Ice Fishing Cleats
8,066
42
12
I made these due to the fact that I never have luck with the slip on/ strap on type ice cleats, they never work or fall off.
I have tried various techniques to maintaining footing while ice fishing without success until I tried this, they work excellant, but be warned, they are extreamly aggressive and will damage flooring so be carfull around the house oor the bait store.
Required items:
Heavy soled winter boots, I used winter insulated, water proof, logging boots
Hex head screws (the ones with the screwdriver slot work the best) of a length appropriate for the sole thickness of your boots, in this case I used 5/8" long
First lay out a pattern of your choosing, I tried to maintain the cleats on the portions of the sole that were already raised and in areas where pressure is applied when walking (toes, heals)
When putting in the screws, you can use a corless drill with the appropriate driver but I found that the screw kind of prenetrated too deep, by useing a hand driver or flat headed screwdriver they can be more accurately inserted to where the head of the screw rests firmly against the rubber.
Should the time come when you decide you no longer want the cleats in place they can be simply unscrewed with little more then superficial holes to the soles.
Hope this helps some fellow fisherman or other folks who have to work on the ice!
Supplies:
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
12 Discussions
JarrodL6
3 years ago
Great idea! As noted by another, it works great for running shoes as well!
buck2217
3 years ago on Introduction
History lesson -- Ernest Shackleton did this when on his rescue mission after being stranded at the Antarctic!
Ketzer
7 years ago on Introduction
Congratulations! You have reinvented the hobnailed boot.
GainEnergy
Very clever idea!!! Hate the icy when I walk...This is an idea I may try for myself ;) Thanks for sharing!
I hadn't thought about that, but yeah I'm sure they could, we use similar spikes called korkers for fishing in the rivers around here in summer
Takelababy
Great idea. My yard slopes so if we get freezing rain, away I go, downhill, in a slow uncontrollable slide. I read this just in time as we are to get freezing rain tomorrow so I'll be prepared this time. I've had to rely on the dog with his big claws to help me move when so icey.
jfree1
Great idea!! I like the fact of the screws being able to remove them if needed. You just gave me great ideas for the used boots in the thrift store!
chevhunter
i've done this for a couple years now and it works great. when we used to ride the river on our 4 wheelers we would put the screws in the lugs on the tires. man talk about traction!!!!!!!
