How to Save a Dry Highlighter Lifehack
112,545
6
20
About: www.patreon.com/making https://www.youtube.com/making www.thingiverse.com/MakinThings/designs
Highlighters, whether new or old, sometimes become dry. You know them, screeching on the paper, barely doing anything. Today I will show you a very simple way to save your highlighter!
Supplies:
Step 1: Step 1 - Notice Your Highlighter Is on the Fritz
Easy enough, you get annoying results like these:
Step 2: Setp 2- Save It!
Simply dip the tip of your highlighter in a bit of water for a few seconds (2-3 should be enough). I used my water-cooler`s drip pan for this because I was at work and did not want to colour my tea .
Step 3: Step3- Wait 10 Seconds
Wait a few more seconds (5-10) for the water to run up into the highlighter and for the tip to dry a bit (as it is now dripping).
Step 4: Step 4: Test and Enjoy!
Test it! it should now work. It should now work perfectly!
If not, I recommend the Uni Promark View highlighters (USA / Canada)
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
20 Discussions
ArshS6
5 months ago
Actually I read to put it in some acetone or nail polish remover ..I did it but it didn't work..but this water method work..and it gives dark color than before .
EdmundN3
2 years ago
It worked perfectly! Thanks!
N'TeashaB
2 years ago
Worked perfectly, thanks so much!
JuliefeC
2 years ago
It immediately worked! Hope i had read this post sooner. I could have saved a lot of my highlighters. I just forget to put their caps back on especially when i unintentionally fell asleep while studying ??
TrishC16
3 years ago
didn't work for me. Actually made it worse. It was worth a shot though.
AronL
3 years ago
Didn't work for me on any of my highlighters :(
MakinThingsAronL
Reply 3 years ago
They must have been very dry then!
Could it be that they are the ones filled with liquid (no sponge), and have a 1 way ball valve (kind of like a pen)? If not, and they are felt-tips, you could try setting 5ml of water in a small cup and let it sit until it soaks up, and then let it sit for a while so it spreads. If that does work though, keep in mind this will not work for ever, eventually you will run out of pigment. Let me know how it works!
AronLMakinThings
Reply 3 years ago
Gonna give it a try overnight. They're all felt-tip, so hopefully this will work. Thanks for getting back to me!
MakinThingsHanhB1
Reply 3 years ago
glad it helped one person in two years ;) haha.
TyrondaC
3 years ago
How do I get to the post
