How to Swap the Blade on Your Leatherman Wave, Charge, or Surge Tool
51,009
166
11
About: We modify knives, multitools and other products turning them into functional pieces of art! All of our products and materials are made in the USA!
This Instructable will give you the step by step on how to replace the blade on your Leatherman Charge, Wave, or Surge tool. The photos will follow a Leatherman Wave tool, but the steps are the same for all three tools.
Please be warned that tampering with your tool may void the warranty. If you're having an issue with your tool, Leatherman has a great warranty repair program, and in most cases you can send your tool in for factory repairs.
If you're looking for a specific modification to your tool and would like to have a warranty, please check our our website. We will mirror the original factory warranty on the functionality of all of our modified tools.
Supplies:
Step 1: Materials List
  • Leatherman Charge, Wave, or Surge tool that needs a new blade Replacement blade
    • Any version Charge TTi (TTi, Ti, XTi)
    • Any version Surge (black oxide, stainless, original version, new 2014 version)
    • Any post 2004 version Wave tool. If your Wave has removable screwdriver bits in it, it's post 2004.
  • 2x Torx #10 security bits or screwdrivers
    • The "security" part refers to the hole in the tip of the bit
  • 1x 1/4" bit holder screwdriver
  • Vice or clamp (for holding one of the torx bits)
  • Loctite threadlocker
    • We recommend the red strength
You can find both Damascus blades and stock blades at our webstore, txtoolcrafters.com. Here's the full list of available blades for the Wave/Charge/Surge tools:
Charge/Wave 420hc Plain Edge Blade
Charge/Wave 420hc Serrated Blade
Charge/Wave 420hc Serrated Blade (Black Oxide)
Charge/Wave s30v Plain Edge Blade
Charge/Wave Damascus Plain Edge Blade
Charge/Wave Damascus Serrated Blade
Charge/Wave s35vn Super Steel Blade
Surge 420hc Plain Edge Blade
Surge 420hc Plain Edge Blade (Black Oxide)
Surge Damascus Plain Edge Blade
Step 2: Setup Your Work Area
If you have a vice, clamp one of the torx bits firmly in place as pictured. If you don't have a vice, you can use a c-clamp or vice grips to fix the bit to the edge of a table.
Step 3: Identify the Pin and the Screw
The tool is assembled with a pin (a screw head and a shaft that extend through the tool) and a screw that attaches on the other side. For the easiest dissassembly, you'll want to hold the pin still while rotating the screw. On black oxide tools, Leatherman uses the loctite liberally and this is a MUST, not a recommended.
On your Wave or Charge tool, the pin is usually on the side with the sharp blade (plain edge or serrated), and the screw is usually on the side with the other function (saw or file).
On your Surge tool, it's usually the other way around - the screw is on the side with the sharp blade and the pin is on the side with the opposite function (scissors or file/saw).
Step 4: Remove the Screw
Take your time with this step so that you don't strip out the screw. Especially on black oxide tools, the factory applied loctite can make the screw difficult to remove.
Step 5: Remove the Pin
Use your screwdriver to push the pin out through the tool.
Notes:
  • If you are working on a Surge tool and the screw was removed from above the blade, you do not need to remove the pin.
  • If the pin does not come out easily, try pinching the blade/file together while pushing out the pin. Sometimes the file and/or blade can bind up on the pin.
Step 6: Remove the Old Blade, Check Your Bushings, and Position the New Blade
Double check that your bushings have remained in place. There should be one brass bushing under each of the functions.
If your bushings fell out of place, you can use a small drop of oil to help hold them in place while you work on getting the pin re-inserted.
Try to align everything as closely as possible. You can use your screwdriver through the hole to help center everything up.
Step 7: Re-Insert the Pin
This is the tricky step - TAKE YOUR TIME! It should not require a large amount of force to reinsert the pin. Here are some pointers:
  • You can insert the pin in either direction. If you think you might be changing the blade again in the future, it's a good idea to insert the pin so that the screw will be above the blade. This way you won't need to mess with the pin the next time you change the blade.
  • Pinch the tool on either side of the pliers (the area marked in the photo and the matching area on the opposite side) to help align the hole. There are some springs that give tension to the opening and closing of the tools that need to be compressed for an easy fit.
  • Rotate the pin as you insert.
  • Check that your bushings are aligned properly.
Step 8: Apply Loctite and Insert Screw
You only need a small amount of loctite - the dot shown in the photo is sufficient.
Tighten the screw until the desired amount of tension in the blade is reached. We recommend screwing it in until tight and then unscrewing 1/4-1/2 rotation.
Step 9: Enjoy!
Your new blade should be easy to open, but should not have wobble or play in the blade. The locking mechanism should move into place easily when the blade is in the open position.
If you're having issues you can reach us at customer.support@texastoolcrafters.com. If you purchased your replacement blade through us, we're glad to swap the blade for you at no cost (just cover the shipping).
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
11 Discussions
BobKrohn
1 year ago
The steel thing that you clamp to the bit is a VISE not a VICE
AdamM193BobKrohn
Reply 1 year ago
A vise (American English) or vice (British English) is a mechanical apparatus used to secure an object to allow work to be performed on it.
HC30
1 year ago
To loose and remove the pivot screws for the first time you can use a cigar refillable butane small torch selling for 5 buck at a liquor store. Heat up the head of the screws on both sides of the pivot for about 10 second, that will melt down the Locktite making the screw very easy to remove.
nbrowning1
3 years ago
This works on the wingman model too.
Jobar007
3 years ago on Introduction
Locktite Red. I hope you never want to remove those screws again.
I like the idea of being able to remove the blade. This means that you can customize your leatherman however you want (laser engraving anyone?).
Thanks for the compliment on the blade! We produce them in our shop from USA forged Damascus steel. You can find the Wave/Charge sized one in the photos here:
http://txtoolcrafters.com/products/damascus-blade-kit-for-leatherman-wave-charge-plain-edge
We have several blades available for the Skeletool -- start with the following link:
http://txtoolcrafters.com/search?type=product&q=blade
tomatoskins
Such a great idea! Thanks for sharing and welcome to the community!
