Hydraulic Ram Pump
765,350
1,115
156
Pump water with no electricity, no gasoline, just gravity!
Sound crazy or impossible? Don't worry, it does obey the laws of physics, but I'll try to explain the operation later. This instructable shows how to build a fairly simple water pump that needs no energy input other than water flowing from a higher point to a lower point. Most of the pump is constructed from PVC, with a couple of bronze pieces thrown in for flavor. I was able to source all of the parts from a local hardware store (Lowes) for a bit under $100.
To function, the pump does require a reasonable amount of water that will drop at least 3'-5'. The level that the pump can raise water to depends on the water's head (total drop the water will make).
This design was worked out by Clemson University.
If you like what I've done, please take the time to give it a rating, and I'd love to hear your input. Thanks!
Step 1: Bill O' Materials
Before you can really do much, you've got to go out and buy some stuff. One of those sad facts of many projects. But if you want to build this (and it's a lot of fun to see it work), print out this list and head to the plumbing dept of your hardware store.
Materials for the Pump
  • 1-1/4" valve
  • 1-1/4" tee (buy two of these)
  • 1-1/4" union
  • 1-1/4" brass swing check valve
  • 1-1/4" spring check valve
  • 3/4" tee
  • 3/4" valve
  • 3/4" union
  • 1-1/4" x 3/4" bushing
  • 1/4" pipe cock
  • 100 psi gauge
  • 3/4" x 6" nipple
  • 4" x 1-1/4" bushing
  • 4" coupling
  • 4" x 24" PR160 PVC pipe
  • 4" PVC glue cap
  • 3/4" x 1/4" bushing
  • Short (4') section of 1-1/4" PVC pipe
  • Old Bicycle Innertube
This parts list comes directly from the Clemson website. I recommend you look there for help in identifying what each of the pieces look like, if you're unsure. I'm also not convinced that the 100 PSI gauge, or all of the things that make it possible, are necessary. This will probably drop the price a good bit, and I haven't found a need for it on my pump. The associated pieces are: 100 PSI gauge, 3/4" Tee, 3/4" x 1/4" bushing, the 1/4" pipe cock. Four things not needed. But have them if you like.
Connections Note Read through the instructable and understand all the pipe-fitting connections that will happen before buying materials. The store may not have exactly what you're looking for, and you may have to improvise. I wound up getting some different parts because my local store didn't have the exact parts I was looking for. This usually appears in the form of not having a threaded fitting, but having a smooth pipe connection, or vice versa. Not a problem, you can figure it out.
Installation Materials
  • Long section of 1-1/4" PVC ("drive pipe", connects pump to water supply)
  • Garden Hose (male end threads into 3/4" union, supplies pumped water)
  • Bricks, blocks, rocks to prop up and anchor pump
  • Shower Drain assembly (must be able to attach to 1-1/4" pipe, for attaching pipe to water supply)
Build Materials and Tools
  • PVC Primer (I used Oatey Purple Primer)
  • PVC Cement (Oatey again, just what they had)
  • Teflon Thread Tape
  • Hacksaw
  • Measuring Tape
  • Clamps
  • Pocket Knife
  • Lab gloves (keeps the chemicals on the pipe and off your hands)
  • Bike Pump (to inflate the innertube)
Step 2: Lay Out the Loot
Now that you've bought lots of goodies, lay them out on the table (or floor) so that you can start to see how the pump goes together. See the pictures for a visual on this.
You will have to cut the long sections of pipe into shorter sections to go between each of the fittings. This is discussed more in the next step.
Step 3: Cut Your Connecting Pipe Pieces
You need to connect each of these little units with some pipe, so set about cutting segments off of that stock 1-1/4" pipe with the hacksaw. They don't need to be long, just enough to reach all the way into each fitting, maybe with some space between. But not much!
Once these pieces are all cut, take your knife (or some sand paper) and try to smooth the inside edge of the pipe. Get all the burr off, clean it up, give it a nice bevel or rounded edge. The idea here is to make these as smooth as possible, to reduce the likelihood of cracks developing with the repeated pressure waves that occur inside the pipe. Clean up both ends, and make pieces to join all of the 1-1/4" fittings.
While you're at it, you might as well clean up the edges on the other sections of pipe, though it will be less critical for the other parts. Now that you've got all the connecting segments, you can actually test fit the first part of the pump together, just for fun.
Don't worry if the pipes seem rather tight when you're test fitting everything. The primer and cement help them go together when you do the real assembly.
Step 4: Fun With Chemicals
Grab your lab gloves, a clamp, primer, cement, two fittings and their connecting piece of pipe. Then head to a well ventilated space, because the primer and cement aren't precisely aromatherapy. At least not the good kind.
For those of you who haven't built things from PVC in the past, it isn't terribly difficult. The primer serves to clean off the PVC a little bit and gets it ready to really bond with the cement. The cement keeps everything together.
