Hydro Dip Painting
134,193
354
48
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Hydro Dipping is where paint resting on the surface of water is then transferred onto an object through dipping. It produces some psychedelic effects, is incredibly simple, and no two dips will ever look alike!
To hydro dip at home, all you need is acrylic spray paint and a large bath of water. Check out this quick video demonstration (direct link for those that can't see it):
Ready to give your next project a crazy paint job? Let's make!
Step 1: Prepare Your Wood
Just like any paint job, before hydro-dipping you need to prepare your work.
I dipped this natural wood skateboard, as it had a light coat of protective that was easy to sand away.
Using an 80 grit sandpaper I blasted through the clear protective coat and got down to the raw wood underneath. I then smoothed everything out with a 180 grit sandpaper to make everything smooth.
Step 2: Water Bath
Any large, deep container will work for dipping. Since we are using paint your container will also be partially painted during the process, it's best to use an older container so you don't risk ruining something nice.
Large, plastic containers can be inexpensively picked up at any big box home improvement store . You can even use it as a storage container after the paint dries, if you don't mind a splash of colour in your storage container.
Fill container with enough water to completely submerge the item you want to dip. For the skateboard I was dipping even full to the brim the container wasn't large enough, so i dipped it in two sections. Having the maximum dipping depth is desired.
Step 3: Add Handle to Dipped Item
If you want paint coverage over the entire item you are dipping you'll need to add a handle to your piece so the paint can reach all surfaces (minus the handle). A handle is better than your hand getting in the way, and depending on where your handle is mounted you can make the contact point between the handle and the work piece very small.
For this skateboard, I could attach the handle on the back of the board where the grip tape was - so there was no handle interference with the surface to be painted.
Step 4:
With the container of water ready you just need some acrylic spray paint colour combinations you want to apply. I had a few old spray paint cans that could be used up here, and almost any combination looks good with this technique.
Of course you're going to need to wear some protective gloves so you don't get paint all over your hands when you dip.
Step 5: Get Spraying
Here's where you can get really creative! Spray a generous amount of one colour directly onto the water, you can do one big spray in the middle of the container or a few smaller sprays around the surface. Different spray locations will produce different patterns. Don't overthink it though, the pattern will change quite a bit with each successive spray.
Paint will float on water. Switch up colours and give a few blasts of the new colour over the first.
Grab a spray can in each hand and keep spraying all over the water surface, creating all kinds of crazy patterns.
The best part about this process is that the spraying action does all the work creating the patterns. So all you have to do is keep spraying until you're happy with how it looks.
Step 6: Dip!
Now the fun part, dipping!
The paint will stick to whatever it comes in contact with. If you push your work into the water and through the paint it will stick to the first surface, you'll notice that sometimes the paint can even wrap around the piece and stick to the topside of the piece as well. Depending on the results you want to achieve this may be the look you want, if you only want to cover a certain side of your work then cover the side you don't want painted with petroleum jelly to inhibit the paint from sticking
Push the work into the water until it's completely submerged. You'll find different results depending on the angle on which you submerge your work, and the speed.
Step 7: Disturb Water Surface
If you don't want paint to cover the top of your work as you bring the piece out of the water you'll need to disturb the water and push away the paint to make a clear spot in the water.
You can shake the piece underwater to agitate the water surface, or push the paint away with your hand. Alternatively, you can leave the surface undisturbed and create another pattern on the topside of the piece as you extract it from the water.
Step 8: Larger Dips
For the skateboard dip I needed to dip one side, then reapply a few more blasts of spray paint onto the water and then re-dip the other side.
The paint swirls will overlap and won't be noticeable since the pattern is so chaotic.
Step 9: Clearing Paint
The paint is very sticky and should have no problem sticking to your dipped piece. This also means it will stick to the sides of the container, your hands, and anything else it comes in contact with. Use caution!
Step 10: Let Dry
After dipping your piece is going to be wet, both with paint and water from the bath.
Let your work dry completely before handling. I left my skateboard for about 2 hours before I could touch it and have it not feel tacky.
Step 11: Remove Handle + Protect
Once dry you can remove the handle.
To prevent the paint coming off it's wise to protect your work with a polyurethane spray
Apply the spray like with any other project, spraying about a foot away in even sweeps across entire piece. Allow to dry for about an hour before applying a second or third coat.
Step 12: Happy Dipping!
Now you know the basics of how to paint with hydro-dipping, you're ready to make all kinds of one of a kind dipped designs. Here's the skateboard I dipped from both sides to get good coverage. Can you tell where the overlap is?
There's loads of ways to take this to the next level, like making multiple dips with contrasting colours or partial dipping.
Have you done your own hydro-dipping? I want to see it!
Share a picture of your hydro-dip painting in your comment below and get a free 3-month Pro Membership!
7 People Made This Project!
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
48 Discussions
mikeasaurusArcticFrost22
Reply 24 days ago
You can skim off the paint, then water your plants with the waste water.
