Industrial Style Wall Sconces
32,732
451
56
About: My name is Zack, I'm a full time craftsman. I am incredibly fortunate to be able to do what I love full time--turning ideas into reality. I specialize in commissioned projects, including furniture, sculpture...
Hey!
I was recently commissioned by a local brewery(Escape Brewing) to design and produce some wall lighting for their new expansion. I decided to go with an industrial theme with some medieval styling cues.
This was hands down one of my personal favorite builds as it required so many disciplines: metal fabrication, woodworking, blacksmithing, and some simple electrical work.
Since I didn't want to overwhelm you all with too many images, some of the steps in the video aren't included in the images. If you are curious about the Wine barrel chandeliers I made for the same brewery or any of my other work, please feel free to check out & subscribe to my DIY YouTube channel ZH Fabrications.
Thank you!
Zack
Supplies:
Step 1: Cutting the Frame
The first step was to cut out the frame. The frame is made of 1"x1"x1/8" angle iron.
I used a DeWalt cold saw for this. I truly believe this to be the most deafening tool one can own!
Step 2: Welding the Frame
With the pieces for the frame cut, the next step was to weld the frame together. I'm using a Lincoln 140C MIG welder.
Step 3: De-burring the Socket Housings
After cutting out some 2x3 square tubing(Cold saw again), I'm de-burring the holes I drilled which will later accept the bulb.
Step 4: Constructing the Panel
The next step was to cut out the panel, which will set inside the frame. I'm cutting a piece of 2x12 Southern Yellow Pine.
Step 5: Chamfering the Edges
With the panels cut, I'm chamfering the edges so there will be a visible & rustic joint when the panels are glued together--without this the panel would resemble laminated plywood.
Step 6: Fire!
I also torched the chamfer to heighten the contrast once the piece is assembled and stained.
Step 7: Mock-up
With the panel glued up, and routed for the socket frame--this is the mockup assembly.
I used a DeWalt plunge router on the panel to accept the socket frame
Step 8: Staining & Finishing
I stained the panels using a dark walnut gel stain in the chamfers and a slightly lighter gel stain (Candelight) for the entire panel. Here I'm spraying a water based polyurethane clear coat.
Step 9: Final Mock-up
Getting closer, this is the final mock-up with the blackened metal patina, and stained & clear coated panels.
Step 10: Forging Nails
For the final medieval touch, I really wanted to use some hand forged nails--so I made a bunch of them! This was a lot of work, but it was also a fun process, and beating red hot steel always makes you feel awesome.
Step 11: Nails!
Nails!
Step 12: Wire It Up!
Wiring up & installing the sockets.
Step 13: It's Alive!
Victory!
Step 14: Installed
And the last step was to celebrate the instal with a free victory beer!
If you liked this and would like to support me, I invite you to subscribe to my YouTube channel, it really helps me out.
I look forward to your questions and comments.
Here is a list of the tools and products I used to make these:
Bulb-T9 Long
DeWalt DW872 cold saw
DeWalt DWE4011 Angle Grinder
Dewalt DW618 plunge/fixed base router
Lincoln 140C Mig Welder
General Finishes Antique Walnut Gel Stain
General Finishes Candlelight Gel Stain
General Finishes High Performance Top Coat(Gloss)
Zack
ZH Fabrications
Make it Glow Contest 2016
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    56 Discussions
    bassam704
    2 years ago
    Beautifullllllll!!!!!
    tranzit1260
    2 years ago
    Зак спасибо за ответ !!! Теперь я сделаю это !!! Отлично !
    wile222
    2 years ago
    Would you mind sharing your source for your light sockets?
    ZH Fabricationswile222
    Reply 2 years ago
    Hey, sorry your message slipped under my radar. Here is a link to the sockets I used: http://amzn.to/2lwnI6c
    tranzit1260
    2 years ago
    Зак , добрый день ! Где покупали патрон для лампы . Мне такой не найти (((
    Bernie40
    2 years ago
    Great work and good video! A pleasure to watch and to learn, thank's a lot :)
    PPDB33
    2 years ago
    I must say... I saw this in my email and thought, "Perfect, just what I'm looking for right now! Shouldn't be too hard." Ha!!! I can't believe your skill from welding to finishing, and when you got to the part of iron working and forging your own nails, I literally said, "Shut Up!!!" And to be doing it from your garage! I know you must be underpaid.
    You are a walking talent! Great video!
    ZH FabricationsPPDB33
    Reply 2 years ago
    Hah, thank you! Yeah, I just set up a Patreon and I'm still working on the underpaid part, but I think things are just going to keep getting better.
    Thanks again for the compliments!
    bzmaker
    2 years ago
    That is a sweet project, Zack! How do you do the blackened metal patina?
    ZH Fabricationsbzmaker
    Reply 2 years ago
    Thanks, I use a product called "Black Magic" By Sculpt Nouveau, I will actually be giving some away on a huge giveaway I have coming up on my youtube channel