Most PVC chemical bottles have caps with little brushes attached to them. Take the cap off the primer, and carefully coat the outside face of the pipe, with a band about 2" wide beginning at the end. Take care not to drip the primer on anything that you don't want permanently purple. Once the pipe is coated, do the same for the inside of the fitting that you're planning on cementing up. Close up the primer bottle.
Open up the cement bottle, which should also have a little brush in it. With this brush, go over the areas that you painted with the primer. Don't rush, but you do want to get the pipes together before the cement dries up. You've got time though, so focus on getting a nice coating of cement on both pieces.
Once you've got cement where you want it (and hopefully only a little where you don't) fit the pipe into the fitting. It should slide in without too much resistance. When working on my pump, I felt that it was best to clamp up each piece after I had assembled it, that way the pipe couldn't slip back at all. It may not be necessary, but I figure it helps.
Most of the pieces go together in a fairly self-explanatory way, but there are a few things to note: on the spring check valve there is an arrow, and you will want this to point toward the main tee that will have the 4" pipe (air chamber) on it. This allows water to pass through toward the main tee, which you want. With the brass swing check valve, the arrow should point down toward the tee, and the main line of pipe.
On to the next step for order of assembly!
Step 5: Piece by Piece (Main Line)
I began at one end of the pump, with the 1-1/4" valve to the 1-1/4" union. You can choose to start with other pieces, but I found that setting up the main line gave me something easy to clamp up. After the 1-1/4" to 3/4" bushing is on this tee, you can glue up the end assembly separately, and then connect it to the main assembly with the threaded 3/4" pipe.
When connecting the threaded sections, make sure to wrap some teflon tape around the threads. This will help the operation along and prevent leaks at these joints.
Step 6: Piece by Piece (Pressure Chamber)
Now you need to put together the pressure chamber. Gather up your big pipe section, cap, adapter, bike tube, and bike pump. Using the pump, partially inflate the bike tube. Don't pump it up all the way, just enough that the tube is squishy. We need the air in the pressure chamber to act like a spring.
The bike tube prevents the pressure chamber from becoming waterlogged during operation. Air dissolves into water. It does so more readily at high pressure. (This is related to how commercially produced soft drinks are carbonated) The bike tube sequesters some of the air from ever contacting the water (in theory), and prevents all of the air from being carried out of the pressure chamber.
Stuff the bike tube down into the big pipe, a la image two. After this, cement on both ends, and clamp that sucker up. Once that's dried up, go ahead and glue this whole assembly to the pipe coming from the main tee.
Note on possible improvements / modifications:
Some may choose to omit the bike tube, and just drain the pump out every once in a while. That's totally possible. It's also possible to either mount a schrader valve onto the end cap of the pressure chamber to recharge it. Whatever suits your fancy, but this setup worked fine for me so far.
Step 7: Optional Pressure Gauge Assembly
If you want to use the pressure gauge, you will mount that after the main tee. Setup is pretty self explanatory. From top to bottom it goes: Gauge, pipecock, nipple, bushing, tee. Remember to wrap all threaded connections with teflon tape, and make sure you tighten them up well.
Installing this requires cutting the 3/4" x 6" pipe nipple in half, which creates two pieces, threaded on one end and smooth on the other, to go into the bottom arms of the tee. Cement these.
Step 8: The Last Piece (for the Pump Anyway...)
If you haven't done it already, install the brass swing check valve. Make sure that the flapper (I just like calling it that) is hanging down, when the pump is held upright (everything pointing upwards). The whole thing should just thread onto the bushing that you've cemented to the end of a 1-1/4" pipe. Simple enough.
After that, you may break out the flapper dress, cut your hair short, and swing dance the night away celebrating the reckless spirit of the Jazz Age (and completion of your pump). You party animal you.
Step 9: Pump Installation
Now that you've got a rather aggressive looking collection of PVC bits, it's time to make it do something. You'll need to attach the stand pipe (the long section of 1-1/4" pipe) to the 1-1/4" union with cement, and then decide how you want to hook the other end to your water source. My first method was a chopped up milk jug. Honestly, I just wanted to see this thing pump some water.
My later design was to mount a shower drain on the other end of the stand pipe, and fix that to a styrofoam cooler that I had cut a matching hole in. The cooler served as a collector for the pipe, and it all worked pretty well. In more permanent installation (to be completed in the coming spring) I'll attach this shower drain to a board that can be fixed in the higher water supply, and things will be good.
Gather up a garden hose, your stand pipe, and your pump, then drag all of this out to your waterfall or what have you. Bring a friend or two. They help in the setup, and maybe you can win the bet that "you can pump water above the source without electricity, gasoline, diesel, a bicycle, or a bucket while they watch."
