How to Use an LCD Display - Arduino Tutorial
214,863
338
37
About: Arduino Tutorials by Codebender.cc Team
The LiquidCrystal library allows you to control LCD displays that are compatible with the Hitachi HD44780 driver. There are many of them out there, and you can usually find them by the 16-pin interface.
In this tutorial you will learn how to use LCD 16x2 display (and 20x4) with Arduino uno.
You will also learn how to use lcd.begin(), lcd.print() and lcd.setCursor() functions
So, let's get started!
Step 1: What You Will Need
For this tutorial you will need:
  • Arduino uno
  • Breadboard
  • LCD 16x2
  • Potentiometer (e.g. 4.7K)
Step 2: About the LCD Dislpay Pinout
The parallel interface consists of the following pins:
  • Power Supply pins (Vss/Vcc): Power the LCD
  • Contrast pin (Vo): Control the display contrast
  • Register Select (RS) pin: Controls where in the LCD's memory you're writing data to
  • Read/Write (R/W): Selects reading mode or writing mode
  • Enable pin: Enables writing to the registers
  • 8 data pins (D0 -D7): The states of these pins (high or low) are the bits that you're writing to a register when you write, or the values you're reading when you read.
  • Backlight (Bklt+ and BKlt-) pins: Turn on/off the LED backlight
The Hitachi-compatible LCDs can be controlled in two modes: 4-bit or 8-bit. The 4-bit mode requires seven I/O pins from the Arduino, while the 8-bit mode requires 11 pins.
For displaying text on the screen, you can do most everything in 4-bit mode, so in this tutorial we will use 4-bit mode.
Step 3: The Circuit
The connections are easy, see the image above with the breadboard circuit schematic.
Step 4: The Code
Here's the code, embedded using codebender!
The lcd.begin(16,2) command set up the LCD number of columns and rows. For example, if you have an LCD with 20 columns and 4 rows (20x4) you will have to change this to lcd.begin(20x4).
The lcd.print("--message--") command print a message to first column and row of lcd display. The "message" must have maximum length equal to lcd columns number. For example, for 16 columns display max length is equal with 16 and for 20 columns display max length is equal with 20.
The lcd.setCursor(0,1) command will set cursor to first column of second row. If you have an LCD 20x4 and you want to print a message to column five and third row you have to use: lcd.setCursor(4,2).
Try downloading the codebender plugin and clicking on the Run on Arduino button to program your Arduino with this sketch. And that's it, you've programmed your Arduino board!
You can keep playing with that by clicking the "Edit" button and start making your own modifications to the code. For example, try to change message on first and second row.
Step 5: Well Done!
You have successfully completed one more Arduino "How to" tutorial and you learned how to use an LCD display with Arduino uno.
I hope you liked this, let me know in the comments.
There will be more of them, so make sure to click Follow button!
8 People Made This Project!
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
37 Discussions
Surya Rathinakumar
Question 7 weeks ago on Step 4
I wrote the code and dumped into arduino.
But display does not show the alphabetic letters. It shows only dark boxes..
NMBH
3 months ago
Hello,
I have a small problem, i took the code from bellow, run it, there are no errors.. but still the display doesn't show anything ? did i missed something ? Please help.
/* Arduino Tutorial: Learn how to use an LCD 16x2 screen
More info: http://www.ardumotive.com/how-to-use-an-lcd-dislp... */
//Include LCD library
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Hello World!");
void loop() {
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
//Print a message to second line of LCD
lcd.print("Codebender");
i attached also a picture with the arduino.
Thank you in advance,
NMBH.
BremPaul4341woutermoors
Reply 4 months ago
If you are using an Arduino MEGA 2560 (or any other prossesor variants of the MEGA) you do need to use PWM pins and it will work fine.
AlinafeJ1
5 months ago
i have a problem. when i power my lcd only one line of it is working. i have tried to charge lcds but no charges. what should i do?
this-djsAlinafeJ1
Reply 5 months ago
have you used "lcd.setCursor(0, 1);" ?
HimanshiG3
5 months ago
why are only four data pins of lcd are used instead of all seven data pins
provashporia
6 months ago
I want to type characters from 4 cross 4 matrix keyboard and display on lcd.
CoolM3
Tip 8 months ago
Thanks working properly
yadea
Question 11 months ago
Hi,
How do I print a white box? I am planning to print white boxes to act like a progressbar.
Thank you.
chrisjlionelToreE
Reply 1 year ago
Then ToreE, how will you adjust the contrast?
ToreEchrisjlionel
Reply 1 year ago
I simply don't. Once I've found the most comfortable contrast level, I hardwire resistors with fixed levels. No need to adjust an optimal settinng. :)
codebender_ccrene14
Reply 3 years ago on Introduction
Hello, yes you will need one 10K pot. Why? Because with this you can adjust the contrast of yours display.
yash0011
2 years ago
it was great fun i did it
yash0011
2 years ago
what if i do not have the potentiometer
TimC211TimC211
Reply 2 years ago
Although I DID use an Arduino MEGA
