Receive SmS IF "GaS" Leakage
5,017
24
7
About: I make hobbyist stuffs and play with electronics follow me to know more https://www.facebook.com/arduinolabviewsolidworks https://twitter.com/learnrobotix
Are you worried about your Home Safety??
This might be a perfect Project to get started with :)
This ible will explain how to receive sms when there is "GAS" Leakage at your home.
This project involves few components you don't need to be a nerd to make it.
List of components:
1) MQ-2 Gas Sensor
2)GSM Module
3) Arduino
4) Connecting Wires.
Step 1: Circuit Connection
You don't need to connect the way I did here, It just a explanation about which pin of arduino meets the GSM pin, all you have to do is place the GSM shield in the Arduino.
Connect the MQ-2 Gas sensor's Digital Outpin to the 7th pin of arduino or any other pin you'd like, but don't forget to change in the program (if you change the pin)
Step 2: Arduino Program
int PIN = 7;
int sensor = 0;
void setup() {
pinMode (PIN,INPUT);
Serial.begin(9600);
delay(5000); }
void loop() {
sensor = digitalRead (PIN);
if (sensor == HIGH){
Serial.println("AT");
delay(1000);
Serial.println("AT+CMGF=1");
delay(1000);
Serial.println("AT+CMGS=\"+919962*****\""); //CHANGE TO DESTINATION NUMBER
delay(1000);
Serial.print("Gas Leakage at HOME (attention required)");
Serial.write(26);
delay(300000); }
You can also download the program from this link: https://www.dropbox.com/s/q4vlcadygyn7giq/gsm_testing.ino?dl=0
Step 3: Add-on to the Project
You can also add a Flame sensor and other sensors to this project and modify the code for your Complete safe guard of your Home.
You can also check My other works in my blog: http://www.labviewarduino.in/
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    7 Discussions
    Njms
    3 years ago
    Please.. Ans me as soon as you can... I have very short duration:-(
    Njms
    3 years ago
    Njms
    3 years ago
    Can you give me the code to use both flame sensor and MQ2 gas sensor with this.
    OndraB2
    3 years ago
    Hello, does it works with SIM 800L also?? Thank you
    Mayoogh_Girish
    3 years ago on Step 2
    Do you have code for SIM300
    or will the same code works with SIM 300 GSM module?
