IKEA Chair Ergonomic Hack, 3D Printed
7,661
20
8
The problem to solve...
I've bought an inexpensive and confortable IKEA office chair, but doesn't have the correct height for my desk.
As you can see on the picture the position of my arms to the desk surface is not ergonomic. They should be flat over the desk surface.
Solution...
Design and 3D print a stand off to elevate the chair.
Supplies:
Step 1: Tools and Materials to Use
CAD Software
I've chosen the Fusion 360 from Autodesk. It's a easy to use but advanced software with cloud file sharing.
You can access my public design here: http://a360.co/1PtSGVW
Desktop 3D printer
I've used my beautiful BEETHEFIRST to 3D print the standoff.
Materials
  • PLA filament
  • 4x M8 140mm hexagonal head parcial thread screws (note: start designing after having the screws)
Tools
  • caliper rule
  • set square
Step 2: 3D Design: Preparation
Disassemble the chair
The base of the chair and the seat are connected by 4 screws.
Take a picture of the base
I've used this photo to help on my 3D design.
Start 3D modeling with "Fusion 360"
This is not intended to be a detailed tutorial about Modeling and 3D printing but I've written the sequence and the necessary keywords that can be googled (fusion 360 tutorial <keyword>). This way any one can learn from scratch how to model a part like this one, without previous knowledge on this tool.
Step 3: 3D Design: 1-Canvas
Insert image Canvas
I will use the photo taken from the chair base, to help trace the sketch lines.
  1. Insert/Attached Canvas
    1. Edit Canvas
      1. Canvas Opacity = 45
      2. Scale
Step 4: 3D Design: 2-Sketch
Create a 2D Sketch
  1. Sketch / Create Sketch
  2. Add Line (use set-square and caliper rule; consider one corner as a reference to all measures)
  3. Add Arc/3-Point Arc
  4. Add Sketch Dimensions
  5. Add Constraints
Note: It's normal that the design with the exact measures don't fit exactly the image from the photo. The photo will have some distortions.
Step 5: 3D Design: 3-Press Pull
Create a 3D Extrusion
  1. MODIFY: Press Pull
    1. Distance = 120mm (define height according to the screws you bought)
Step 6: 3D Design: 4-Cut Model
Cut Model
  1. MODIFY: Split Body
    1. Chose Plane YZ
Step 7: 3D Design: 5-Add Text
Add Text
  1. SKETCH: Create Sketch
  2. SKETCH: Text
Step 8: 3D Design: 6-Text Extrude and Fillet
    1. Distance = 1mm
  2. MODIFY: Fillet
    To the letters be perfectly 3D printed without using support material.
    1. Radius = 1mm
Step 9: 3D Design: 7-Save Body As Stl File
Save body as stl file
Finally we have a design (one Component) that have two Body. Each Body have to be saved as *.stl file to be 3D printed.
  1. Mouse Right Click over each Body
    1. Save as stl
Step 10: 3D Print: BEEsoft Import and Print
BEEsoft is the driver software for the 3D printer BEETHEFIRST.
  1. Drag and drop *.stl file over BEEsoft
  2. Rotate
    to put the part in proper position for printing.
  3. Click PRINT
    1. Resolution = Low (0,3mm layer heigh)
    2. Density = 10% (infill)
  4. hit Print button!
Step 11: 3D Print: BEETHEFIRST
These are the 2 parts 3D printed.
Step 12: Assemble and Test
Assembling was easy because the design was rigorous and everything fit perfectly.
The real test was done with 75Kg of my weight over the chair and I didn't heard nothing breaking! So I gave it a quality pass check!
That's all folks.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    8 Discussions
    aife
    3 years ago on Introduction
    Wouldn't it be possible to do it with a block of wood?
    What are the advantages of 3d printing it?
    fmendes75aife
    Reply 3 years ago on Introduction
    fmendes75 (author) 0 seconds agoReply
    Absolutely!
    A friend of mine did it in metal because he had access to a workshop with a lathe and have knowledge on use that tool.
    Unfortunately I don't have access to a a wood workshop.
    I would need several tools also. A saw and a drill.
    I would need to have big piece of wood (~120x120x120mm) or glue several boards.
    I would have some difficulties in making the holes also. They are long and they aren't concentric with the center of the piece. IKEA guys design it like that in order that the partes can be assembled in only one position.
    So, I think there are several different materials and tools to make the job, but using my BEETHEFIRST 3D printer and Fusion 360 software:
    I measured twice; Drew once; Print once; chose the color without having to make a finishing work; added a light piece; added embossed initials of my name with a beautiful text font and did it in my living room :)
    ritalobop
    3 years ago
    Sounds very useful! 3d printing really is fascinating... Great project!
