IoT Service Robot
4,620
41
4
About: A candle loses nothing of its light when lighting another
In this project, we will be making a Vacuum Cleaner Robot that could be control remotely via internet with single-board computer raspberry pi. We also would use camera as user interface feedback!
It’s a quite complicated project and need some basic knowledge requirement which is :
  • Introduction to IoT PHP
  • Introduction to HTML and CSS
  • Raspberry Pi Stream Video
  • Make your LocalHost Online
Supplies:
Step 1: List of Material
In this project we will be using :
- Raspberry Pi 2
- Raspberry Pi Camera
- Arduino Nano
- IR 333
Step 2: Hardware Connection
In general, the connections are very simple. Follow the instructions and images above, and you should have no problems.
  • Connect Raspberry Pi Camera to Raspberry through camera socket
  • Connect Arduino Nano to Raspberry Pi through USB cable
  • Connect IR333's VCC to Arduino's digital pin 3
  • Connect IR333's GND to Arduino's GND
Step 3: Microcontroller Programming
Below is IoT Vacuum Robot Code. Upload Nano.ino code to Arduino, index.php and index.css to Raspberry pi in /var/www/ and you should have no problems.
You could clone and edit the code in any way you prefer.
Step 4: Enjoy!
After making sure that IoT Vacuum Robot working perfectly, port forward your server to make your IoT Robot ability to be access from everywhere. Check it out here.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    MatthewBenny
    2 years ago
    Okay, you guys could make it into 3 steps.
    Step 1: Get arduino, bulb etc
    Step 2: Build it
    Step 3: Enjoy
    cynthia90
    2 years ago
    How can I get vacuum cleaner? Do you have 3D model file for printing? Is there any other sales product or model No. of prodcut?
    craighissett
    2 years ago
    I may be missing something, but where does it cover the actual building of the vacuum robot?
