Ikea Aquascape on the Cheap $12
55,866
248
41
Quick and easy mini-aquascape for decoration. I became obsessed with the idea of an aquascape a few years ago. I built one with fish, a CO2 pump, and a lot of plants, but the snails took over, the fish had babies, and everything went nuts. That isn't a problem with this setup.
The idea of an aquascape is essentially an underwater garden that releases oxygen into the room. You can make them into mini-biospheres (ala Make 10), but this one won't require you to pick things out of a pond.
Step 1: Aquire the Materials
There are four things needed for this project. Two can be purchased at IKEA, but the same two can be acquired nearly anywhere.
You will need a container (glass jar, bottle, cup) about $6 for mine
Gravel (Ikea has small bags for $2, enough to make two of these)
Plant bulbs (I picked these up at Wal-Mart(BOO, HISS) for about $3
Water (I used distilled water for fear the chlorine mine kill the plants) $1
You can easily substitute anything but the bulbs. The water could be purified or treated water (for an aquarium). I would advise against pond water for the micro-organism count, and the smell. The distilled water won't have many of the same problems. I waited to post this until the plant had grown to see if there were any problems with the distilled water sucking the nutrients out of the plant, but I don't see any problems so far.
The taller the container, the more elegant the plants will look. Wal-Mart sells two types of plants, Aponogeton and Lily bulbs. The first is what I used, the second has a different color and shape of leaves. That is about the only difference, they will both work.
Growing from bulbs eliminates the chances of snail infestation. It will also make it easier to setup.
Step 2: Wash and Soak the Gravel
As with any aquarium/colored gravel, there will be a lot of dust. Use a strainer or cloth of wash the gravel and eliminate as much of the dust as you can. I originally tried to put soil beneath the gravel for the plants, but this did not work at all, and I wouldn't advise it. After the gravel has been cleaned, place a couple inches of it at the bottom of the container and fill just a bit above the gravel with distilled water.
This step may not be necessary, buy any chemical residue from the dye or bleach should leech into the water and can be poured off the next day. Shake the gravel/water every few hours and let stand for 24 hours (give or take) prior to completing the project
Step 3: Start the Bulbs
This step will take you less time than it did to read it. Take a glass (not your jar) and fill it with a couple inches of distilled water. Place your bulbs in the glass and set it aside. There is no reason to add all of the bulbs to the aquascape if some of them won't sprout!
In a few days, you'll see the sprout start to work its way out. When this happens, it's time to transplant it to the gravel.
Step 4: Transplant the Bulbs and Enjoy
Fill the display jars with the cleaned gravel and just a bit of distilled water. Remember that you want to be able to manipulate the bulb into the right position prior to filling the jar. For this, I used bamboo skewers(for kabobs) that reach just below the top of the gravel.
Carve a shallow trench in the gravel and orient the bulb so the shoot it up. After the shoot grows a little taller, you can fill in the trench over the majority of the bulb.
It won't quite look like a real aquascape, but it will add a touch of elegance to your living room or desk. I will probably add a couple shrimp or fish to my aquascape, and maybe give the real deal another try. I don't know for certain excess oxygen will bleed into the room, but it makes a nice excuse for assembling such a simple and pretty display.
If I could do it over, I'd like to use a taller container. I'm sure at a 99 cents store or somewhere else I could find a vase or jar that meets the order, but IKEA is so darn convenient.
Enjoy!
    • Organization Contest
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest
      Paper Contest
    41 Discussions
    BartholomewH
    3 years ago on Introduction
    How can IKEA offer SO MUCH stuff you could use in SO MANY ways!
    Good hack there! Does has the looks
    cwellems
    9 years ago on Introduction
    You seem to have more experience growing aquatic plants than I do, so maybe you can help me. I have a year-old tank with a variety of plants and fish. For the first six months the plants grew like crazy, and then eventually everything slowed down. The plants still grew, but nothing took over the tank. In the last two months, though, all the plants are dyeing. Only duckweed grows -minimally. Even algae isn't growing.
    My lighting is three 24" 20-watt bulbs, and I use Flourish Iron fertilizer. Any suggestions as to the cause of this problem?
    Alaska_Fansoncwellems
    It can be a hundred different things. Too much light, not enough nutrients, not enough water changes, wrong ph, etc etc etc. If you have too much light in your tank without enough nutrients, the plants will struggle to grow with whatever they have on hand. Contrary to popular belief, fish poop isn't the only thing plants need. ;) With all the light you have, a plant is able to photosynthesize like it's supposed to as long as it has food AND CO2. Fish only produce small amounts of CO2. Your filter helps remove it by oxygenating the water.
