LED-light for Drill Press
8,346
95
16
About: DIY, 3D printing, Woodworking, CNC, Arduino, RPI, CAD-CAM, DIY repair & MOD's.
I've had problems working with my drill press because of the shadows casted by my ceiling lighting. Obviously my tool shed / man cave isn't well lit. I decided to build a LED lamp attached to my drill press.
Step 1: Shopping List
The key item here is the loc-line modular hose. It is rigid but gives great flexibility.
- Loc-line modular hose system the real one: https://bit.ly/2MYcoBa or AliExpress https://bit.ly/2LBqAva
- LED lamp: I used this 12V 1.2W LED https://bit.ly/2wxCKj1 or: https://bit.ly/2POrzLN
- Lamp fitting: https://bit.ly/2NvvA6r
- Power supply: AC to DC 110-220v to 12v https://bit.ly/2okQBpj
- Electrical wire
- Electrical connectors (to your liking)
- mini lamp shade, I made my own: www.thingiverse.com/thing:3074219
Step 2: Assembly
1. Decide where you want your light coming from, probably from the left side as the handles are usually on the right.
2. Drill a hole in the top housing. I used a stepped drill bit as shown in the picture above. Drill a 12mm hole and you will be able to screw in the loc-line connector. I didn't have any 12mm bolts so I used some epoxy putty to fasten it to the housing.
3. Pull the 2 electrical wires through the Loc-line
4. Decide where you will house your power supply. I placed it in the upper housing as shown in the picture.
5. Loosen the on/off switch and open it's housing. You're going to have to "tap" some current (in my case 220V) from there and make sure to isolate the wires and see to it that they don't come in contact with any moving parts. I had to drill a hole from the on/off switch housing to the upper chamber. Run the 220V wires to the power supply.
6. Solder/connect the wires from the Loc-line to the power supply V- / V+ DC side.
7. Solder/connect the "220 V" wires to the input side (AC) of the power supply.
8. Run a short test making sure your output is 12V using a multimeter.
9. Connect the LED fitting to the wires making sure you know which is + (pos) and which - (neg).
10. Glue or epoxy the LED-light fitting to the Loc-line.
11. Make a lamp shade or buy one. I made my own: www.thingiverse.com/thing:3074219
12. Done!
Step 3: End Result
There you go, done!
Let me know if you've made your own and please share some pics.
Cheers!
  • Organization Contest
  • Trash to Treasure
    Trash to Treasure
  • Pie Contest
    Pie Contest
16 Discussions
KetkA
6 months ago
Una estupenda idea!!! Pablos Casita... me ha gustado tanto esta idea, que como tengo un taladro vertical igual al tuyo, voy a comprar las piezas y me voy a construir esta lámpara auxiliar para la taladradora.
La única diferencia es que yo sí que voy a utilizar lámparas LED de alto brillo, sin transformador, con un reductor de voltaje de CA a CC.
Un cordial saludo desde España.
Ketk Aiball.
Pablos CasitaKetkA
Reply 6 months ago
Muchas gracias KetkA. Mandame una foto cuando estas listo, ya ?
KetkAPablos Casita
Reply 6 months ago
Mejor que eso Pablos... tengo un canal en Youtube donde enseño las
cosas que diseño, construyo y también reparo. Busca Ketk Aiball en
Youtube. Podrás suscribirte a mi canal y verlo completo, desde que
consiga las piezas, diseñe mi propio sistema de alumbrado y
alimentación, y lo ponga en marcha.
Recibe un cordial saludo. te espero en mi canal de Youtube.
ketk.
landonz
6 months ago
If you need the loc-line to be stiffer (possibly after time) Ive heard that using wire coathanger or similarly stiff thin wire can give you the added rigidity and ward off sag (depending on the weight of the light-head).
Good stuff!
KetkAlandonz
Reply 6 months ago
Mejor que eso Pablos... tengo un canal en Youtube donde enseño las cosas que diseño, construyo y también reparo. Busca Ketk Aiball en Youtube. Podrás suscribirte a mi canal y verlo completo, desde que consiga las piezas, diseñe mi propio sistema de alumbrado y alimentación, y lo ponga en marcha.
ketk.
pgs070947
6 months ago
I like it
A good bright light helps (and makes more safe) any operation like drilling and soldering - also would make a good microscope illuminator.
I would have to agree that a transformer is not a great way to drive an LED, but it will work.
For LEDs that need constant current, I use specific LED driver chips. Microchip do a 20-mA driver in a TO92 package called a CL20 or similar. They can take any input voltage up to 90-Volts
Pablos Casitapgs070947
Reply 6 months ago
Thanks! I used a power supply (sse picture). You are right.
JohnW51
6 months ago
Umm, a transformer will NOT produce a DC voltage (which is what the LED needs). What you have must be a power supply, which takes in the 220V AC and converts it to 12V DC.
Pablos CasitaJohnW51
Reply 6 months ago
You are absolutely correct. Thanks for the correction. I made some changes to the text.
cordovox
6 months ago on Step 3
I had similar problem with poor lighting. I used two 12V led lights. one oe each side.
