Joule Thief Charger
127,382
201
87
About: I like to tinker and experiment with electronics, robotics, programming, and photography. Along with my latest interest in Steampunk.
Let your dead battery give life to another! An open circuit Joule Thief can put out 50 or more volts. Enough to charge a AA or AAA Nicad or NiMH rechargeable battery.
Step 1: Make the Charger
Use this schematic to build a standard Joule Thief circuit with the added diode.
My joule thief uses twisted network wire passed through a small ferrite core. I use 6 turns of wire. You can find a core from a burned out compact fluorescent bulb. You can see how others have wound the coil and built the Joule Thief, since so many have done so. Just add a diode and LED in series with the charging battery. The LED is useful as a charge indicator.
A high-speed schottky diode would be the most efficient. The 1N4005 was handy at the time and works.
Step 2: Open Circuit Voltage
I got a voltage of 52.6 volts coming out of the joule thief circuit without any connection to a load.
More than enough voltage to charge a rechargeable battery.
Step 3: Charge Current
I measured 9.33 milliamps into a shorted load. This is the charging current to the cell.
Step 4: Charger in Action
The donor cell on the left has a voltage of 1.057 volts. This battery is charging the battery on the right.
Step 5: Charging Up
The receiving cell voltage is 1.375 and is getting a steady charge.
Step 6: Plotting the Results
I connected My two channel data logger and monitored the voltages of both batteries overnight. The life force from one cell goes to the other. Its like the Alien Healing Device from Babylon 5.
Steps 7 and 8 show the results using Excel.
Step 7: First 8 Hours
Top red trace is the cell being charged. The cell voltage has stabilized and is accepting a charge.
Bottom blue trace is the donor cell. Notice how the voltage is slowly dropping off. The life force of the donor cell is slowly slipping away.
The Joule thief output jumped between two voltages and is a bit steppy. Nothing is perfect.
Step 8: Last Chart
The final 5.7 hours before I stopped recording data.
The charged cell is still receiving a charge and the donor cell now has dropped to about .62 volts. The Joule Thief is still running.
    • Build a Tool Contest
    • Pie Contest
      Pie Contest
    • Remix Contest
      Remix Contest
    87 Discussions
    Nakagwa Labs
    2 years ago
    what if i connect a 9v alkaline battery instead of the 1.5v battery
    elhnad
    4 years ago on Introduction
    this is really awesome....but just to make sure i've understood this right. So even tho this outputs 50 or so volts, when it actually is closed and there's a load receiving the charge, it will self adjust to the recipients voltage, just enuf so current (a few dozen milliamps) can flow from one to the other.
    does the current change by a lot or is it always a small number and so will require overnight charging.
    my practical use of this is to rejuvenate/restore almost dead lithium ion batteries.
    botronicselhnad
    Reply 4 years ago on Introduction
    The voltage will adjust itself to the charging of the battery. The current is so small that is more of a trickle charger. Because there is no voltage limit, may not be safe on a lithium cell. Although many lithium cells have built-in overvoltage, undervoltage and overcurrent limiting devices inside. Monitor the voltage as its charging and establish a cut-off point.
    Yerboogiemanbotronics
    Reply 3 years ago
    IMR lithium batteries have this protection while similar ICR batteries do not.
    zorcy
    3 years ago on Introduction
    So, what would keep this from working with, say 6 circuits, running parallel, with electrodes in the lake, to charge a 12v battery? Since the water is not alkaline, it would have a very small charge, very. But a small charge would boost up?
    botronicszorcy
    Reply 3 years ago on Introduction
    I guess parallel operation is possible. The diode at the output would keep the other circuits from shorting each other out. You can eliminate the led and just keep the one diode. Interesting idea!
    gmccusker
    Hmm, replace donar cell with a small 1.5v solar cell and the load with 3 1.2v Ni-MH batteries in series. Workable? I don't care much for how long it would take to charge the batteries, more interested to know if I can get a smaller cell to charge a higher voltage considering that's what the joule thief does in the first place.
