IoT - Controlling a Raspberry Pi Robot Over Internet With HTML and Shell Scripts Only
61,581
160
111
About: Engineer, writer and forever student. Passionate to share knowledge of electronics with focus on IoT and robotics.
In this instructable, we will learn how to create a fully controlled IoT Raspberry Pi Robot. The idea is to control the robot (or anything), using low level commands written with shell scripts commanded straight from a HTML page. Not using higher level languages as Python for example, makes the robot very responsive and quick to act.
In this part of the project we will learn:
  • Install and use the library WiringPi to control the RPi GPIOs
  • Control motors using a H-Bridge
  • Make the RPi a WebServer
  • Create a HTML to control the robot over internet
If you want to go further and provide your robot with "vision", you can go to the second part of this tutorial:
IoT: Raspberry Pi Video Streamer and Pan/Tilt camera remote control over internet
There, you will learn:
  • How to stream video with a PiCam
  • How to install and use ServoBlaster library
  • How to control servo motors and build a PAM/TILT camera position mechanism
  • Create a HTML page to control the camera position over the internet
A great video tutorial about building such type of robots can be found bellow:
Short Tutorial on How I Built my Raspberry PI Web Browser Controlled Robot, developed by Alan H.
A lot of ideas come from there. Thanks Alan for a great tutorial.
The block diagram shows the basic idea of the project. The RPi will be set as a WebServer and will receive commands from an HTML page. Those commands will change the GPIOs status, making the RPi control motors (direction and speed) and turn ON/OFF LEDs. As you can realize, the robot is in fact a particular case of an IoT project. You can control what you want. This Instructables intends to give you those ideas to take off from here.
Step 1: Bill of Material
  • Raspberry Pi model 2 or 3
  • L293-D H Bridge
  • DC Motors (2x)
  • 9V battery for motors
  • 5V batery for RPi
  • LEDs and a 330 ohms resistors
  • Breadboard
  • Wirings
  • Acrylic support for the motors/electronics (can be a kit, CDs, etc.)
Step 2: Installing WiringPi Library
WiringPi is a GPIO access library written in C for the Raspberry Pi. It is very ease to use and simplify a lot any project involving RPi and electronics.
The WiringPi library includes a command-line utility "gpio" (wiringpi.com/the-gpio-utility) that can be used to program and setup the GPIO pins. You can use this to read and write the pins and even use it to control them from shell scripts. It can be used in scripts to manipulate the GPIO pins – set outputs and read inputs. It’s even possible to write entire programs just using the gpio command in a shell-script.
To Install WiringPi:
git clone git://git.drogon.net/wiringPi
cd wiringPi
./build
To print the version, use the command:
gpio -v
To read all the normally accessible pins and prints a table of their numbers (wiringPi, BCM_GPIO and physical pin numbers), you can use the command "gpio readall", that create a cross-reference chart, with their modes and current values. This command also will detect the version/model of your RPi and printout the pin diagram appropriate to your Pi.
gpio readall
The first monitor screenshot, shows the above 2 commands result.
To setup pins (BCM_GPIO pin numbering scheme) as OUTPUT mode, for example the command must be used:
gpio -g mode 10 out
Once the pin has its mode defined, you can sign a logic state to the output:
gpio -g write 10 1
Install a LED from GPIO.10 to ground using the 330ohm resistor and anode and GND. Do some tests to be sure that everything is working. Check the monitor with gpio-readall command (see photo here).
Besides setting the pins as output or input, you can set some of them as an PWM output. This is the case of physical pin Pin 12 or GPIO.18.
to setup the pin:
gpio -g mode 18 pwm
or
gpio mode 1 pwm note: (“1”) is the wPi id for GPIO.18
to setup a pwm value:
gpio pwm 1 XXX note: [XXX ia value between 0 —> 1023]
ex.:
gpio pwm 1 512 note: a motor or a LED will be at 50% duty-cicle
to remove the setup of this particular pin:
gpio unexport 1
to remove all pin setup:
gpio unexportall
Step 3: Controlling Motors With Raspberry Pi and WiringPi
At this point, the WiringPi library is installed and you can control any GPIO directly from the command line at your RPi monitor. The next step is to create a logic to control the motors. To do that, we will use an H-Bridge, the L-293-D. This H-Bridge can control 2 motors. It has for each motors, 3 inputs:
  • Motor Left: "enable"; "motor+" and "motor-"
  • Motor Right: "enable"; "motor+" and "motor-"
Both "motors enables" input will be connected together and will be controlled by GPIO.18. This pin will be responsable for the speed control. If you do not want control the speed, leave those pins in HIGH, for example. we will discuss this further in this step.
