Installing MQTT Broker(Mosquitto) on Raspberry Pi
251,651
68
43
In this instructables you will find how to install MQTT on Raspberry Pi. There are two methods to install mqtt, one is we directly connect keyboard mouse and monitor to a Pi , turn it on and go to the terminal of the raspberry pi and install it from there. Another method is to access Pi through a computer using putty(SSH) and logging into the root and installing, we have an instructable which mentions how to install putty and access Pi through a computer ,you can get it here .In this instructables we are following the second method. Both mqtt client(Pub/Sub Client) and broker( mosquitto) needs to be installed on Pi.
Supplies:
Step 1: Installation of the MQTT Broker on Raspberry Pi
To use the new repository you should first import the repository package signing key follow the below comman, the wget command is used to download single file and stores in a current directory.
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
Then make the repository available to apt
cd /etc/apt/sources.list.d/
Enter the following
for wheezy
sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
for jessie
to install the mqtt mosquitto for the raspberry pi follow the below steps use sudo before the command if not using root
sudo -i
The above command is not mandatory ,it is if you wish to use root or you will need to prefix each below command with sudo eg sudo apt-get update
The below command is used to update the source list
apt-get update
After updating type the following commands to install mosquitto broker as shown in the image 1.
apt-get install mosquitto
the above command is to install mqtt mosquitto broker.
Step 2: Installation of the MQTT Client on Raspberry Pi
After the installation of mqtt broker, install the mqtt client on raspberry pi.
The below shows the command to install mqtt mosquitto client this can be clearly seen in the image1 .
apt-get install mosquitto-clients
Step 3: Testing the Working of MQTT
After installing mqtt mosquitto broker and client the user need to test by creating the topic. Open two putty programs on windows, you can do this by clicking the putty.exe file and enter the host name and click to open do this twice so that two putty programs access Pi via ssh. Lets say putty1 and putty2 are open and connected to Pi via ssh for our convenient.
In putty1 window type the command with the topic name armtronix_mqtt this topic name can be anything, according to the convenience of the user .
mosquitto_sub –d –t armtronix_mqtt
As shown in the image 1 this will subscribe Pi to MQTT broker(which is runs on Pi) handling topic armtronix_mqtt.
In putty2 image 2 window type the following command with the same topic i.e armtronix_mqtt
mosquitto_pub –d –t armtronix_mqtt –m “Hello armtronix”
Now come to the window putty1, image 1 here you will be able to see the message
Hello armtronix
This concludes the that you are running the Mosquitto broker successfully.
Similarly here another case we have tested mosquitto_pub –d –t armtronix_mqtt –m “Test passed” will display Test passed as it is shown in image 1 and image 2.
Step 4: Testing MQTT From Another System
If you want to mqtt to connect through the network/internet from another system then you need to type the IP address of the host(Broker System, in our case its Raspberry Pi ) and you will be able to connect. In the image 3 it is shown that another computer from the LAN network has subscribed to the topic armtronix_mqtt in the window 1 using the command .Please note 192.168.1.10 is the raspberry pi ip address and may be different in your case.So you will need to enter following command as shown in the image 1 which refers to window 1.
mosquitto_sub -h 192.168.1.10 -t armtronix_mqtt
Now in the terminal window 2 we are publishing by entering the command as shown in the image 2
mosquitto_pub -h 192.168.1.10 -t armtronix_mqtt -m "Hi this is Armtronix_server"
Now in the window 1 we will be able to see the message Hi this is Armtronix_server as shown in the image 3
We hope the we have made it as clear as possible for other to understand the process of installing and testing Mqtt on Raspberry Pi .Thank you
Creating some other instructable- Installation of openHAB on Raspberry Pi and setting it to control the lights, fan and camera etc which will be updated shortly.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    43 Discussions
    MarkusM9
    1 year ago on Step 4
    I had trouble getting it to work on my old Raspberry Pi B (RPi B). The issue ended up being because I used the Raspian version "Stretch" and it having some dependencies that caused issues when installed on the older Raspberry Pi version. After I rebuilt the RPi B using "Jessie" instead of "Stretch" is worked straight away.
    JohnN3
    Question 1 year ago on Step 3
    When I get here: mosquitto_sub –d –t armtronix_mqtt
    I receive an error: Connection refused.
    I don't know where to go from here.
    MrJadamlJohnN3
    Answer 1 year ago
    You probably did not start the mosquitto broker -- looks like that step may have been missed in the instructions.
    In your terminal run `mosquitto`
    Then in a new tab, ssh into the pi again and run the `mosquitto_sub -d -t foo` command to subscribe to the "foo" topic.
