IKEA HACK: Easy Lamps
46,504
757
35
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Ikea has plenty of things that can be turned into attractive lights. I loved the industrial look of the stainless steel colander, and turning it into a lamp was a breeze with IKEA's inexpensive Hemma light socket set.
At $15, this easy project can be remixed and remade in countless ways.
Step 1: Supplies
I wanted to try a few different kinds of lights using this concept, so I grabbed a few types of stainless steel enclosures:
$5.00 HEMMA cord and light socket set
$9.99 ORDNING stainless steel colander
$3.00 VACKERT stainless steel candle holder (striped)
$3.00 VACKERT stainless steel candle holder (dotted)
Step 2: Drill Opening
Going at a low speed on a drill press and using plenty of lubricant, a 1-1/4" hole saw was used to create an opening in the bottom of the colander. The same process was repeated on the stainless steel candle holders.
Step 3: Disassemble Socket Set
The light socket set has a collar that threads into the neck of the socket. Unscrew the collar and feed the neck through the opening of the colander, then screw the collar back on the neck securing the socket to the colander. After, install a light bulb into the socket.
Repeat this same process with the stainless steel candle holders.
Step 4: Hang Lamps
To hang your lamp you'll need a ceiling hook or beam to drape the power cord through, then plug into the wall directly or into a power switch.
Let there be light!
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    35 Discussions
    david.claus.140
    2 years ago
    Hmm, looks like I stole your idea without knowing it. Just finished this today and now found your instructable while searching for a next project. :)
    mikeasaurusdavid.claus.140
    Reply 2 years ago
    Great ideas are hard to keep down! Looking good, and I love the light pattern on the ceiling.
    violetsmuse
    2 years ago
    If I don't have a drill press can I use something else? I reallylovethese!
    mikeasaurusvioletsmuse
    Reply 2 years ago
    A handheld power drill will also work. Make sure to secure your work before drilling, it can spin out as you drill break through.
    BartholomewH
    3 years ago on Introduction
    I love such IKEA furnishing hacks. Your final result looks awesome.
    Ave IKEA ah? :)
    RWSmith13
    4 years ago on Introduction
    You might want to try some Edison Bulbs in these for the look!
    twocvblokedoodlecraft
    Reply 4 years ago on Introduction
    You're always close to an ikea when you use their website (I like looking on there for things I really don't need, like their Tertial worklamps, got three of them cos they're so cheap and useful!!)... :D
    deshevo
    This type of colander, bigger, in our village the women use to wash cloths in local stream. It works very well. Not in winter.
    nanaof2
    These look great. I have used old wire baskets in one room I decorated for a family and used the replica bulbs to add more character. Great post, thank you for sharing.
    zappenfusen
    Useful where no ceiling box available though would look best with canopy and permanent install. Needs Led bulb! Great looking fixture as it easily adds to instead of distracts from decor. Gawd Awful Hampton Bay actually sells much worse for 4X your cost.
    robbadooz
    Okay! Good project but I am stuck as to connecting them to the ceiling if I want to replace the ceiling light. Can you give me a little schematic? Thanks.
    robbadoozmikeasaurus
    Thanks for getting back to me. I figured that what you were talking about were the plug ins but what if you got the fixtures for replacing a ceiling fixture.
    That's okay, though. I got a book on electrical wiring and I'm all set now. Thanks again for sharing your idea.
    The Rambler
    This is awesome. I have been on the lookout for metal bowls at thrift stores that I could cut designs into and turn into pendant lights but I never thought about repurposing things like candle holders and colanders.
    craftyv
    Love it. The industrial look appeals to me and this is a great hack.
