Infinity Mirror Candle Holder
21,348
190
17
Hello everyone!
In this instructable I will be showing you how I made this awesome infinity mirror candle holder. Everyone loves infinity mirrors and we all want them, but for some people is not easy to work with LEDs and electricity and thats the reason I came up with this build.
Tools And Materials:
  • Wood (any kind, I used mahogany)
  • Mirror (30 x 15 cm)
  • One way mirror (30 x 15 cm)
  • Wood glue
  • Miter saw
  • Circular saw (You can also use table saw or wood shaper if you have one)
  • Clamps
  • Band saw
  • Planer
Here is a video of the building process, you can watch it if you like to get a better idea what is going on!
Supplies:
Step 1: Repairing the Wood
This first step is actually the most difficult for people who do not have a planer or jointer. But you can go to your local woodworking workshop and ask them to make this for you.
So the dimensions for this piece of wood should be (8 x 1.8 x 120 cm)
Step 2: The Grooves
At this point you want to make two grooves on the wood for the mirrors to fit in. You can do this using your table saw or if you do not have one you can use a circular saw like I did. Those grooves must be 1 cm in from each side 5 mm deep and must be wide enough to hold your mirrors. My mirrors thickness was 3mm so I did a 3.5mm wide slot to be easy for me to slide them in or out.
Step 3: Bottom Part and Sides
Set your miter saw at 45 degrees angle and cut out a 32 cm long piece making sure you have bevels on both edges.This is going to be the bottom part of your candle holder. Then cut out two more pieces 17 cm long again with bevels on both edges.
Step 4: Glue Time
Now just use some wood glue and clamps to glue those pieces together as shown in the pictures.
Step 5: Band Saw
On your band saw cut two strips of wood 18 mm wide to secure the mirrors.
Step 6: Assembly
From the two strips of wood cut out two 32 cm long pieces. Slide the regular mirror into the first slot making sure it faces in and secure it by gluing the strip on the top.
Step 7: Front Mirror
Apply some silicone inside the groove on the wooden strip an slide your one way mirror in. The mirror side must also be facing in.
Step 8: Finishing
Apply two coats of clear lacquer and let it dry.
Step 9: Its All Done!!
Place three candles in and slide the front mirror in the front slot. Enjoy!
Thank you for stopping by. If you have any questions please let me know, and please forgive me for my bad English!
Glass Challenge 2017
Runner Up in the
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    17 Discussions
    eralonSisters Undercover
    Reply 1 year ago
    What's not worthy here is Sisters Undercover's negativity. This is a place to be inspired, not for bashing other people's work. Remember that if you ever publish one of your own works. FS Woodworking, great job on this! I like the spin on it, using natural light instead of something electrical-based.
    Craftcorner
    2 years ago
    Wow great idea!
    Please check out my instructables and comment your feedback! :
    https://www.instructables.com/id/LED-Glass-Bottle-Chimes/
    DougM77
    2 years ago
    on step 5 you recommend using a band saw, I don't have one what else could be used?
    fs woodworkingDougM77
    Reply 2 years ago
    Hi, you can use a jig saw,hand saw or a circular saw.All work great.
    bethmwl
    2 years ago
    Very unique design. Do the candles stay lit in their hole?
    TimB2
    2 years ago
    Does the candle power or wattage increase with this device? In other words would a room become brighter than it would with just three candles?
    fs woodworkingTimB2
    Reply 2 years ago
    No, the light from the candles is trapped between the mirrors. Actually just three candles are brighter than three candles in this candle holder.
    cestymour
    2 years ago
    Very good !
    Just an idea of potential improvment: You could add 2 mirrors, one the right side and one on the left side to multiply the infinite effect.
    whatforcestymour
    Reply 2 years ago
    I had a similar idea to this, except I was using a square jar instead of a nice holder for multiple candles. I just wrapped some privacy mirror film around the jar and stuck a tea candle inside. Unfortunately, the sides were somewhat rounded, and not completely even on the inside, so it didn't really result in an infinity mirror. Another downside was that both sides are translucent, so it wouldn't get as many reflections. However, you could definitely accomplish the desired effect with 2 mirrors and 2 panes of glass with the one-way film.
