Hula Girl
dancing hula girl
Step 1: Concept
- Sketch out your concept idea
- Make a prototype out of paper
Step 2: Sketch Out Your Design
Step 3: Paint Your Sketch in Illustrator
To leaser cut
Program: Illustrator
420x720
Colormode:
RGB
Line size: 0,01mm
To cut: use color red
R:255
G:0
B:0
To engrave: use color black
R:0
G:0
B:0
Step 4: Laser Cutter
Make a hole in de bellybutten area so that you can put the servo motor thru it
Step 5: Tiki God
Download your Tiki Totems vector here: http://www.vecteezy.com/vector-art/83487-tiki-tote...
Step 6: Arduino and Servo Setup
See instructions:
Arduino code for lights:
https://www.arduino.cc/en/Tutorial/Blink
Arduino/servo code for skirt:
https://www.arduino.cc/en/Tutorial/Sweep
my version:
#include Servo myservo; // create servo object to control a servo // a maximum of eight servo objects can be created int pos = 0; // variable to store the servo position void setup() { myservo.attach(9); // attaches the servo on pin 9 to the servo object } void loop() { for(pos = 0; pos < 120; pos += 1) // goes from 0 degrees to 180 degrees { // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } for(pos = 120; pos>=0; pos-=1) // goes from 180 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } }
Step 7: End Results
After the setup of the Arduino and servo the next step is to
1) Put the servo true the bellybutten area of the hula girl.
2) And covering de servo bij attaching the hula skirt on it.
3)After that you kan just put de Arduino on and the skirt wil sweep from left to right.
See video link
    • Pocket Sized Contest
    • Weaving Challenge
      Weaving Challenge
    • Trash to Treasure
      Trash to Treasure