Let's make a convention that if we want the motor LEFT to run forward, we must setup motor+ as HIGH and motor- as LOW. To run on a reverse direction, we must do the opposite: motor- as HIGH and motor+ as LOW.
The best way to really define the correct inputs for controlling the motor direction, is to test them when the real motor is assembly.
Let's assigned the GPIOs for H-Bridges inputs:
  • Motor left +: GPIO.5
  • Motor left - : GPIO.6
  • Motor right +: GPIO.13
  • Motor right - : GPIO.19
Based on the above assumptions, a logic table can be built with the possible levels to be assigned to the GPIOs (see table picture). The next step is to create shell scripts to run the motors
Every script file is essentially plain text. When a text file is attempted to be executed, shells will parse through them for clues as to whether they’re scripts or not, and how to handle everything properly. Because of this, there are a few guidelines you need to know.
  • Every script should being with “#!/bin/bash” (The Hash-Bang Hack}
  • Every new line is a new command
  • Comment lines start with a #
  • Commands are surrounded by ()
When a shell parses through a text file, the most direct way to identify the file as a script is by making your first line: #!/bin/bash (The Hash-Bang Hack). If you use another shell, substitute its path here. Comment lines start with hashes (#), but adding the bang (!) and the shell path after it is a sort of hack that will bypass this comment rule and will force the script to execute with the shell that this line points to.
For example, to create a shell script to run the motors “Forward”, based on the above table, we must create the file bellow (use the best editor for you. I am using NANO for that):
sudo nano forward.cgi
#!/bin/bash
gpio -g write 5 1
gpio -g write 6 0
gpio -g write 13 1
gpio -g write 19 0
Once the script is created, we must give it permission to be executed:
sudo chmod 755 forward.cgi
Now, to execute the script:
sudo ./forward.cgi
4 LEDs were used for testing the scripts, the real motors will be added on a further step. If works, the correspondent LEDs must be ON (see photo).
Note that I use .cgi as the file extension. CGI means “Common Gateway Interface”. It is a standard way for web servers to interface with executable programs installed on a server that generate web pages dynamically. Such programs are known as CGI scripts or simply CGIs; they are usually written in a scripting language, but can be written in any programming language.
Going on, the same idea must be applied for the other possibilities of the previous table:
sudo nano stop.cgi
#!/bin/bash
gpio -g write 5 0
gpio -g write 6 0
gpio -g write 13 0
gpio -g write 19 0
sudo nano reverse.cgi
#!/bin/bash
gpio -g write 5 0
gpio -g write 6 1
gpio -g write 13 0
gpio -g write 19 1
sudo nano left.cgi
#!/bin/bash
gpio -g write 5 0
gpio -g write 6 1
gpio -g write 13 1
gpio -g write 19 0
sudo nano right.cgi
#!/bin/bash
gpio -g write 5 1
gpio -g write 6 0
gpio -g write 13 0
gpio -g write 19 1
Once the scripts are created you must give them permission to be executed, same as was done with forward.cgi
sudo chmod 755 stop.cgi
sudo chmod 755 reverse.cgi
sudo chmod 755 left.cgi
sudo chmod 755 right.cgi
Now, execute some tests to confirm that all is working:
./forward.cgi
./left.cgi
./reverse.cgi
./right.cgi
./stop.cgi
It is a good practice that we have a specific directory for the programs used and call it “bin”. So, to save the scripts that we will use in the project, we must create a directory like cgi-bin containing all executable scripts (or binary files). For example, /var/www/cgi-bin.
So, let’s create the directory www under var, where our webpage will be located and under it, the cgi-bin directory with the scripts:
sudo mkdir /var/www
sudo mkdir /var/www/cgi-bin
Now, let’s move all files to this new directory:
sudo mv /*.cgi /var/www/cgi-bin
cd /var/www/cgi-bin
Using the line command ls, you can see the files created (see photo).
ls
One last thing before we move to another step. If you reboot the RPi, the GPIOs will return to their default condition that is INPUT. So, we must change the script /etc/rc.local that is executed at any Raspberry’s start. Just before the last command at the script ==> exit 0, we must include the GPIOs mode commands:
sudo nano /etc/rc.local
gpio -g mode 5 out
gpio -g mode 6 out
gpio -g mode 13 out
gpio -g mode 19 out
exit 0
Now, anytime that that the RPI starts, it will be ready to control the designed outputs.
Step 4: Controlling Motor Speed and Turn ON/OFF a LED (optional)
Once we will use an H-Bridge, the L293-D for motor control, we must decide if besides direction, we also want control speed.
