Infinity Mirror Clock Making
43,962
756
41
Making an infinity mirror clock is a very fun proccess. Anybody can do it and once you finish it you will be amazed!
So lets get started!
Here is a video step by step:
What you will need:
1. An old wall clock, the rim diameter of mine was 30cm
2. A round mirror with a 10mm hole right in the center, (The diameter here must be smaller than the rim diameter of the clock becuse you will have to fit the mirror inside the rim)
3. A round one way mirror the same diameter with the other mirror
4. Some strips of wood, or anything that is bendable and can be used as a spacer between the two mirrors
5. Led Strip
6. Some wire
7. A power adapter for the led strip (mine was 12Volt DC 50Watt)
Supplies:
Step 1: Disassemble the Old Clock and Prepare the Rim
Disassemble the old clock, take the rim and drill an 8mm hole 1,5cm from its edge. We will need that hole to feed the wires from the led strip to the adapter through it.
Step 2: Placing the Wooden Spacers
Take your strips of wood and place them as shown in the pictures, they act as spacers between the two mirrors. If you use wood place it in some water first for 10 minutes. This way it wont break as you bend it.
They must be a few mm wider than the led strip. At this point you will have to redrill the hole on the rim to penetrate the wood.
Step 3: Led Strip
Place the led strip in the rim, connect the wires and give it a test!
Step 4: The Clock Mechanism
Fit the clock mechanism on the mirror (I bought a 5mm mirror and I had to glue the mechanism on it. If you buy a 3mm thick mirror you might be able to use its own nut!)
Place the clock hands on the mechanism, and place the mirror in the rim.
Step 5: Finishing!
Use another wood strip to secure the whole structure.
Place the adapter behind the Clock and its all done!
Enjoy!
5 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
41 Discussions
SherylinRM
2 years ago
VERY nice
Thanks for this :)
majids16
2 years ago
I did it. Old clock. Mirrored plastic. Mirror sun protection film on the window https://youtu.be/Cyl4STWeXos
goldenshuttle
3 years ago
Very nice project. Ur youtube post also very clear. I have one question, whats the best distance between LED strip vs front glass vs back mirror ? Thanks indeed.
fs woodworkinggoldenshuttle
Reply 3 years ago
Well I think that its just a matter of taste really. I wanted my led strip to be close to the mirrors to achieve a more intense light effect, and thats why I placed my strip just 3mm away from each mirror. As a rule of thumb I would say if you want more intense light but a bit less depth effect, keep your led strip close to the mirrors, but if you want more depth effect but less intense light keep it a bit more far apart from them. (I dont know if that makes sense, I am sorry for my English.).
If you have more questions just let me know. Thanks
MarkP54fs woodworking
Reply 3 years ago
never apologize for your English unless it is the only language you speak.
Good job! I'm going to make one next week.
samalertgoldenshuttle
Reply 3 years ago
The distance between the (LED and mirror) & (LED and one way mirror) should be uniform. If it is then we get hollow depth effect with LED at equal placement, if it is not then two reflection will seem closer to other two. Lastly as we increase the distance the LED hollow depth effect will be more likewise lesser the distance the depth effect will be shallower.
clee105goldenshuttle
Reply 3 years ago
how can you attach the led strip to the wood strip ?
fs woodworkingclee105
Reply 3 years ago
Some led strips are self adhesive. Some others like mine are not. If its not you can attach it using some hot glue in a few spots on the led strip.
FractalPI
3 years ago
yes yes and yessa! This is so inspiring to try variations, but your way is definitely my first attempt. Quite creative.
BrianM172
3 years ago
amazing suggestion: find a way to rig a computer chip to it so when you set an alarm, it makes a sound, or whatever sound you want, and the led lights inside also spiral around...
BobF13
3 years ago
REally cool. Made it a favourite. Something else to build!
fs woodworkingBobF13
Reply 3 years ago
Thanks a lot. I am here to help if you need anything.
arvevans
3 years ago
Infinity pendulum...? Infinity alarm, and infinity chimes?
Great Instructable. It shows how to build many different types of Infinity Displays.
david.crocket.52
3 years ago
Très beau travail, simple et rapide a réaliser.Bravo
AndrianS
3 years ago
So glad to see someone finally making a instructable about this , I made mine about a year ago but forgot to take pictures so i can make it into a instructable. Nice job ,looks great , circle looks great , mine was a square.