    Also, if you choose plants that grow from bulbs, that can be part of the problem. The reason a plant grows a bulb is to store nutrients for a later date. A lot of the time, an aquatic plant may only be under water for 6 months at a time and the rest of the year be completely dry. The plant has a kind of "internal clock" that tells is to start dying off for the start of a dry season. And if you don't supply the nutrients a bulb needs in the long run, it will use itself up completely and the plant then dies.
    Something else can be the plants themselves. If you pick out plants that are picky, they might do alright at first, but in the long run, they end up just completely horrible. I kept jungle val for a long time, but it kept dying off. I found out it was a calcium defficiency. A plant. Needing calcium supplements. Yikes. :P
    You can also be adding too much iron. You use Flourish, so instead of iron, go out and grab some flourish EXCEL(which is an organic CO2 made from liquid that you just pour in) and get yourself some Flourish root tabs. That helps put a lot of basic must-haves back at the plant's disposal. This was long winded of me. :P Try this site if you're still interested:
    aquaticplantcentral.com GREAT site with friendly people. :) Good luck!
    sleighbedguycwellems
    I'm none too experienced when it comes to growing anything, but the basics are generally pretty simple. If nothing is growing and you have not changed anything else, it stands to reason something is out of whack. Perhaps too much fertilizer is shocking the plants, there is too little diffused CO2, or the lights may be too intense for the plants. It would stand to reason the best approach may be replacing a larger portion of the water, and laying off the fertilizer for a while. That and temporarily putting a bubbler or CO2 pump might be worthwhile. Again, I'm not an expert at all, but if the plants started wonderfully and have steadily dropped off and are now struggling...I have to assume the problem has built up for a long time. If the plants have not been able to process the fertilizer, I'd imagine they would be shocked just as houseplants are. It is at least a good starting point...
    sleighbedguyxVAGUE
    Z Sun...The aquascapes sit above my sink which gets a little indirect light everyday. One side does better than the other, so I switch them occasionally. Be careful with using direct sunlight due to algae. I don't know if the distilled water limits that issue, I suppose it can be tried and altered as necessary. It has never been a problem for me. Anyone have any knowledge of algae and growing in distilled water?
    NeilLizard
    I have done this before. I took a clear glass bottle and bought an aquatic plant at petco. I planted the plant in some old aquarium gravel(which I cleaned)and added water. I just dont know if the aquatic plants will survive in the lower water pressure compared to that of an aquarium.
    Do you have to add any sort of special nutrients to the water to keep the plant healthy? Or does the plant just absorb everything it needs from the water anyway?
    As long as the jar is not completely closed off from the air, everything seems to be alright. The aquascape recycles the majority of the nutrients, so little is lost. Mine has been growing strong for nearly a year.
    That's good to know, thanks! So it really is low-maintenance! Cool! I just wondered with you using distilled water, as I know that distilling removes a lot of the minerals, etc. (I think that's why doctors don't recommend drinking it for long periods of time.) Thanks again! :)
    Miss World
    thank you for the cool instructable :) been curious on how to make those, now I might just give it a try!
    Gnome
    11 years ago on Introduction
    Great instructable! Could you perhaps give us a link to the original aquascape's instructions or info? I'd love to make one for a fish! I'd try to keep it simple though :)
    sleighbedguyGnome
    Reply 11 years ago on Introduction
    I have been unable to find the site for years! I know it is on the Amateur Telescope Making webring. It was a private site, and a link I accidentally clicked on within his site. All I can tell you is it was a site about an 8" Dobsonian telescope build. There isn't much to it though, and there are a lot of sites out there about it. There are websites that sell plants, plans to build CO2 injectors and everything in between.
    ironsmitersleighbedguy
    CO2 injectors are SUPER simple. get a 2 liter soda bottle, fill with sugar water, toss in some yeast(bread, beer and wine all work just dandy). Drill a hole in the cap, hot-glue an air tube into it, and run the tube into the bottom of your aquarium. The happy little yeasties will go on producing CO2 for weeks at a time. If the sugar water stops bubbling, or the water goes green, unscrew the cap, toss the bottle, and start with a fresh 2-liter. If the soda is cheap enough, you can add the yeast straight to it!
    Gnomeironsmiter
    Cool! So you could just dump beer in a container filled with sugar water and the yeast will produce CO2? Have you tried this before? It looks too simple to be true!
    ironsmiterGnome
    sorry, it's not that simple, unless you brew your own beer. in which case, just hook a hose to your air-lock and run the other end into the tank with all the plants. The issue with using bottled beer as your source of yeast is, every commercial beer I know of has been pasturized. AKA, they killed off all the swimmies. the good ones, AND the bad ones. "fresh" homebrew would work, but you're better off drinking your beer, and getting a 25cent packet of yeast from the grocery store.
    bobiseironsmiter
    I think that yeasts FOR bread or beer and wine was intended, I know I was thinking that using beer or wine as a starter was advised, the comment was oddly worded... We use potassium metabisulfate to kill off yeast before bottling our wine.