Two possibilities here:
  • Fixed speed: Connection of H-Bridge Enable Pins (1 and 9) to +5V (full speed) or any other proportional value using a voltage divisor with 2 resistors
  • Enable Pins 1 and 9 connected to Raspberry Pi GPIO.18
Usually you can keep the speed constant, but let’s explore how to control it. To to that, a PWM signal must be used. Let’s create a group of scripts, same as we did with “directions” (the values must be tested for your specific motor):
sudo nano nospeed.cgi
#!/bin/bash
gpio pwm 1 0
sudo nano lowspeed.cgi
#!/bin/bash
gpio pwm 1 250
sudo nano regularspeed.cgi
#!/bin/bash
gpio pwm 1 512
sudo noano highspeed.cgi
#!/bin/bash
gpio pwm 1 1023
sudo chmod 755 nospeed.cgi
sudo chmod 755 lowspeed.cgi
sudo chmod 755 regularspeed.cgi
sudo chmod 755 highspeed.cgi
Now, it is only execute some tests to confirm that all is working:
./lowspeedcgi
./regularspeed.cgi
./highspeed.cgi
./nospeedcgi
In my case, at the stage I have a LED connected to GPIO.18, so I can see by the intensity of its bright, that the command is working.
Last, but not least, let’s have an extra script to control a digital output, to turn ON or OFF a lamp, for example. We will use the GPIO.10 for that:
sudo nano llighton.cgi
#!/bin/bash
gpio -g write 10 1
sudo nano llightoff.cgi
#!/bin/bash
gpio -g write 10 0
sudo chmod 755 lighton.cgi
sudo chmod 755 lightoff.cgi
Same as before if you decide to use those additional GPIOs, you must change the script /etc/rc.local:
gpio -g mode 5 out
gpio -g mode 6 out
gpio -g mode 13 out
gpio -g mode 19 out
gpio -g mode 10 out
gpio mode 1 pwm
exit 0
It is good to have the gpio mode 1 pwm as the list line before exit 0
Step 5: Installing the LIGHTTPD WebServer
We will install LIGHTTPD that is a very “light” and fast WebServer (can be used instead of Apache for example). As described on its lighttpd wiki page, “Lighttpd is a secure, fast, compliant, and very flexible web-server that has been optimized for high-performance environments. It has a very low memory footprint compared to other WebServers and takes care of cpu-load.
Let's install Lighttpd web server and components:
sudo apt-get -y install lighttpd
sudo lighttpd-enable-mod cgi
sudo lighttpd-enable-mod fastcgi
By default, Lighttpd is looking for a index.html page at /var/www/html. We will change it, so the index.html will be placed under /var/www. For that, we must edit the Ligghttpd config file:
sudo nano /etc/lighttpd/lighttpd.conf
change:
server.document-root =“/var/www/html”
by:
server.document-root =“/var/www”
In order to allowed this change to take effect, we must stop and re-start the web server:
sudo /etc/init.d/lighttpd stop
sudo /etc/init.d/lighttpd start
At this point the web server is running and if a page index.html is located at /var/www, we can access it from any browser, typing the RPi IP address:
let’s create a simple test webpage (Note that for testing, previously I moved a png file - /images/robot52.png - to image directory):
cd /var/www
sudo nano index.html
<html>
<head>
</head>
<style>
body {background-color: lightyellow}
h1 {color:blue}
</style>
<body>
<div style="text-align:center">
<h1>MJRoBot RPi Web Robot Control</h1>
<br><br>
<img src="/images/robot52.png">
</body>
</html>
Once you finish the page edition, save it and change the permissions:
sudo chmod 755 index.html
The final result can be seen at screenshot above.
Now, open your browser and type your Raspberry Pi IP Address, for example in my case: 10.0.0.31
Step 6: ​Creating an HTML Page to Control the Robot
Let’s think about a simple design for our page. What commands we may have?
  1. Two buttons for turn ON and OFF the lights ==> will work with the scrips: lighton.cgi and lighoff.cgi
  2. Five buttons for motor direction control ==> will work with the scrips: forward.cgi, stop.cgi, left.cgi, right.cgi and reverse.cgi
  3. Four buttons for motor speed control ==> will work with the scrips: nospeed.cgi, lowspeed.cgi, regularspeed.cgi and high speed.cgi
Using the index.html that we created in the last step, let’s include buttons that will call functions to execute the scripts.
For example, let’s create a button to light ON the LED (GPIO.10):
<xmp>
button {
	color: blue;
	background:lightgrey;
	border: 1px solid #000;
	border-radius: 8px;
	position: center;
<button style="height: 50.0px;width: 100.0px;"><img src="/images/lighton.png" style="height: 40.0px;"></button>
</xmp>
The above HTML would create a rounded button with a "lightened lamp" as an image (see the final page above).
