Intrecciato Woven Cardcase
1,105
19
About: Hahns Atelier provides daily handicraft contents. Feel the pleasure of making everyday items by yourself in Hahns Atelier. Motto : Share and inspire
It's an easy version of Intrecciato woven wallet.
I recorded it slowly for following easily. If you need a pattern, please leave your email address on youtube comment. If you have any questions, please leave them in a comment too. Let's start : )
Supplies:
Step 1: Prepare Pattern and Leather
The total of of 8 sheets are enough, 12cm x 10cm
Leather should be skived as thick as 0.7 t
Step 2: Pocket Base
Apply glue on the four sheets to make the last pocket
It will be the back side of this wallet Draw a line under 13mm from the top of the card pocket Apply the glue up to the lines you marked
Step 3: Folding Top Edge
Prepare reinforcement tape 5mm thick
Place reinforcement tape 6mm below from the top Apply the glue on the reinforcement tape Fold the top of the card pocket
Step 4: Prepare Weaving
Stick the four leathers which you put glue earlier
Place the pattern on leather Punch the leather following the pattern My pattern is suitable for a 6mm punch
Step 5: Cut and Weave
Cut leather straps 5mm in width to weave
Press the surface from time to time to make it tight Apply glue on the top part by 13mm
Step 6: Making Pocket Parts
Fold to end of reinforcement tape
Make creasing line at the top of the card compartment
Step 7: Combine and Cut
Combined the whole thing, cut it in the final shape
You can make clean edges, if you cut whole parts together at once Stitch the three sides of the pocket except the top
Step 8: Edge Painting and Burnishing
Put on edge coat on the edges
repeat edgecoat - sanding - burnishing Rub with soft cloth to finish
Step 9: Done :^)
Thanks for watching!
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    3 Discussions
    Swboats
    7 months ago on Step 9
    What is that large metal disc that you're using as a roller? I've never seen one and that would fantastic for my leatherworking as well! Great video!
