Infinity Illusion Mirror Clock
1,462
39
About: Experiments, DIY, Life Hacks YouTube channel
Create the illusion of infinity thanks to mirrors and leds.
Step 1: Material
For this instructable you will need:
  • 1 Clock
  • 1 Round mirror - The diameter must be the same than the inner diameter of the clock
  • Some One way mirror film
  • 1 Led strip - It can be either fixed color or RGB
  • 1 Glass and mirror drill bit
  • Drill
  • Screw driver
  • Sponge and water
Step 2: Disassemble the Clock
Remove back screws, the top glass and clock hands.
Keep them safe as they will be used later.
Step 3: Drill the Mirror
Drill the mirror in the center.
This step have to be done with caution as mirrors are fragile.
Use a specific glass/mirror bit drill, with a standard drill you have no chance to make a correct hole.
Put some water on the glass to low down temperature and use the drill with low speed.
It took me an hour to drill the hole.
Step 4: Place the Mirror and LED Strip
Make an hole on the clock side big enough to let the LED strip go through.
Place the mirror inside the clock.
Cut the LED strip with dimension the perimeter of the inner clock circle.
Stick the LED strip in the inside of the clock.
Step 5: Replace Clock Hands
Put back in the clock mechanism an clock hands.
Step 6: Prepare the One Way Mirror
Cut the one way mirror film using the dimension of the top glass you kept from step 2.
Spray or sponge some water on the glass and apply the mirror film.
The film is easier to apply if you add some soap in the water.
Step 7: Reassemble the Clock
Put back the top glass and screws.
Make sure the LED strip alimentation cable comes out from the clock.
Step 8: Light on LEDs
Power on the LED strip to discover the infinity illusion.
Step 9: Rainbow Effect
If you use a RGB Led strip you will be able to choose your clock color.
I have chosen blue for the clock in my house.
Step 10:
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    2 Discussions
    iminthebathroom
    10 months ago
    Wow, great video instructable and follow-up step by step.
