Huge Bubble Maker
114,061
277
48
Hello and welcome to my first instructable. This instructable is how to make a huge bubble maker, now i'm no english teacher so please excuse the grammatical errors. I have seen some youtube videos of these but never found one on how to make one, so i rednecked one and with some trail and error got one that work great. can be made in just a few minutes and for cheap!! i also found a bubble mix recipe that works out great
Step 1: Parts for the Bubble Maker
All you needs is
2 wooden dowel rods
cotton cord
2 eye screws
a few washers
For the dowel rods i used 3/8" by 48" long $0.84 each
The cotton cord is braided cotton cord 1/8"x45' $2.97
Eye screws are 1 1/16"  $2.99 for a pack of 12
washers i had lying around
So for around  $8.00 you have one and enough supplies to build more if you buy more dowel rods.Witch i recommend because when the other kids on the block see huge bubbles they come running, believe me.
Step 2: Assembly
1) screw the eye screws to one end of the dowel rods
2) cut two lengths of the cord one 70 inches the other 100 inches
3) slide a few washes to the middle of the long cord ( needed for weight ) i used 3 small ones
4) tie one one of both cords to one eye screw  and the other ends to the other screw
TA DA your done! what you should have now when you hold it up is a upside down triangle see how the washer hold down the bottom length of cord.
Step 3: The Mix
for the bubble mix the best i have found yet is as follows
12 cups of water
1 cup of cornstarch
1 cup of dish liquid ( dawn brand works best but any will do )
2 tablespoons of baking powder (not baking soda)
and the SECRET INGREDIENT  is a few oz. of  "personal liquid lubricant" yes i know this sounds funny but it has Glycerin in it that make the bubbles larger with out popping. You can buy the Glycerin at a hobby shop if you dont want to get the funny looks at the store buying the lube but it cost more the the lube.
mix it all together in a large bowl or bucket it will be cloudy and if it sits for awhile the cornstarch will for a paste in the bottom but stir it back up and it will still be good. i have keep the stuff for a week before and it was still good after stirring
Step 4: Now the MAGIC
Now all you got to do is go outside and holding the rope ends of the "wand" together dip all the rope into the mix and keeping it together lift out hold it up into the air a little and slowly open the "wand" ends so the rope forms the V and if you has a little wind it will blow it up for you, if no wind just start ti slowly walk backwards, If you want to close the bubble and watch it float away slowly close the "wand" ends to bring them together and it will close up and drift away. i like to keep it open and just see how long it can get before it pops ( have had some 30 footers myself ).
i also love the view you get from making them because you are the one who can look down the bubble from the inside,
made this for my kid but  she always has to say " dad its my turn " , who dont like huge bubbles????
In case you were wondering the redneck setup in the background is a pvc  " sprinkler " i made for her to play under and ride her bike through on hot days. cost for that $12.00
Well thanks for reading and leave a comment to let me know what you think.
    • Remix Contest
      Remix Contest
    • Sweet Treats Challenge
    • Organization Contest
    48 Discussions
    DebbiT4
    9 months ago
    How much is "a few ounces"? Three? After that it would be several right?
    nayrenna
    3 years ago
    Cool, will definitely try this :)
    Snibril
    5 years ago on Introduction
    I just followed your instructions and it worked perfectly.
    I had all the bits, barring the rope, lying around anyway, but instead of the washers and metal loops I tried using metal hooks. I pushed the open end through the rope and then used pliers to close them into loops to stop any slipping - seems to work ok and saves having metal-weighted rope swinging around when a small child's enthusiastically bubbling. :)
    Barb37
    6 years ago on Step 4
    Well! I think you are one very talented redneck! WELL DONE!
    lesliecr
    6 years ago on Introduction
    I followed your instructions to make this for a family reunion (all hardware supplies came fromMenards). Kids and adults alike enjoyed the results!
    crios42
    It was awesome. We ended up using glycerin and the bubbles were great. I the rods were only 24" and the cords were only 50" and 70". My kid have short little arms.
    dtackettcrios42
    Reply 6 years ago on Introduction
    glad to see they liked it, the best part of making these is seeing the kids enjoy themselves. thanks for the pictures.
    crios42
    Is there something about cotton cord that works well with giant bubble or would nylon or cotton/poly cord work? I'm having trouble finding a place that sells cotton cord, but nylon is in abundance.
    dtackettcrios42
    the cotton is better. nylon does not let the bubble mix "cling" to it as well home depot or any hardware store sells the cotton stuff
    taseriandtackett
    Do you know of any alternate places that might have the cotton cord? I visited both my local Lowe's and Home Depot, and almost all of the ropes and cords they have available is poly or nylon. I did find some cotton/poly blend, but it's much thinner than 1/8" so I doubt it'll work well.
    crios42taserian
    Tell me about it. I went to two different home depots and they both only had the cotton/poly mix. I finally went to my local Ace (I should have tried there first) and found it. It wasn't 1/8", it was 9/64" (which is slightly larger than 1/8) but that should be fine.
    outcasted
    The bubble mix has to have some time to "age" before it will work. Make it up a few days before you plan to use it.
    FitUW
    I tried your mix, but it doesn't work for me :( Do you use distilled water? Our tap water here is quite hard, might that be a problem? And I used pure glycerin since we had a small bottle right here. How much would you take? I even bought a cotton cord, we had only some PVC strings around...
    Damn it, I want huge bubbles now!! ;)
    dtackettFitUW
    if you have hard water i would buy a jug to use, and just a oz or two of glycerin. also dawn dish liquid works best i have found
    FitUWdtackett
    Well I live in Germany, I have to find out which brand works best here. Don't want to buy Dawn via the internet.
    mkog03
    Awesome Instructable!!
    Great job!
    AtlantaTerry
    What sort of container do you use to hold the Bubble Mix into which you dip the cords?
    How large is that container?
    We are going to have a neighborhood block party soon and I plan to build several of these to keep the little kids occupied.
    Thank you for the plans.
    dtackettAtlantaTerry
    i just bought a cheap flower container at the dollar store, you could use any large bowl or bucket.
