How to Remove 5 Gallon Bucket Lids
8,673
8
About: "CAN'T can't do anything until TRY comes along and does it" -Grandpa
5 gallon buckets are great to reuse, but many are made with lids not intended to be removed. This instructable will show you the way to easily remove them without damaging the bucket itself.
Supplies:
Step 1: Tools
Tools needed
Safety glasses
Kevlar gloves (to avoid cuts)
Utility knife with sharp blade
Jigsaw
Step 2: First Cut
To start, make a small cross shaped hole in the lid as shown. This will allow you to fit your jigsaw blade in.
Step 3: Cut Around the Brim
Next, take your jigsaw and cut the whole center out of the lid
Step 4: Final Cuts
Cut the outside, top, and inside of the lid so that it is completely split.
Step 5: Peel It Apart
Use a flat head screwdriver to begin removal. Once it's started, it will easy to pull apart.
That's all there is to it. The process is simple and can be completed in a matter of minutes. Be sure to wash them out before use if they've contained chemicals.
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    2 Discussions
    connie46
    4 years ago
    Sorry wasn't finished pull up the lid will come off it takes a little work but you can save your lid
    connie46
    4 years ago
    If you will use a screw driver and get under the lip of the lid and prie
