Indoor Firewood Rack
7,671
39
11
About: I've found that I like the challenge of making stuff with reclaimed wood.
After a winter of using a plastic box, then a cardboard box when the plastic one broke, I decided I wanted something that held more wood in a similar amount of floor space, was more durable than a plastic box, and looked better than a cardboard box. While checking instructibles.com for ideas I found a few outdoor firewood racks, but nothing for indoor firewood storage. Thus, I present the finished project as my first posting to this site.
Most times that I go to the local dump I check the wood pile for lumber and other useful bits of wood. I endeavored to challenge my creativity by staying within the limits of my recycled lumber supply (Sounds better than "I didn't want to spend money if I could help it.").
The side pieces are cut from a 2" x 10" of some type of close-grained wood.
The bottom braces are 2" x 6" with grooves to fit the 2" x 10"s. Eight 3" screws (also recycled) hold them together.
The shelf (bottom of kindling box) is a 1" x 10", held in place (and pretty tightly at that) with my first attempt at mortise and tenon joinery with the 2" x 10"s. It also happened to be slightly wider than the side pieces and came almost flush with the slats on the front and back of the box.
Four slats (approx. 1/4" x 2 1/2") from some type of shelving unit make up the front and back of the kindling box (2 on each side). 1" screws hold the slats to the 2" x 10"s.
None of the wood had been treated or finished so far as I could tell. Fasteners of varying shapes and sizes (nails, screws, and staples) had to be removed from all but the 1" x 10". The 2" x 10" pieces were weathered enough that the grain was separating, so they were shaved using a table saw, then sanded smooth. All the other pieces required sanding to remove weathering or dirt. Corners that would be exposed were rounded with a chisel and sander. I finished it all with a water-based polyurethane.
So far as construction is concerned, I think the images show enough (my cop-out for "I didn't take any pictures during the build."). I intentionally left out length dimensions as I don't recall them and my tape is in the garage as I write this. I can say that I was going for roughly 2' x 2' x 1' of storage space and didn't get too far off. I am sure someone wanting to build something similar will have their own size requirements.
Supplies:
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
11 Discussions
StanP24
1 year ago
I guess the reason the 1x10 was wider than the 2x10's was because the 2x10's were shaved with a table saw. It looks like a good project, and I will try it soon.
Iliasp
4 years ago on Introduction
Congratulations, very simple and clever. It can be even better, adding swivel casters (wheels) at the bottom. Thanks for the idea..!
Dustin Rogers
5 years ago
I have some 2x10's left over from a project that I was wondering what I was going to use them for. This is my answer. Thanks for the idea.
lilchumy
5 years ago
At first I thought you meant the store "the dump" almost asked for wood from there garbage. Lol
Very nice, If I ever get around to fitting the wood burning stove we keep talking about I may borrow this idea.
