IoT ESP8266 Series: 1- Connect to WIFI Router
55,177
86
12
About: I have my B.Sc. in Mechatronics Engineering and M.Sc. in Embedded Systems Engineering.
This is part 1 of an "Instructables" series dedicated for explaining how to make an Internet of Things project using ESP8266 NodeMCU that aims at reading and sending data to a website and making an action using the same website.
ESP8266 ESP-12E Development Board will be used. This board is based on ESP8266, integrates microcontroller capabilities and WIFI in one board. It could be coded like arduino.
This instructable will show you how to configure it and program it using arduino IDE. You will implement two projects:
  1. Blinking an LED
  2. WIFI connection and IP-address print
Step 1: Configure ESP8266 NodeMCU As an Arduino
  1. Download its driver from this link CH341SER.zip or from attached file.
  2. Download Arduino IDE.
  3. —Start Arduino and open Preferences window.
  4. Enter http://arduino.esp8266.com/stable/package_esp8266com_index.json into Additional Board Manager URLs field.
  5. —Open Boards Manager from Tools .
  6. Enter esp8266 intro the search field to install ESP8266 platform
  7. Go to Tools > Board menu, then select your ESP8266 board.
  8. Go to Tools > Port.Connect your ESP.
Step 2: Run Blinking LED Program
This program needs no circuit. It will use a built-in LED which is connected to:
The pin named D4 or GPIO 2
For more information about hardware see this link https://github.com/nodemcu/nodemcu-devkit-v1.0
Download the attached program
Enjoy!
Step 3: Connect to a WIFI Network
This program will connect your ESP to a WIFI network and print its IP address on your arduino serial monitor.
You need to modify your ssid and password
const char* ssid = "YOUR WIFI NETWORK NAME";
const char* password = "YOUR WIFI PASSWARD";
make sure that the Baud rate in the program and your serial monitor window are the same
Step 4: Part 2
Follow us to see the next part of the series. It will be published soon
7 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
12 Discussions
SanjayG29
2 months ago
Thanks for an excellent , to the point description.
Joshua6243
8 months ago
This works on the NodeMCU ESP-12E, after you upload the program change the baud rate of the terminal window to 9600 and press reset, after a bit of garbage you should see the dot and the ip address.
amroadriderJoshua6243
Reply 8 months ago
Joshua6243,
I get the dots to show up but it never gets an IP address. Have you figured out anything else?
Joshua6243amroadrider
Reply 7 months ago
Actually yes, Took me a while to figure this one out, i block every mac addres on my router that is not listed so of course i forgot to add the mac address of the ESP12E to the list, this is what i used to get the mac address from the board!
Just open the console and note the mac address.
Hope this helps you out!
#include <ESP8266WiFi.h>
void setup(){
Serial.begin(115200);
delay(500);
Serial.println();
Serial.print("MAC: ");
Serial.println(WiFi.macAddress());
void loop(){}
AhmadM164
2 years ago
serial monitor is not showing any thing , as i have changed the ssid and pass and also to the 9600 baud
ImadSalkiAhmadM164
Reply 1 year ago
Dont forget to press the button reset when you open the Serial communication
anujkr6525ImadSalki
Reply 1 year ago
Thanks.. after pressing the reset button.. worked fine
Handy35
1 year ago
Hello,
Is it possible when I connect the ESP8266 to Router and I want to access Router using programming not web browser??
kenspratt
2 years ago
When the unit is connected initially, is the blue light supposed to blink? This unit is new and in it's sealed package. Also it never connects to the computer.
kenspratt
2 years ago
Am unable to find drivers that work with my Ver. 1.0 (Ver 2). The drivers here disapear when attempting to extract. The file name is there, and when extracting it dissapears. That is for Win 10, haven't found any OS X drivers that works either.
RobDeVoer
2 years ago
Thanks for the first part, cant wait to read part 2. Keep it coming!
It is good to see an introduction that just uses the device and does not spend all the time describing how to change its firmware as the standard firmware works fine for most users.
I have found the way you wire the device up makes a big difference with being successful to operate it. Secondary power that is sufficient to supply a few hundred milliamps appears critical or the device will be unreliable or now work at all.