    PhilKE3FL
    What was the starting voltage and ending voltage of the NiCd battery?
    botronicsblinkyblinky
    The turns is not critical for it to work. The frequency will usually go down with more turns. Experimentation is in order.
    blinkyblinkybotronics
    Thanks. On my digital meter, when I measured and checked for voltage I got 0.1 volts less than the battery had. What happened?
    PhilKE3FLblinkyblinky
    You can go to my website http://cs.yrex.com/ke3fl/htm/JouleThief.htm to see how to optimize the Joule Thief circuit. I did a boatload of tests to see what was "best." I consider it to be the "best" when a circuit got the dead battery to last as long as possible, in other words it used the least amount of current. Brightness was not as important but the LED still had to be about as bright as a 3V source using the same LED. This is NOT the only "best" there is, it is simply the one I decided to base my test results around. I figured that as long as the circuit could be used as either a flashlight or a night light it was good, bright enough.
    Increasing the number of turns, up to a certain number, which differed for different types of wire and inductor cores, increased the efficiency and then if you put more turns on things started to get worse again. I noticed little difference in peak pulse voltages but they were there and with the circuit running they never seemed higher than ~ 2.8 Volts as I measured with an O-scope. The lowest voltage measured was ~ 1.95Volts, for the white LEDs. Other LEDs, as the blue and amber LEDs showed, had different turn on voltages.
    I tested three different transistors, three different colored LEDs, four different inductor toroid cores from Digi-Key (all under $0.50 each for single pieces) http://www.digikey.com/ at least three different wire thicknesses, and many different number of non-easy type of loops. (The easy Joule Thief uses the same number of loops for both sides of the circuit, I tested different number of loops, found which part of the circuit should use the higher and lower number of loops and found the optimum number of loops for each to achieve the lowest current usage while maintaining a sufficient brightness.)
    Digi-Key Toroid Part #s I used for my tests:
    495-3851-ND, 495-3849-ND, 495-3848-ND, & 495-3874-ND
    captainchaoss
    4 years ago
    Total Noon here. this is probably a silly question, but could I use "c" cells as the donor(s) ? They are the same voltage, with larger capacitance, so to my understanding, they will still work, right ?
    Through my job, I have a constant supply of partially discharged batteries, mostly "c" cells. It stinks to see most devoted to disposal. I would rather build a few of these and vampire the energy to some rechargeable !
    Yes, in fact the circuit will work with any size battery and with voltages probably a good deal higher than 1.6Volts even, as long as the transistor, and other parts, can stand the voltage. Understand that the thing that keeps the battery, the NiCd under charge, from blowing up or having a meltdown due to the excessive voltage is the fact that these are very fast pulses. NiCds WILL meltdown if over charged even at a trickle rate, considered to be ~ 1/20 - 1/10 the AHr rating of the battery. They start to heat up, get extremely hot eventually and self destruct. I have never known them to start a fire but I have seem them melt plastic cases such that the case with dead batteries had to be thrown out and replaced batteries and all. I saw this happen to a pair of 5W CB walkie talkies and I had to replace the entire case of the walkie talkies as well as the NiCds.
    NiCds are generally considered to be fully charged when they reach a charge voltage of 1.35 - 1.4 Volts and should NOT be charged further than that to avoid the overheating or meltdown condition.
    kyooby
    Hi.Can I light up 12 leds(bright light not low) with this circuit? I sow somebody on youtube hooking up 53 leds lightning for about 15 hours.Can this be true or fake?
    argha halder
    5 years ago on Introduction
    its impossible because leds will burn to ashes at 50 volts and even the best joule thief with 6 turns on coil wont give 50 volts.may be you put the wrong dial on the voltmetre to measure.but except it is a great instructable.
    botronicsargha halder
    Reply 5 years ago on Introduction
    No, No you are so wrong. You can place an led in series on high voltage circuits as long as the current is limited and not reverse biased. Its done all the time in led light bulbs that run on 120 vac. The diode in series protects the led from any reverse voltage and the joule thief current is limited. The meter clearly shows 50 volts. I kid you not.
    PingoBagsbotronics
    The high volts if from the zener diode you're using right? I have some different zeners I've tested and a few of them output about 50 volts too.
