Instant Hanging Garden
14,659
206
8
About: Justin Tyler Tate is an artist, designer, animator, teacher, jeweler and maker/hacker who produces with thoughts of culture, science and interactivity.
These wonderful little air pillows have been around for a while now, slowly replacing Styrofoam and packing peanuts as the conventional packing material. Some air pillows are biodegradable but I wonder if the rest might not end up choking a dolphin or seal.
In this Instructable we'll upcycle those air pillows to make a vertical garden which can be draped or wall mounted; we will use the draped version as our example.
This instructable is about as easy as breathing and costs about as much so let's gather our materials and get started:
Supplies:
Step 1: Tool & Materials
For this instant hanging garden you will need:
  • A knife or scissors
  • A column of air pillows consisting of 3 or more pockets
  • Some small plants or dirt and seeds
  • A small handful of rocks/gravel/pebbles to line the bottom of each pocket
  • Clear packing tape
Step 2: Tape & Air Pillows
Start by rolling out your clear packing tape so that the sticky side is facing up; you want a length equal to or longer than your column of air pillows. Place the column of air pillows so that the edge of the plastic meets the center of the packing tape, as demonstrated in the picture. Cut the tape nicely at the end of the air pillows so that it is not visible or a few inches/10cm from the end of the column so that you can use the tap-tab as a hanging device. For a draped vertical garden you don't need to cut the center air pillow.
*You can use other wide tapes but I think clear packing tape is the best choice.
** This is not absolutely necessary depending on how many air pillows you have in the column but it won't hurt...a falling bag of rocks and dirt could hurt.
***After you're done using the packing tape, make a courtesy-tab on the end of the roll so that the next person doesn't have to struggle trying to get a piece.
Step 3: Knife
Use your knife or scissors to cut the edge that is going to be open towards the sky in your instant hanging garden.
The version I made for this instructable drapes over objects so all of the cuts were on the edges which were pointing towards the center of the air pillow column.
Step 4: Gravel
Hang your garden as you want it to be forever. Fill the air pillows with just a bit of gravel/small rocks/pebbles so that water has a place to drain.
In the example hanging garden the fourth air pillow, being the center of seven, is empty.
*You may want to clip it to the center of the garden to surface you're attaching it to, temporarily until after the next step. I used a bulldog-clip as you can see in the picture.
Step 5: Plants & Dirt
Now just put some dirt with plants or seeds into each air pillow (except the center one) and you can hang your garden anywhere...
Step 6: Hang a Garden on It:
  1. Hang your garden on a chair and pretend it's person.
  2. Hang it on a railing and look at it while you walk up stairs...
  3. OR on a different railing and watch it as you walk down stairs...
  4. Drape it over a fence (your fence, a public fence or barbed wire maybe)...
  5. Hang it over the branch of a tree, on your best friend, on a clothesline, in your window, maybe you could use it as a scarf, make a draped garden which hangs like a wall OR think of your own places to put your new hanging garden.
To get updates on related and unrelated projects: https://www.facebook.com/JustinTylerTate
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    8 Discussions
    RoBear613
    5 years ago on Introduction
    Nice idea!. I have seen some newer air pillows that are perforated between sections to make it easier to custom the packing, though. So be sure to check yours before hanging; don't want a catastrophic fail!
    I think it would work especially well for planting herbs. Actually I had always imagined planting herbs in it but then I found/used these plants instead.
    SilverBaneWolf6
    5 years ago
    Like the recycled hanging gardens of Babylon!
    5pints
    5 years ago
    A little early for April fools?
