How to Make Your Own Fermentation Lock (Not a Balloon!)
273,791
166
48
About: I enjoy growing citrus plants, building things that capture green energy, constructing car audio systems, and nearly any DIY project.
Are you thinking about making your own wine or beer? There are lots of quick and simple recipes out there for making wine but many of them suggest you use a balloon as your airlock. While this is very cheap and practical, I have found that many people claim it can leave a "rubbery" taste in your drink.
Commercial airlocks are not expensive by any means, but if you are like me and don't live close to a home brew store, you are on your own. Ebay sellers want ~$2 plus whatever gouged shipping charges they feel like putting on top of that. I have a simple solution for you, you can make your own super cheap one for less than $2 and maybe even free if you have all the stuff lying around!
I list 2 different methods, one is the bare minimum way (~36 cents plus some spare things you probably have lying around) and the other is the recommended way (a little under $2). I only have pictures for the recommended way but the diagram I use can be altered to work for either method.
Supplies:
Step 1: Materials
Bare Minimum way:
- Tape
- Pen
- Plastic tubing
- Jar (clear is best)
- Water
- Something to punch a hole with
Recommended way:
+ Hot glue gun
+ 1 Nylon barb and matching nut (I got this from the hardware store, ~$1.25)
+ Plastic tubing (~ 2 feet, depending on where you will be placing your jar)
+ Jar (clear is still best)
+ Water
+ Drill
Step 2: Methods
This is my illustration, hopefully it is pretty straight forward. I have some detailed instructions below...
1: Cut a hole in a box
Drill a hole in the lid of your fermentation vessel (or punch a hole in it, however you prefer to make holes). Make sure that it is very close in size to your nylon barb (or pen top). If you make the hole too big you risk not being able to make the seal airtight.
2: Put your junk in that box
Place your nylon barb into the hole you made in the fermentation vessel's lid (the barb should be on the external surface). I got a nylon barb from the hardware store for about $1.25. Lock it down by placing some hot glue around the hole and then quickly bolting the barb to your lid with its corresponding nut. If you are not satisfied with the seal, use more hot glue around the cracks where air may escape.
If you are doing the bare minimum method, put the tapered pen piece in the hole (tapered end facing outward) and tape it down like hell. I am assuming duct tape would be the tape of choice for this method.
3: Make her open the... I mean hook up your tubing
Hook up your plastic tubing. I bought mine from the hardware store for 18 cents a foot but I am sure there are plenty of places you can get it (Maybe some aquarium tubing from a pet store? Not pre-used though, that would be unsanitary). Either way, I bought 2 feet of tubing which worked out quite well, you may need more if you are not using a bucket as a fermentation vessel and have to set the jar somewhere farther away. As explained in the step's title, hook up the tubing to your barb (if using a pen tip you may want to using something, like tape, again to make sure your seal is still air tight, this problem is not as prominent in the barb method though).
4: Cut many holes in your jar's lid
Cut a main center hole in the jar's lid that is large enough for your plastic tubing to fit in, the size of this one is not that important. I place a little bit of tape around the rough edges of the hole as to not damage my plastic tubing. Also, poke many smaller holes around the center one to allow CO2 to escape from you airlock jar.
5: Place your tubing below the water level
This is pretty self explanatory, fill your jar about halfway with water and place the tube below the water level so that CO2 can escape from your vessel but will not come back in (due to the water barrier). I found that the closer the tube is to the water level (while still being below it) the quieter the bubbling noise is.
Step 3: Results
There you have it! You now have your own homemade airlock and it cost you less than $2. Be proud of yourself.
Also, I recommend using water or vodka in your airlock, not sanitizer. This is what I found about it on wikipedia.org (the greatest site ever!).
"Many brewers simply fill the liquid chamber with water, which in itself acts as a sufficient barrier to contamination. Others use a sanitizing solution in their airlocks. However, this is generally a bad idea with a small airlock. Sanitizer does not offer much, if any, additional protection, since airborne bacteria or wild yeasts are unlikely to be able to pass through any liquid and become airborne again in sufficient quantity to spoil beer. More importantly, under some circumstances, material from the airlock can be sucked into the fermenter, and even unboiled tap water is better for your wort or must than most sanitizers. As a compromise, some brewers use vodka, which is sanitary but will not contribute any flavor or character to the finished product other than a small amount of alcohol."
Step 4: Discussion
Let me know if you have any improvements, comments, or airlock ideas of your own!