At this point you can probably figure it all out on your own, but you'll need to get the water flowing down the stand pipe, which you've connected to the main pump, and then up through the swing check valve. On to the next step for theory of operation, troubleshooting and tuning.
When you install this permanently (or semi-permanently), you'll want to find a good place to anchor it to, probably not in the stream. Place it as low as possible, but keep in mind that if the stream were to flood and / or a tree to wash down it, it would take your nice little pump off with it.
Also, for those in the northern (or far southern) latitudes, you won't want this to be running during the winter. Water could potentially collect inside the pressure chamber and freeze, causing you problems (untimely death of pump). But experiment as you feel fit.
The video here is playable using Quicktime. Presently, you have to save it to your computer, and change the extension (bit after the long strange file name) from .tmp to .3gp. I'm sorry it's being difficult, maybe someday I'll set it up with an embedded player, but right now I'm short on time. It shows the pump working, with narration by yours truly. Gives you an idea of what it sounds like standing in the water right next to it, and also has a close up of the swing check valve working.
Step 10: Howsitdodat?
So here goes for the operation of the pump.
As the pump cycle begins, water flows down the stand pipe, and up through the swing check valve. Water begins to flow faster and faster around the flapper in the check valve, until friction draws the flapper up, slamming it closed. This causes a pressure spike in the pump body, as the water flowing down the stand pipe at some speed no longer has anywhere to go. This pressure is relieved by some of the water flowing across the spring check valve, over onto the pressure chamber side of the pump. Once past the swing check valve, it cannot return, and has to stay there. When the pressure difference across the spring check valve drops, the valve will close and water will stop flowing through it. The lower pressure will allow the swing check valve to open again, beginning the cycle all over again.
Troubleshooting
So what if this doesn't happen? Well, first things first, check and make sure that it's "on". That is to say, make sure both the 1-1/4" and 3/4" valves are in fact open.
Sometimes water will flow out of the swing check valve, then the valve will slam closed, but nothing will happen. If this occurs, tap on the flapper in the check valve to open it up again, and let the cycle begin again. In theory these pumps need some back pressure (coming from the pressure tank side) to operate, but I've never had any trouble getting mine going with just some basic tapping and fiddling.
Tuning
Now that it's working, can you make it work better? You'll find that there's a maximum height that the pump can deliver water to. Be patient when trying to find this, as it takes a little while for the pump to achieve the pressure required to raise the water up higher and higher. There are formulas that will tell you how high you can theoretically pump water based on the source water head. Feel free to look them up.
Tuning ram pumps mostly involves varying the water velocity that results in the swing check valve closing. A higher water velocity will generate a larger pressure spike, allowing you to pump to greater heights. But it will also cause a slower cycle, so you pump more slowly. If the valve closes at a lower water velocity, it will take less time for the water to reach that velocity, so the pump will cycle faster, and the water pumped faster, but you will not be able to pump as high. So that's the trade off. Keep in mind though, that this will work without interference 24 hours a day, so combining it with a holding tank, you can get a decent supply of water built up.
To tune this specific design, you take advantage of how gravity acts on the flapper. When the check valve is pointing straight up in the air, the full force of gravity holds the flapper down, so the water must flow past the flapper faster to generate enough drag to raise the full weight of the flapper. By rotating the pump about the main line, you put the flapper's degree of freedom at an angle to the force of gravity, so that less drag is required to move the flapper. You could work out all of this fairly easily with a bit of trig, but I feel it would serve you little use out in the field. Just play around with it, you should find a position that works well for your application.
No Power?
Well, no. This pump derives its power from the potential energy of the water uphill, and by wasting (not in a bad sense) the majority of the water that flows through the stand pipe. It only pumps a small fraction of the water that actually travels down that pipe. But that's fine if you have a stream already flowing down a hillside. Before, you weren't doing anything with all that potential / kinetic energy. Now you are. Hooray for you!
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
156 Discussions
Robbo59
2 months ago on Step 10
Hi further to my previous comment my husband ha finished making the ram pump. He made a few minor adjustments and it is working like a dream. It hasn't missed a beat. We installed anew 11,200 litre water tank and it filled it in just over 4 days. Your instructions and photos are invaluable and anyone that has the means to utilise water in this way, don't hesitate. It puts us another step closer in self sufficiency. Great work and thank you for sharing.
haboloobyRobbo59
Reply 2 months ago
That's great to hear! Good on you guys for building it and getting it working. If you have any other photos or tips (for examples what adjustments you had to make) that might help others with their builds, please share them. Keep up the good work!
Robbo59habolooby
Reply 2 months ago
Thank you for your reply, I see the water going into our water tank and I smile and marvel at your amazing invention.