When the button is pressed, due the command “onclick=lighton()”, the function “lighton() is called:
<xmp>
function lighton()
        xmlhttp.open("GET","cgi-bin/lighton.cgi",true);
        xmlhttp.send();
</xmp>
And once the function lighton() is called, the script lighton.cgi is executed and “voilá”, the LED will be ON.
The same procedure must be used for all buttons. There are some HTML functions that will organize the look&fill that you can realize looking the full HTML page. The HTML source can be seen bellow (test the page with the LEDS setup used on the previous steps):
<xmp>
<html>
<head>
</head>
<style>
h1 {color:blue}
button {
	color: blue;
	border-radius: 8px;
	position: center;
</style>
<body>
<h1> MJRoBot RPi Web Robot Control   <img style="height: 100px"src="/images/robot52.png"> </h1>
<br><br>
<button style="height: 50px; width: 100px" onclick="lighton()"><img style="height: 40px"src="/images/lighton.png"></button>
<img hspace="20" style="padding-left: 200px">
<button style="height: 50px; width: 100px" onclick="lightoff()"><img style="height: 35px"src="/images/lightoff.png"></button>
<br><br>
<span style="display:inline-block;padding:5px;border:1px solid #fc0; font-size: 140%;font-weight: bold;">
<br>
<button style="height: 75px; width: 75px" onclick="forward()"><img style="height: 65px"src="/images/forward.png"></button>
<br><br><br><br>
<img hspace="10" style="padding-left: 5px">
<button style="height: 75px; width: 75px" onclick="left()"><img style="height: 65px"src="/images/left.png"></button>
<img hspace="20" style="padding-left: 10px">
<button style="height: 75px; width: 75px" onclick="stop()"><img style="height: 63px"src="/images/stop.png"></button>
<button style="height: 75px; width: 75px" onclick="right()"><img style="height: 65px"src="/images/right.png"></button>
<br><br><br><br>
<button style="height: 75px; width: 75px" onclick="reverse()"><img style="height: 65px"src="/images/reverse.png"></button>
<br><br><br>
<p>Motor speed control</p>
<button style="height: 50px; width: 50px; font-size: 18px" onclick="nospeed()">0</button>
<img hspace="30" style="padding-left: 20px">
<button style="height: 50px; width: 50px; font-size: 18px" onclick="lowspeed()">--</button>
<button style="height: 50px; width: 50px; font-size: 18px" onclick="regularspeed()">==</button>
<button style="height: 50px; width: 50px; font-size: 18px" onclick="highspeed()">++</button>
<br><br>
</span>
</div>
<script>
var xmlhttp;
xmlhttp=new XMLHttpRequest();
function lighton()
        xmlhttp.send();
function lightoff()
        xmlhttp.open("GET","cgi-bin/lightoff.cgi",true);
        xmlhttp.send();
function forward()
	xmlhttp.open("GET","cgi-bin/forward.cgi",true);
	xmlhttp.send();
function stop()
	xmlhttp.open("GET","cgi-bin/stop.cgi",true);
	xmlhttp.send();
function left()
	xmlhttp.open("GET","cgi-bin/left.cgi",true);
	xmlhttp.send();
function right()
	xmlhttp.open("GET","cgi-bin/right.cgi",true);
	xmlhttp.send();
function reverse()
	xmlhttp.open("GET","cgi-bin/reverse.cgi",true);
	xmlhttp.send();
function lowspeed()
	xmlhttp.open("GET","cgi-bin/lowspeed.cgi",true);
	xmlhttp.send();
function regularspeed()
	xmlhttp.open("GET","cgi-bin/regularspeed.cgi",true);
	xmlhttp.send();
function highspeed()
	xmlhttp.open("GET","cgi-bin/highspeed.cgi",true);
	xmlhttp.send();
function nospeed()
	xmlhttp.open("GET","cgi-bin/nospeed.cgi",true);
	xmlhttp.send();
</script>
</body>
</html>
</xmp>
Step 7: Assembly the Robot Body
First thing is to find a platform. I had a 4WD kit with 4 DC motors. I realized that it is not easy to control the 4WD and once the idea here is not a mobility analyses, I assembled the full car, but for real test I will only use 2 of the wheels and a coster (took from an used deodorant roll).
After the Body and motors are in place, It is time to include a protoboard, make the motor connections and test it. Use the external battery to test each one of the motors.
The motors will be controlled by a H-Bridge L293-D as shown at above diagram. At this point you can also make tests, controlling the motors using +5V and GND probes at H-Bridge inputs, simulating the RPI GPIOs.