PegP7
Question 2 months ago
Would the dip method still work on glass? Specifically these light covers?
1 answer
spark master
2 years ago
It is called marbleizing , not "hydro dipping", it is an old process and your instructions are very nice.
The novelty of using the process on wood which typically is done very different. (faux finishing), I like the size of the project and that it is something other than paper.
I did this at home many years ago on Paper . I could not get what the people get in there video's, but I made some awesome papers just using corn starch water and paint. I literally took old combs as my tools and made some basic stuff.
I have added 3 video's there are many many more.
Please note these are all water based paint video's. Carrageenan is sea weed , non animal gelatin. It is parve /vegan, and some say it tastes terrible. I have never had it. So one day perhaps I will try it. I called a starch company to find the amounts needed to stiffen the water a bit. Also he uses an Alum solution to help the paper absorb the paint better. If you have unsized paper this may be skipable.
You can use oil based house paint using the techniques in this ancient art and do not need sizing or gelatin, for any surface.
Water process with oil based paint does have some real advantages. Duribility on hard objects or as a print on a T shirt,. Look up the Turkish art of marbleizing use latex paint and go right onto a tee shirt.
Italian gent
American Kid doing it very nicely
Another American Arteest
search youtube for a huge list including Japanese and Turkish versions of the art form.
Nice "structible Love that it was done on a skate board
HenleyLspark master
Reply 7 weeks ago
You should really not comment like this on someone else's tutorial. Because what you just posted was a tutorial in and of itself.
Besides that what you just showed was not with the guy just did! He dipped his item into water that has paint on top of it and yet what you described and linked to included tools and preparation that many people do not have on hand or time to acquire!
Overall very uppity and unnecessary comment.
XTLspark master
Reply 2 years ago
Methocel instead of carrageen is a good idea as its commonly used in cooking. Does the exact same job, used the same way. Better than water. Stabler paint on the surface.
Two main approaches to this - oil based on water(this instructable) or water based on methocel/carrageen....
mikeasaurusspark master
Reply 2 years ago
I suppose marbling is the technical term for this technique as hydro dipping is for applying printed graphics, however I think in most DIY circles you could call this hydro dipping and people would understand. Thanks for clarifying!
Even though I did this project, I had not made the connection on how they made paper using the same technique. Today I learned...
moosejaw23mikeasaurus
Reply 2 years ago
I agree. I see the roots of hydrodipping in marbling. Your process could be described as either a by-hand version of hydrodipping, or an evolution of marbling. Very cool tutorial! Thanks for putting that together!
Karen Dillon
2 months ago
I hydrodipped acrylic keychain blank first coating in a white flat primer. I seal them with a couple coats of epoxy. My problem is bubbles forming after the dip. I've tried lightly using a heat gun but not all the bubbles resolve. There isn't any bubbles on the water so I'm not sure why it adheres to the blank.
vincekerman
Question 7 months ago
I would like to know, does the polyurethane spray will come off if it is used on something that I touch a lot, I tried your tuto but didn't have the polyurethane spray and I used a protective spray that I use for my planes models but since I used on a phone case and that I use it a lot, paint started to come off. So I wonder if the polyurethane spray is strong ?
1 answer
mikeasaurusvincekerman
Reply 7 months ago
A few coats of polyurethane will protect the surface from handling, yes.
yashen
10 months ago
For anyone having issues with this, I highly recomend using primer before dipping as it will greatly help the paint to stick properly.
johnh5837
10 months ago on Introduction
The paint will start to glob up in about 15 seconds once you get it in the water so you have to be quick you can add ice which will give you twice as much time cold water very cold is what you're looking for remove the ice cubes before you dip . Doing it this way will give you a nice clean surface. Practice in a small container to find out how long do you have before the paint starts to glob up you can steal dip your project in the paint after it Globs up but you will not get a smooth surface
MichaelM1360
Question 1 year ago on Step 7
Have you tried using a few drops of dish soap to break the surface tension and clear the excess paint before pulling the object out? Not sure how well it would work....
BrodieS5
1 year ago
I Had Two Problems With the process. I was trying to dip an Altoids mint container (Who Knows Why?) and some Thermomourph things for my fish tank that I made and I found out that for you to dip multi-colored things, you have to spray paint it white first. Also I had a film-like thing cover the top and I was Wondering how do you prevent this?
LachlanD3
1 year ago
doesnt work for me :/ i keep getting this kinda film on the top, it dries on the top too quickly
Djjazzyjasper
2 years ago
did the paint get on the grip tape at all?
andygreyrider
2 years ago
Looks like Cheese and Tomato Pizza!
I nearly missed it in my Inbox because it's so convincing.
Thank you for teaching me this method.
MilanV16
2 years ago
Nice. Ibanez used to do a similar method on Jem guitars in the 80's. (http://www.ibanez.com/products/images/sig/pastmodels/JEM77_PMC.png)