Robbo59
3 months ago on Step 10
Thank you for sharing your amazing ram pump. Very impressed. We are using a Billabong brand which is Australian made. Having a few issues so we are going to give yours ago. Off to Bunnings tomorrow to get some fittings. They are an amazing concept and they sound good also. Thanks again
Mikepentecost
Question 10 months ago on Introduction
I live on a river that flows 4-5 mph. Will that suffice as creating enough pressure to make the pump work ?
johnpritch
Question 11 months ago on Introduction
why doe my pump start, work as expected BUT stop after 30mins.
Depressing the 'inlet' check valve starts it again and it continues merrily for another 30 mins before stopping again?
TimS398
11 months ago
What is the 4" Coupling in the parts list needed for? I don't see it in the finished build.
TimS398
11 months ago
Please update the supply list in order with more precise descriptions. The first time I went shopping with my phone, photos, and list in hand, it didn't go well. That was a while ago. I see now the "pool noodle" is removed. That was good, didn't cost much anyway! Hopefully I can do some returns and get what I need. Thank you...
ToddK49
can you use the flow of a high current creek as your inlet source for water or does it need to be an elevated water source.
funkdubius
1 year ago
Wondering if this might work to increase water pressure in a gravity fed home system?
ChrisD479
1 year ago
My Rampump is finally up but not working as it should. . Set up is as follows
Vertical fall is about 5meters
The life is about 35m
Diameter of Drive pipe is 90mm
Length of drains/drivepipe is about 20m
length of delivery pipe is 110m and 25mm diameter
Pump is 40mm
Air Pressure Chamber is 110mm in diameter and 2m in length.
It is cycling very fast which in another the article says is either because drive pipe is too short or waste valve isnt heavy enough. The water is pushing up delivery pipe but not far enough, it reaches about 100m with a small trickle, when extended with another 10m and 3m head it stops flowing.
DrewS71
1 year ago
So I swapped out the spring check valve for a swing a check valve in the best I get is that the swing check valve cycles through a couple of times but ultimately stays open. I have the swing check valve closest to the water source and before the pressure tube, is this correct or does it need to be after the pressure tube?
DrewS71
1 year ago
Hello,
I built this pump the same as yours as well but without the pressure gauge assembly and used a spring check valve instead of the swing check valve. The pump is being driven by an artesian well with a pipe providing about a 1 foot drop into the pump but i am having no luck getting it push even at a hoizontal level. Any suggestions?
Drew
haboloobyDrewS71
Reply 1 year ago
Hi Drew,
That's awesome you built the pump, and I'm sorry it isn't working yet! In terms of troubleshooting, is there any water flowing out from the waste port? That is, coming out of the spring check valve in place of the swing check?
I suspect that the issue may be with the spring check valve. In this design, water flows in the "wrong" direction through tthe brass check valve. This is permitted because gravity pulls the swinging portion down, opening the valve. This lets water flow through, developing the momentum to eventually create the pressure spike when the gate is dragged shut by the speed of the water.
Though I'm not certain, I believe in most spring style check valves a light spring keeps the valve closed position. The pressure of the spring is easily overcome by water flowing in the correct direction, but as soon as the pressure drops, the spring returns the valve to the closed position. Since it's already closed, any additional pressure in the "wrong" direction will only close the valve tighter.
If possible, I would recommend replacing the current "waste" spring check valve with a swing check valve, and see what happens. Keep us posted!
-H
DrewS71habolooby
Reply 1 year ago
Thanks H,
I ordered a swing check valve yesterday and have the spring boxed up to return. Will update when I it installed, thanks for the direction.
Steve8486
2 years ago
Hi
I have built a water ram the same as yours with 1-1/4 drive pipe and 3/4 supply pipe it works ok I need to get a bit more height out of delivery so I need to fine tune. I am using 1-1/4 poly drive pipe 25 metres long if I add 6.5 meter steel pipe Between poly pipe and pump will this help. What is the maximum length of drive pipe I can use.
Steve
SantiagoA8
2 years ago
Hi habolooby, thanks for the great post!
What flow of water did you achieve, for which delivery and supply heads and length of the delivery pipe?
Do you think scaling up (flow wise) would be cheaper per (l/s pumped) or more expensive? What do you think it would be more sensitive to?
Thanks in advance for your answer
kulpra
2 years ago
Hi, can you please share your e-mail ID here please? I want to ask question in private.
lehilty
3 years ago
Could a hydram be installed in a stream/river and use the velocity of the water vs creating fall in a drive pipe? I have land next to a river and would like to have an elevated tank.
haboloobylehilty
Reply 2 years ago
It might be possible depending on your river conditions, but as others have suggested, different pump designs may work better for you. The pump derives its energy from letting the water in the drive pipe develop a bit of inertia, then suddenly stopping the flow, and using that kinetic energy to force a bit of water up a pipe. So if the water in the river flows fast enough, it's possible that the pump would work. In general, it's easier to set the pump up using gravity to accelerate the water. There are some pretty cool pump designs out there specifically for rivers, so definitely check them out.