Step 8: Installing the RPi
Once all is working it is time to add the RPI. The complete circuit is shown above.
I install the RPi 5V battery between the motors at lower level chassis. The RPI is on top.
Make all cable connections ans turn on the RPi. If all the previous steps were OK, you can control the robot, using the RPi IP address. Open your favorite WebBrowser and safe trip!
Bellow, a video where the robot is tested using the Web Page:
Step 9: Conclusion
As discussed at introduction, the robot is almost an excuse to develop an IoT project. what we did here is control the RPi GPIOs over the internet. We can control anything starting from there!
My next Intractable, IoT: Raspberry Pi Video Streamer and Pan/Tilt camera remote control over internet will explore the PiCam. How to streaming video and also how to control the camera position using servos. The goal will be to merge both projects, having a rover that can be controlled by internet, but receiving video streaming.
The video bellow show how it will end:
The complete files and documents used on this Instructable can be found at GITHUB:
https://github.com/Mjrovai/MJRoBot-Web-RPi-Robot
As always, I hope this project can help others find their way in the exciting world of electronics, robotics, Raspberry Pi and IoT!
For more projects, please visit my blog: MJRoBot.org
Saludos from the south of the world! See you at my next instructable!
Thank you
Marcelo
2 People Made This Project!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
111 Discussions
Neonon
2 years ago
I'm execute some tests
./forward.cgi
./left.cgi
./reverse.cgi
./right.cgi
./stop.cgi
And is ok all working .
but when i click on the web page then nothing
John_03John_03
Reply 1 year ago
Hello
I found it!
sudo vim /etc/lighttpd/lighttpd.conf
add to:
server.modules = (
"mod_cgi",
Now it works
FreyaH4John_03
Reply 4 weeks ago
Hello,
I'm having the same issue as described above, however I am able to control the light through buttons on the web page but not the motors.
The motors run when testing in the terminal.
I've tried adding mod_cgi to the lighttpd.conf file but no success yet. Can you suggest anything else that might help?
Thanks!
John_03FreyaH4
Reply 4 weeks ago
Try to mix up all files in same folder root, do not create sub folders, images scripts .....
WilliamS287
1 year ago
Hi, I have a problem. My cgi files are running ok when executed fromcthe terminal, but when I try to run them from the web server nothing happens. I was wondering if you could help me solve this.
thanks!
mpham4k
7 months ago
When I click the webpage the button not working. I have change to 755 all the .cgi files but same issue. Please help and let me know how to fix it?
Thanks,
MP
ChandanA14
Question 1 year ago on Step 3
commod when I move the files to new directory using
Sudo MV /*.CGI /car/www/cgi-bin
That shows
MV: cannot stat '/*.cgi': no such file or directory
1 answer
artur99ChandanA14
Answer 7 months ago
It's sudo mv ./*.cgi /var/www/cgi-bin
So a dot before the first slash. I think the author made a little mistake
kzona
Question 10 months ago
I get the same error message as Maciej12345:
When I type:
I get the following error:
mv: cannot stat '/*.cgi': No such file or directory
What am I doing wrong?
Despite running into this issue, it is a great tutorial so far!
artur99kzona
Answer 7 months ago
kzonakzona
Answer 10 months ago
Did some digging online.... apparently I needed to edit it to:
sudo mv ~/wiringPi/*.cgi /var/www/cgi-bin
Now it works and the files have been moved.
fhernandezg77
Hi mjrovai, i have set GPIO18 pin or wiring pi 0 as PWM, and included into /etc/rc.local before ...exit 0 line, when I restart my raspberry this pin has 1 as value, and the scripts regularspeed, lowspeed, etc that control motor speed dont work... only work forward, stop, right, reverse and left cgi scripts. I am using L298N motor driver and have connected EN1 and EN2 to the GPIO18 pin. My rapsberry is Pi 3 Model B.
Could you help me please?
fhernandezg77
10 months ago
Maciej12345
Question 1 year ago
How to make information from gpio show up on html page. After connecting GND with gpio, the information on the page was shown and the button was pressed. Super design everything works.
DaniellO1
Question 1 year ago
Thank you for this awesome tutorial. Everything went smoothly until I got to trying to get the buttons on the website to execute the cgi. For some reason it's not working when I click the buttons. Everything works when running the cgi files on the RPi monitor. Any ideas? Thanks again!
1 answer
DaniellO1DaniellO1
Answer 1 year ago
thank you for your response! I got it working finally. I had to reformat the SD card and start fresh. I followed your instructions all over again and it worked perfectly!
