Install Windows7 on to a Acer Netbook From a USB Flash Drive
390,862
36
20
This is a How-To for installing Windows7 on to a Acer Netbook from a USB flash drive.
Requirements:
USB Flash Drive (min 4GB)
Windows 7 DVD or ISO image (32bit)
MBRWizard (download)
Supplies:
Step 1: Extract MBRWizard & Format Flash Drive
Download and Extract MBRWizard on your hard drive.  To simplify things later, copy mbrwiz.exe to your local disk C:\.
Connect your USB Flash Drive to your computer and Format the USB drive.  To Format a USB Flash Drive Go to My Computer >Right click on USB drive and select Format from context menu.
Step 2: Convert Flash Drive From Fat32 to NTFS File System
Now go to Start Menu >Run >cmd (Command Prompt)  and Type the following command:
convert Y: /fs:ntfs   (Where “Y” is your USB drive letter).
This will convert the USB Flash drive from a fat32 to a NTFS file system.
Step 3: Insert Windows 7 DVD or Mount Windows 7 ISO Image
Insert your Windows 7 DVD or mount your Windows 7 ISO image as drive (You can use MagicDisc or any other Virtual Drive program)
Step 4: MBRWiz to Set the Flash Drive As Active
Type Start >run >cmd (Command Prompt)
Now dir to directory where you have extracted MBRWiz and run following commands.
mbrwiz.exe /list  (note the disk number of your USB Pen drive)
mbrwiz.exe /disk=X /active=X  (X is Disk Number of your USB Drive)
exit
Step 5: Make the Flash Drive Bootable
Now open another command window and type following command:
J:
 (Drive letter of Windows 7 DVD or ISO mounted image)
CD boot
bootsect /nt60 Y:
(Y is drive letter of your USB drive )
Step 6: Copy Windows 7 to Flash Drive
Now copy all files from your CD/DVD drive or where you have mounted a Windows 7 ISO image.
Step 7: Acer Netbook BIOS Boot Order
Plug your newly created Windows7 Flash Drive into your Acer Netbook and Power it up.  We need to change to boot order so that the Netbook will boot from the Flash drive first.
At the Acer boot screen, hit F2 to enter the system BIOS.
Navigate to the Boot tab. Use F6 and F5 to move your USB Flash Drive to the top of the list.
Hit F10 and save your settings.
Step 8: Installing Windows 7 on Acer Netbook
After saving your BIOS changes, the computer will restart and boot from your USB Flash Drive.  The installing will ask you which partition you would like to install Windows7 to.  Choose the larger Partition2.
Leave the OEM Partion1 intact.  This is the factory restore partition which contains the original OS files that shipped with your computer.  This partition allows you to restore your computer back to the way it was when you first brought it home.  I believe rebooting and holding down ALT/F10 will start the Acer system recovery utility.
Step 9: Important Thing to Know!
During the install process, the computer will reboot.  When this happens, Hit F2 at the Acer screen to enter the BIOS.
You need to change to boot order back so that the hard drive is listed first.
If not, the computer will boot from the USB drive again and want to start the install process from the beginning.  Putting the hard drive first in the boot list will then start the install where it last left off.
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    20 Discussions
    jahanvii
    1 year ago
    "Windows Powershell Issue is not responding", This error message is related to Windows or to my laptop, Currently I am using Acer laptop, I had also contacted <a href="https://500px.com/windows7customersupport"&gt;
    Windows Powershell Customer Care</a>and they provided me step by step guide but the solution provided was temporary. Can anyone help me out?
    jahanvii
    1 year ago
    I have an issue related my Windows 7. Currently, I am also using Acer laptop and from last some time continuously receiving an error message" Windows7 isn't responding". I had contacted<a href="https://500px.com/windows7customersupport"&gt;
    Windows PowerShell Customer Service</a>and followed the step by step guide provided by them it was helpful but was temporary. they are saying it is the issue with my laptop.
    clumy
    2 years ago
    Friends now you can upgrade to win 10 for free if your system is win 7 or win 8. If guys who have neither win 7 nor win 8 you can also upgrade to win 10 by visiting: https://www.instructables.com/id/Step-by-Step-Upgr... There you can get genuine win 10 product key to activate windows 10 in a cheap price.
    khanna4330
    3 years ago
    find out the similar artical at here
    2Dina
    3 years ago
    If you meet some problems,you can visit www.aakeys.com .I think it can help you because I have tried.
    skmsbhopal
    4 years ago on Introduction
    today i have install window 7 ultimate on acer aspire e1 511 linux base laptop.
    two thing we should have to do:
    first boot UEFI to Legacy in BIOS setting in "BOOT" menu.
    and 2nd change booting priority like select "DVDRAM" for DVD os.or "USB" for usb
    NinaW1
    Can you help me please :(
    I am going out of my mind, my husband formatted our Acer Netbook windows 7 starter to put another windows program on it. I created a bootable usb on my laptop and whenever I put it in the Acer it will not boot, Bios is set to boot from the usb. Am I missing something? I pressed alt f10 as well and nothing happens.
    NinaW1
    NinaW1
    I have made the pen drive bootable.
    And also made it the primery to boot.
    now what to do.. please let me know the steps in details as I am not a tech savvy.. :)
    Lily-y
    5 years ago on Introduction
    for step 3 and step 4, you can AOMEI Partition Assistant to do the conversion and Activation. Good work
    Tiswa
    6 years ago on Step 9
    you the best, keep up the good work tankx alot
    picimoc
    6 years ago on Introduction
    any comments on the drivers' support? I own a 8GB SSD version of AcerAspireOne (AOA-110), that comes with Linpus linux distribution. Slow, small, but it has everyhting working (including webcam). My hesitation towards installing Win7 was not related to "how to install from USB stick" (i already re-installed Linpus couple of times from external CDROM), but how well is Acer Aspire supported in Win7?
    rjwarpathpicimoc
    Reply 6 years ago on Introduction
    Windows7 appears to have a lot more drivers then previous versions. All drivers were discovered on the Acer netbook, including the web cam.
    yep...my friend did the same thing for putting WindowsUltimate on my Atom dual core Asus Netbook...except did it with a SD card...similar concept same results...and a much better OS then Starter...
    though had to go back and install the drivers for the netbook...which he already had on a memory card.
    kbhasi
    8 years ago on Introduction
    there's the iso tool for the iso's purchased from microsoft online store, now there is this for your own retail copy :)
    junits15
    9 years ago on Introduction
    why not just put the disc in and boot from that?  i have never seen one of these netbooks,  but is there something im missing about this?
