Internet Enabled Raspberry Pi Pet Feeder
57,642
364
69
This is a dog feeder powered by a Raspberry Pi.
If you want:
  • an easy way to feed your big dog
  • keep track of when you feed
  • control how much and how often you feed
  • and optionally be able to feed remotely through email when you are not around
this is a project for you :)
If you have all the parts around, it should take a couple of weekends to get this done.
Please feel free to modify and share your mods.
Step 1: Parts Needed
  1. Raspberry Pi 2 Model B
  2. Breakout board. cobbler and cable for Raspberry Pi
  3. 16x2 backlit LCD
  4. 12V high torque DC motor
  5. Zevro WM100 Cereal Dispenser
  6. Wireless dongle for Raspberry Pi
  7. 1/4" D-shaft for dispenser
  8. 1/4" to 6mm coupler for motor
  9. Two pushbutton switches
  10. 12V power supply for DC motor
  11. Mini USB power supply for Raspberry Pi
  12. Wood for box
  13. Jumper cables
  14. Tube to make the kibbles flow to the bowl (optional)
Step 2: Breadboard Assembly: Switch Controls
The switches provide controls to operate the feeder. There are two pushbutton switches in this design.
One for controlling the feed motor. The other to reset the feed timer.
  1. First connect the cobbler to the Raspberry Pi using the ribbon cable. Take care to orient the red line on the cable to the corner of the Raspberry Pi
  2. Place the cobbler on the breadboard
  3. Connect one terminal of the feed motor switch to pin #6 on the cobbler. The other terminal goes to ground on the cobbler
  4. Connect one terminal of the reset switch to pin #13 on the cobbler. The other terminal goes to ground on the cobbler.
All the switches are done!
Step 3: Breadboard Assembly: LCD
The LCD panel is programmed to have a clock, a feed countdown timer and status messages while feeding, resetting etc.
Here are the steps to connect the LCD panel to the Raspberry Pi through the breadboard and cobbler.
  1. Solder header pins to the LCD panel and a small PCB to the other end of the header pins. I used an old PCB and cut it to size. This makes taking the cables out to the breadboard easier
  2. Place a 10K Ohm potentiometer on the breadboard
  3. Connect +5V and ground to the left and right legs of the potentiometer
  4. Connect the following pins from the LCD to the cobbler:
  • Pin #1 (VSS) connects to ground (black wire)
  • Pin #2 (VDD) connects to +5V (red wire)
  • Pin #3 (VE) connects to the middle leg of the potentiometer
  • Pin #4 (RS) connects to the cobbler #25
  • Pin #5 (RW) goes to ground (black wire)
  • Pin #6 (EN) connects to cobbler #24
  • Skip LCD Pins #7, #8, #9 and #10
  • Pin #11 (D4) connects to cobbler #23
  • Pin #12 (D5) connects to cobbler #17
  • Pin #13 (D6) connects to cobbler #21
  • Pin #14 (D7) connects to cobbler #22
  • Pin #15 (LED +) goes to +5V (red wire)
  • Pin #16 (LED -) goes to ground (black wire)
There is a very nice detailed write up of the LCD wiring at modmypi.com
We will use the Adafruit library for programming the LCD (more details on that later)
Step 4: Breadboard Assembly: DC Motor
The high torque DC motor is a 12V 3.5 RPM motor with a 6mm D-shaft on it.
It is a simple transistor based circuit with the raspberry PI pin # 19 providing the control signal
Connect as shown in the diagram.
Note that the 12V power supply is a separate power supply just for the motor.
The ground for the 12V power supply and Raspberry Pi's ground will connect together.
Essentially the transistor acts as a switch control by the HIGH on the Raspberry GPIO pin to switch the motor on/off
Step 5: Programming the Raspberry Pi
Here's the basic idea of the pet feeder
  1. Should be able to press a button and get a measured amount of feed in the bowl
  2. No overfeeding. Disable the feed button for 8 hours after feeding
  3. Over-ride the disabled feed button with a reset button
  4. Accidental press of feed button, while disabled, should pop up friendly message on LCD
  5. Display a clock and the time left for the next feed as a countdown
  6. Trigger the feed through an email to a gmail account
  7. Trigger a query to know when the last feed and next feed can be using email to a gmail account
  8. Do some fun replies with Chuck Norris jokes and/or numbers trivia :)
  9. Make the system immune to reboots by starting the program automatically on reboot, saving state to files etc.
Step 6: Connecting the Zevro Dispenser to the DC Motor
The Zevro is pretty cool since it takes care of dealing with large kibbles for the dog.
It comes with a mounting kit and a knob. Discard the knob and its attached plastic D-shaft.