    Then in a third terminal window ssh into the pi yet again and run `mosquitto_pub -t foo -m 'bar'`. You should see "bar" appear in the second terminal where you had originall subscribed to the "foo" topic.
    ArmtronixJohnN3
    Reply 1 year ago
    mosquitto_sub -h xxx.xxx.xxx.xxx -t armtronix_mqtt
    Here xxx.xxx.xxx.xxx is you broker ip address
    Husam_a
    Question 1 year ago on Step 4
    hello,
    I installed the MQTT on raspberry pi3 as my server but I can not connect to it through the MQTT from another pc on my network even though I was successful to send and receive messages on same server but not from another client on the same network any ideas of where to look the message I get is "connection failed!" thanks
    GrahamR33
    Tip 1 year ago on Step 3
    The command options are prefixed by something other(–) than a regular hyphen(-) & the quotes(”) you use are different to these (') which I need on my ssh connection. Otherwise thanks for a nice short explanation of what MQTT is and how to get this set up. Cheers :)
    Bonzadog
    1 year ago
    Stretch has replaced Jessie.
    Trying to install MQTT under stretch I get:
    AFter running this:
    mkdir mosquitto
    cd mosquitto/
    wget http://repo.mosquitto.org/debian/mosquitto-repo.g...
    sudo wget http://repo.mosquitto.org/debian/mosquitto-stretc...
    sudo apt-get update
    Then I made the manual entry:
    pi@mqtt:~/Install-Programmes $ sudo apt install -y mosquitto
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    mosquitto : Depends: libssl1.0.0 (>= 1.0.1) but it is not installable
    Depends: libwebsockets3 (>= 1.2) but it is not installable
    E: Unable to correct problems, you have held broken packages.
    ANy help on this
    yoyojackyBonzadog
    Reply 1 year ago
    reset your /etc/apt/sources.list file and typing those commands on your terminal:
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get -y install mosquitto mosquitto-clients
    ChilCootCharlieBonzadog
    Reply 1 year ago
    use atpitude to install instead, it can override the dependency conflicts. done this twice now and it worked both times.
    $ sudo aptitude install mosquitto
    diy_blokeChilCootCharlie
    Reply 1 year ago
    sudo aptitide install mosquitto did not solve it for me, same error, though eventually i got some options offered that seemed to install a package
    ErikK56diy_bloke
    Reply 1 year ago
    Use this:
    add (uncomment) deb-src http://archive.raspberrypi.org/debian/ stretch main ui
    to raspi.list in /etc/apt/sources.list.d
    apt-get install cmake uuid-dev
    apt-get install libwebsockets-dev
    apt-get install libssl1.0.2
    apt-get install mosquitto mosquitto-clients
    diy_blokeErikK56
    Reply 1 year ago
    Thank you. Fortunately it is a while ago and just apt-get install ended up working for me
    Ratty Ma HattyBonzadog
    Reply 1 year ago
    wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
    sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
    wget http://ftp.nz.debian.org/debian/pool/main/libw/libwebsockets/libwebsockets3_1.2.2-1_armhf.deb
    sudo dpkg -i libwebsockets3_1.2.2-1_armhf.deb
    oldmanbeefjerky
    1 year ago
    does instructables have a text / code window? im pretty sure it still supports html editing so you could probs add one, i say this because somehow, your dashes "-" are not dashes, or, for whatever reason, your code wont paste into putty, specifically
    mosquitto_pub -d -t armtronix_mqtt –m “Hello armtronix”
    Error: Unknown option '–m'.
    the solution was to retype it but someone less experienced might assume its glitch caused by incorrectly installing something.
    sridarm
    1 year ago
    I get the following error when trying to install Ras PI 3 Jessie.
    Could you please help ?
    pi@raspberrypi:/etc/apt/sources.list.d $ sudo apt-get update
    Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
    Get:2 http://repo.mosquitto.org/debian jessie InRelease [3,884 B]
    Get:3 http://repo.mosquitto.org/debian wheezy InRelease [3,893 B]
    Get:4 http://mirrordirector.raspbian.org/raspbian stretch InRelease [15.0 kB]
    Fetched 48.0 kB in 2s (22.0 kB/s)
    N: Ignoring file 'mosquitto-repo.gpg.key' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extens ion
    N: Ignoring file 'mosquitto-wheezy.list.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename exten sion
    N: Ignoring file 'mosquitto-wheezy.list.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename exten sion
    N: Ignoring file 'mosquitto-jessie.list.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename exten sion
    N: Ignoring file 'mosquitto-wheezy.list.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename exten sion