It would be cool if someone did this but had their excess CO2 go to a plant containment vessel to try to boost their plant's growth...just an idea!
Get your drink on.
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    48 Discussions
    LaraC26
    5 months ago on Introduction
    Hey! Great guidance. Living in Fiji some things are impossible to find, but managed with a little ingenuity. Eager to try the pineapple-papaya concoction. Thanks do much for sharing.
    Ben70
    Question 7 months ago on Step 4
    I was going to make this, but all I had were some metal air valve pieces from my neighbors garage. I don't have anything to sanitize with, so I rinsed them pretty thoroughly with water. There's still some grease residue, however. Not a lot. I guess my question is what will this do to the wine? Will it just make it taste worse or will it pose serious health risks?
    DianeE14
    2 years ago
    I am looking forward to using this method, as I have made some wines using the balloon system. They came out well, but have been looking for a better way to do things. This will work out well, as I have all the "stuff" [jars, glue gun, new aquarium hose, duct tape, jars] So I am looking forward to seeing how this works as I attempt to make some dandelion wine this year.
    mmmelroy
    2 years ago
    for those that only buy a bucket and lid, but need a fermentor, this is the TRICK! save the few $ and make your own...
    finfan7
    10 years ago on Introduction
    This is interesting but my first question is immediately: did your setup not come with a free airlock?
    raleggfinfan7
    finfan7, My whole setup was made from scratch so unfortunately I didn't already have an airlock. The fermentation vessel shown is just a food-grade, 5 gallon bucket that I happened across, which I then made the enhancements as shown above to get my final setup.
    DeeRileeralegg
    Reply 5 years ago on Introduction
    One thing that should be noted regarding 'food-grade' buckets......don't reuse one that had previously possibly contained vinegar. You will likely end up with a batch of vinegar for your troubles. My father made his own wines & beer, and that was one thing he always cautioned about.....it's impossible to get every trace of vinegar out of any bottle, jar or bucket, and a trace CAN turn your wine into 'wine vinegar'.
    Wonderful Instructable!!!!
    finfan7ralegg
    That's cool. I got mine as a gift. Brewers in my area are kind of lucky. We have a Brew-Your-Own Store right in town. The prices for hops are fairly reasonable. Do you do wine, beer, or both? I've been wanting to try my hand at wine.
    raleggfinfan7
    Currently I have only made wine but I am looking to try making beer next! I hope wine works out for you if you give it a try!
    kotpet
    9 years ago on Introduction
    Very good instruction. I would add that one don't need a lid on the receiving can. Just my 5 cents. Good luck to all!
    DeeRileekotpet
    I believe the only purpose of the lid on the "receiving can" was to hold the tubing in place.
    uberchoob
    6 years ago on Introduction
    Awesome Ible! I'm brewing up some ginger ale tonight when I realized I was out of balloons... Then I found this! Lifesaver :)
    I'm brewing directly in 32oz bottles, so I took an old wine cork and drilled a 3/8 inch hole in the center and shoved some 3/8 inch tubing in it. Then drilled out the same in the lid of a perrier bottle I had, punched a couple holes in it, filled it with water and called it dandy.
    Thanks again!
    RainDog07
    I just run the blow-off tube into a container of sanitizer located below the fermenter.
    Homepwner
    7 years ago on Introduction
    The sports drink "Powerade" has a sippy lid on it that has a silicone seal with an X cut into it. I think it"s called the "powervalve" I don't brew but watched my Dad do it for years... long ago. I want to see someone fit this as a dry airlock to their carboy! I think it would make "fartlike" noises when it vented HAHAHAHAHAHA! please post a video if you try it.:) sorry, I'm still a Kid at heart!
    codyg102
    7 years ago on Step 2
    Another option for quieting the bubbling might be an aquarium air-stone (from you friendly neighbourhood pet store) in the water jar (much smaller bubbles = quieter?). Haven't actually tried it; just a thought.
    cider101
    I'm making apple cider for the first time soon and am trying to learn all i can. once all the ingredients are in the fermenting bucket is there suppose to be no oxygen/air at all? meaning the bucket becomes a vaccuum chamber?
    Green Goddess
    This is so brilliant!!! I am officially inspired! I signed up just because of this! Thanks for the help :)
    2muchfreetime8
    8 years ago on Step 2
    i love the d**k in a box reference. and interesting instructable, gotta say
    I just used this for my ginger beer, it worked perfectly! Since I don't have wheels right now, it is my best option, and much better than continually opening the brewing vessel. Thanks!
