Illusion Kidnapped Costume
2,560
35
5
About: My motivation for anything in life is my son. I am always making, crafting, and learning new skills along side him. I want to show him that I can do anything I put my mind to, and so can he.
Call it Hansel, call it Gretel, add some adults and call it Hocus Pocus! This illusion costume got a lot of praise and alot of laughs when ppl finally wrapped their brain around what they were looking at.
Update: A lot of houses gave him double the candy when trick or treating, even after he admitted it was just him.
Supplies:
Step 1: Gather Supplies Needed
I started this step a few months early so prices were a bit better.
What I needed:
Witchy looking mask (old man mask)
Classic witch costume
long black gloves
pvc pipe and fittings
zip ties
paper to stuff dummy with
duct tape
2 turtle necks
silver spray paint
child's pants
child's shoes
1 regular tshirt
1 too big tshirt
2 shoulder straps from gym bags
power drill
Step 2: Create Dummy
I used my son as the mold for the dummy. You can use anyone as long as the witch costume will fit them.
1. Put turtle neck on model
2. Not too tightly wrap model in duct tape (arms, torso, neck)
3. Cut model out of duct tape by going up the back and down the arms carefully. You'll be cutting through both the tape and the turtle neck.
4. After it has been removed from your model, tape the cut lines closed and stuff with paper.
5. Stuff the hands of then long black gloves with paper and shape to look semi-realistic.
6. Slide the gloves around the dummy arms and duct tape in place
7. Duct tape a foam head into place (we actually used to a cosmetology head my sister had, but a foam head would be lighter)
8. Put the 2nd turtle neck on the dummy to cover duct tape
9. Dress dummy in witches costume
10. Put mask on foam head
11. I used a hot glue gun to glue witches hat into place
I got this section more or less from https://www.instructables.com/id/Kidnapped-Mermaid-Costume/step2/Make-the-Pirate/
Step 3: Build PVC Cage
This step will depend on the height of the wearer. You want the bottom of the cage to sit right below the hips and the top of the cage should be tall enough so the wearer's head doesn't stick out. I do wish we had made this a bit narrower. We omitted the top of the cage due to weight concerns.
The back of the cage is left open to allow for the illusion.
Don't glue into place yet, the bottom bars will need to pass through the witch's skirt
We build a stand to support the dummy onto the back of the cage with more pvc. No need to paint that
Drill holes in the pvc before painting. Drill holes where the hands will be attached with zip ties. Also drill holes in the back corners where the straps will be attached via zip ties. I drilled one on each side of each back corner to help with balance.
Spray paint cage
Step 4: Finishing Touches
Get dummy situated on the stand
Run zip ties through the bottom corner holes to make loops.
Cut a slit in the front of the witch's skirt to allow wearer to slip through.
Cut two small slits in the sides of the skirt to allow cage to pass through. Take the pipe out of the fitting, slide through skirt and reattach on each side. I then glued the pipes in place so the dummy wouldn't gradually shift backward.
Cut two small slits in the palm of each glove, just large enough to allow zip ties to pass through. Attach to cage via pre-drilled holes.
Cut out cardboard fitting for the fake legs to sit on.
I shaped the legs out of rolled paper and duct tape, then slid into the shoes and jeans.
Step 5: Getting Into the Costume
For my son, the bars were far enough apart he could crawl through.
Start out wearing long sleeve shirt or sweatshirt for colder nights
He puts his feet through the slit in the skirt, pulls it up and sits down.
I help him attach the straps over his shoulders and cross in the back, attaching to the zip ties in the bottom back corners.
Stand up
Slide on shoes (I had him wear his black rain boots)
He puts on a 2nd, larger shirt to cover the straps.
Place cardboard cutout in bottom of cage
arrange legs on cardboard.
Enjoy all the feedback :)
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    5 Discussions
    Anirudh Ralhan
    2 years ago
    Wow!!! Amazing creativity. Will someone please call 911??
    parisusa
    2 years ago
    This is totally sick but funny. Your son's expression is perfect. I have seen a similar illusion costume as a mermaid/pirate. Very cute!
    Swansong
    2 years ago
    This is hilarious! XD That's awesome :)