  1. Use the metal 1/4" D-shaft cut to size for your motor position. It might a tiny bit loose on the Zevro side. Nothing that a cut up credit card shim can't fix :)
  2. Mount the motor securely (I used an L bracket)
  3. Connect the D-shaft from the Zevro to the motor using a 6mm to 1/4" coupler
  4. Mount the Zevro to one of your panels
Step 7: Optional - Dispenser Chute
Didn't want to bend down to press the button and didn't want the dog to knock off the clear plastic container with the food. But a high mounted Zevro ends up in kibbles dropping from too high and bouncing off the feeding bowl
Hence the dispenser chute
Essentially a cheap 3" drain pipe and an elbow joint.
Some duct tape to make sure kibbles are directed into the bowl.
Step 8: Box and Paint
Make a small box to put it all together and paint it
Make a hinged door to keep things serviceable, if needed
Operations Manual :)
  • Just press the button to feed
  • Or send an email with the subject "When" to query when the last feeding was done
  • Or send an email with the subject 'Feed" to feed the dog!
Here's a video of the project in action. Enjoy!
Step 9: Adding a Camera
The pet feeder has been working pretty flawlessly for the past several months.
The one thing that is missing is positive confirmation that the dog is actually eating the food once remotely fed.
Raspberry Pi camera to the rescue!
Here's where to get the camera and installation instructions:
https://www.adafruit.com/products/1367
Once physically installed, here's a code snippet you can add to the original code to get your camera integrated into the pet feeder. This code takes a time-stamped picture and saves it to a file. You can take this file and email it if you like.
In the sendmail function in the earlier code simply substitute the "attach=None" argument with "PICFILE" and you should be able to receive the file.
6 People Made This Project!
  • Tape Contest
    Tape Contest
  • Organization Contest
  • Weaving Challenge
    Weaving Challenge
69 Discussions
JonT20
Question 4 months ago
for the resistors, what wattage, % are they?
krishsdoitJonT20
Answer 6 weeks ago
Most at 1/4W, 5%. There is not a lot of load on the system. The heaviest load is the DC motor and even with that the run time is only 20-25 seconds at s time.
JonT20krishsdoit
Reply 6 weeks ago
most? what would the rest be then? sorry if this sounds stupid it's just 1) im new to electrical work and 2) i want to actually build this the way you did, so i need to know everything :/ sorry for the trouble.
or if i sent you the parts could you build this for me? i'll pay obviously. i'd rather haev something like this than buy some name brand crap that isn't open source and will break in a year.
krishsdoitJonT20
Reply 5 weeks ago
Looking back at the bill of materials all of the resistors are 1/4W, 5%. So you should be good.
Part of the fun is building it. Will help you along.
ijankeis
Question 11 months ago
Hi,
I am a bit new to Python and slowly learning it through this project.
I am writing the code in Python 3.5. I have used the inbuilt imaplib.py instead of imapclient. While compiling, I get an error in the imaplib.py as follows-
data + b' ' +arg
TypeError: can't concat bytes to list
Can you explain the meaning of this and how to solve it?
Thanks.
1 answer
krishsdoitijankeis
Answer 6 weeks ago
There are some changes to the python 3.5 syntax. The original project was based on python 2.7. There are number of online resources on the errors. I usually just search for the error on google and someone would have run into and posted a solution.
krishsdoittomdeppe
Answer 6 weeks ago
It is simpler to use a breadboard. You can get small project breadboards on Amazon. Since the circuits are pretty simple, you don’t have to go through the trouble of designing, etching etc. with a PCB.
krishsdoitthemisfitgirll
Answer 1 year ago
Step 2 is broken down into the four sub steps. Let me know where you are stuck.
MarkG369
Question 1 year ago on Introduction
Hi
Is there a wiring diagram for Step 2: Breadboard Assembly: Switch Controls
Cheers
Mark
1 answer
krishsdoitMarkG369
Answer 1 year ago
There are only three connections in all of step 2.
First is the cobbler, second is the feed switch and the third is the reset switch. Let me know where you are having trouble.
michaelmandala
1 year ago
Can somebody please send a close up picture of the breadboard because I don't know how to do it. Thanks
krishsdoitmichaelmandala
Reply 1 year ago
There are only three sets of connections to the breadboard.
In Step 2 you connect the switches
In Step 3 you connect the LCD
In Step 4 you connect the motor
englewentpro.
1 year ago
This is great! I am going to borrow a lot of ideas from this to help in making my very own. My first go around with a raspberry pi will be a treat dispenser, but this is on my list of "to make". This write up is very detailed and well thought out kudos to you!
krishsdoitenglewentpro.
Reply 1 year ago
Please borrow as much as you need to and customize the way you want. Good luck!
alarmed23
1 year ago
can i use an i2c backpack for the lcd?
and what do i hav to cange in the code?
