Instructables Robot Pencil Sharpener
602
It really works!
You sharpen and it will hold the trimmings!
Supplies:
Step 1: Ingredients
Foam board
Card stock (one shade of yellow for the body, yellow orange for the arms and legs, red for the ears)
Sharpener
Glue
Sharpie marker
Pins
Popsicle sticks
Some sort of stand somewhere
Step 2: Cutting Out the Body
I placed the card stick over my computer (which had the image of the robot on it) then I traced it out with sharpie (it doesn't bleed through).
First, the body is made in three parts to begin with. The front, back, and sides the grid and back are simple, the side can be however thick, I made mine 1 inch thick. In order to find the length cut some rope and wrap it around your body, mine measured out to 6.5 inches long.
Be sure to cut out lips in the rectangle so there is a place to glue.
Step 3: Making the Head
Glue 5 squares together (mine was 1x1, but I think I made it too small)
Be sure to cut out lips, 4 - one on each side. The lips on the outside will help to create a scaffolding type deal.
Cut out the eyes by using paper and outline the eyes with sharpie (just like it looks in the drawing.
The ears are made very similarly to the body, just cut out the basic shapes and add some layers for 3d, I think the pictures will do a better job of explaining.
Stick some pins in the ears for the antennae
Step 4: Arms and Legs
Arms an legs are made by glueing cylinders together then outlining the shapes in Sharpie.
Arms- cut at a steep angle to form a good place for glueing- I think most of this is pretty subjective, so you may come up with a better way
To get started,'I would just start glueing and see where you can go from there.
The wheels are a little more tricky, for the grey- cut out the circles and then glue it to a black piece, then glue that into the legs.
For support, add some pops circle sticks to the back.
Then glue this onto another platform, like a piece of cardboard or a stand of some sort
Step 5: The Insides (part 1)
To force the trimmings out the rear, guides must be placed, glue two sheets of paper to the inside of this sharpener.
Step 6: The Insides (part 2)
Glue the paper to the sharpener and then to the robot in every way you can, up and down and left and right, so it cannot move
Step 7: The Bottom
To create the release mechanism, cut out a bottom, and them glue in a latch to hold it shut.
The bottom is just three cuts right under the area where the shavings would go.
The latch is just one paper being held up by another. The pictures will explain better :)
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    3 Discussions
    bergerab
    4 years ago
    I'm a little surprised this doesn't have that many likes! It's a cool idea, something any instructables lover would want on his or her desk!
    e9b9hoy1
    4 years ago
    Haha, thank you :)
    spunk
    4 years ago on Introduction
    This is a great robot!
    I love the release mechnism on the bottom ;)
