
Step 5: The Camera Calibration Toolbox
Although "the camera calibration toolbox" as long as 3 different angles to shoot photos can be a good camera calibration, but in this design used 9 different angles to shoot photos of the camera calibration the calibration parameters, the parameters are applied to opencv correction algorithm in real-time operation can be real-time correction of distortion of the picture.
The following link is the algorithm paper and ‘camera calibration toolbox’ guide
http://www.vision.caltech.edu/bouguetj/calib_doc/
http://research.microsoft.com/en-us/um/people/zhang/Calib/
Step 6: Lens Process
The PC camera is visible and infrared detection are not allowed to enter because the infrared light in practice may cause the whole picture of the color fidelity, PC camera in the design of the product design manufacturers often use infrared filters in the infrared light environment, in this project need to detect the infrared signal is so PC camera behind add a layer of infrared filter, this filter can filter out visible light infrared light and visible light are only allowed to enter, because of the use of this system is the 980nm infrared laser, so the permeability of 980nm filter, this filter can filter the 980nm light for more than 980nm light has good permeability.
Step 7: Why Choose Linear Laser
Select the 980nm infrared linear laser as the source of the signal detection, the linear laser can cover all the keyboard range.
Step 8: PC Software
The development of software is Visual Studio 2010 and OpenCV library.
Step 9: Programming and Algorithm
Use cvCaptureFromCAM () function and cvQueryFrame () function to get the camera image,Using the cvCvtColor () function binarization the image,Use findContours () function to find the object contour, drawContours () function to draw the object contour, boundingRect () function to draw the object contour of the rectangle
Step 10: Test
Press space key the PC will check the key
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    31 Discussions
    lodong
    6 weeks ago
    공개 CV를 보내 주시겠습니까?
    네가 나와 행복 할거야.
    내 이메일 주소는 kdh12324664@gmail.com
    Mahan04
    Question 4 months ago
    How to make the laser projector thoug? For the keyboard pattern please someone answer
    katie788
    1 year ago
    amazing job out there. I'm looking for something similar to this so please if u can mail me the code on my email koolkatie788@gmail.com .
    Aryan77
    Question 1 year ago on Step 1
    Can you please provide the name of all the parts in detail ? What laser and what camera to use ?
    Sunset1z
    1 year ago
    Nice work for your project! Could I get the OpenCV code as well? I would like to build a similar device like this. my project is this semester please help me out. thanks. God bless you
    My email is : richrich693@gmail.com
    Aryan77Sunset1z
    Reply 1 year ago
    hey @Sunset1z did you got the open cv or any related products ?
    TrungP15
    1 year ago
    Hi there,
    Could you please send me the OpenCV code at email : trungphamthanh86@gmail.com ?
    Thanks in advance.
    edma.analoua
    1 year ago
    I was wondering if I could get the OpenCV code, I was doing this for a school project. My email is edma.analou.a@gmail.com
    G.H.Q.D.mafiaWolf
    2 years ago
    The keyboard pattern of you is not quite same as keyboard pattern in taobao. :'(
    Ap amit
    2 years ago
    Hi..I'm very much interested in this project. Can you please send me the openCV??? My email is apc3777@gmail.com
    durvesh123
    2 years ago
    can i get open cv for this project , my email id is kunal.golvankar@gmail.com
    Sung WooH1
    2 years ago
    My email is : ihansw@gmail.com
    500934
    2 years ago
    I was wondering if I could get the OpenCV code, I was doing this for a school project. My email is presidentpinecone777@gmail.com
    Thank you :D
    513696765theawesomemt
    Reply 2 years ago
    Are you interested in this project?because i am a Chinese ,this is my graduation design,but I can help you to order all the components sent to you in China.my E-mail is 513696765@qq.com
    TonyR87
    2 years ago
    i can't make program run correctly. can you send me openCV code my email is daggerincoat@gmail.com
    KituM
    2 years ago
    I just don't seem to find the components anywhere.. the DIY kit is out of stock on almost all the sites and aliexpress cancelled the order. can you please tell me where can I find all the components?
    KituM
    2 years ago
    Can I get the OpenCV code too? my email address is jainkkritika.km@gmail.com
    westwarde
    2 years ago
    This is a wonderful project, I would also very much appreciate the OpenCV code if you still have it around. If you can, send it my way via personal message or email.
    Thanks so much in advance
