Jumbo Pretzels
14,723
526
26
About: My name is DJ and I previously made electronic whatsits, 3D-printed thingamabobs, and laser-cut kajiggers for the Instructables Design Studio; now I build and repair puzzles for Escape Industries.
Crunchy on the outside, fluffy on the inside, pretzels are part of the pan pantheon of heavenly breads. This is a recipe for Bavarian style pretzels. While not as traditionally large and and twisted as a true Bavarian pretzel, these are nonetheless a quick fix for jumbo pretzel goodness. This recipe will yield about six single-hand-holdable pretzels. Let's begin!
Supplies:
Step 1: Ingredients
  • (4 cups) flour (all purpose)
  • (1/8 cup) water (105 degrees)
  • (1 1/3 cup) water (warm)
  • (1/8 tsp) salt
  • (1 tbs) brown sugar
  • (1/4 oz) active dry yeast
  • (box) baking soda
Tools:
optional (but highly recommended!):
  • melted cheese
  • mustard
  • sausages
Step 2: Preparation
Combine in a small bowl:
Stir until well mixed!
Step 3: Make Some Pretzels
In a large bowl, combine the yeast mixture with the remaining 1 1/3 cups water. Stir in the salt and 4 cups of flour. Before processing, put on your preferred traditional German music. I suggest either Rammstein or Bach, but either is acceptable pretzel-preparing music. Knead the dough until it is nice and stretchy. Divide the dough into six equal pieces and roll them into long ~18 inch rolls.
Heat your oven to 400 degrees.
Now, to create the knot form, take one of your pretzel pieces and curve it into a "U" shape on a floured surface. Twist the ends together, bring them up, and then twist once more before laying them over the bottom of the "U." Repeat for the remaining five pretzels.
Let the dough rise for about 10 minutes!
At this point, you may freeze your pretzels to better keep their shape before the next step. If you're the pangs of a serious pretzel deficiency, I recommend immediately jumping ahead!
Step 4: Dunk Pretzels
In a large pot, keep adding cups of water until it's around 3 inches deep. For each cup, mix in two tablespoons of baking soda. I ended up using 10 cups, thus 20 table spoons of baking soda. Bring the pot to a boil and ensure the baking soda is fully dissolved. Reduce to a simmer.
Using a spatula, individually sink a pretzel one at a time in the pot, pressing down to keep it submerged for ten seconds.
Although lye is traditionally used, the baking soda solution will accomplish a similar chemical reaction with the dough, breaking down the large proteins into smaller amino acids, which, when baked, will produce the classic pretzel skin.
Step 5: Baking
Using a single large baking sheet, lay down a sheet of parchment paper. Lacking proper paper, I opted to grease mine with a stick of butter. Prior to baking, sprinkle salt or your preferred topping and pop your pretzels in the oven for 15 to 20 minutes, depending on your desired level of crunchiness.
Step 6: Eat!
Although scrumptious on their own, pretzels go great with side of dipping cheese or mustard. I purchased a couple packs of kielbasa and a six pack of friends to enjoy with my good beers. Auf wiedersehn!
3 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
26 Discussions
CarolinaThePotato
4 years ago
you're right about the music, they came out better with gamma ray and helloween than they did right now with slipknot. still a great recipe
bgoldberg1
4 years ago on Introduction
If the water/baking soda mix is boiling, then you can add more baking soda than if it's at room temperature.
More baking soda in the water means your pretzels should brown even better.
WoR0407
remark: within original german recipe, Prezels are ducked into 4% Sodium Hydroxide dilution instead of water with baking soda. Please be aware that Sodium Hydroxide can be dangerous...
Finnagin2324
4 years ago
Perfect for a snow day breakfast!
15, 1:17 PM.jpg
barnabas09mjwallace44
Reply 4 years ago on Introduction
There is a no-knead method of forming gluten in wheat dough....you make the dough very wet, adding water as it is being mixed and let it set....the gluten forms from the proteins by itself after a few days. This is how sourdough works....yeasts, once added, continue to "eat" the dough and grow. Keep the dough in at room temperature and the yeast will live and the starches will form elastic gluten. If you use only non-bleached, non-gmo wheat flour, preferably organic, you will not suffer from indigestion.
sour dough does not make gluten specifically, it make yest poopies which we enjoy the smell and taste of. Alcohols, esters and wee wee/acids..sour! Gluten will link up if you add water and warmth, kneading hastens the process. What a long rise/ferment time does is let the yeast pollute the dough enough to make it tasty. In some German bakeries they use 2 yeast. The first makes a "sour", and that is then fortified with a rising yeast , specifically for lift, then the rest of the stuff is added, kneaded risen shaped risen and baked. Every recipe has it's idiosyncrasies and benefits.
I shall try yours. They look rather nice actually. Thanks!
daenrismjwallace44
If you're not letting the dough rise, then the yeast isn't really doing anything. Most pretzel recipes will have a primary -- and somtimes secondary as well -- ferment period to allow the dough to rise, gluten to develop, and to develop a bit more flavor from the yeast as well.
giig982
4 years ago
These look amazing! Can you translate the quantities to metric units, instead of imperial ones?
giig982BeeAmaker
Of course I can, and, FYI, Google works even better: if you search "cup to ml" it shows you an online calculator. BTW, that's not the point.
My comment's aim was to be constructive: if you put the quantities in both systems, your target would be larger, isn't it? :)
Aleator777giig982
+1 El Goog. I have to agree with BeeAmaker. Also, I think it would be a bit confusing to the reader to have both units of measurement side by side, when there are so many free and easy conversion tools.
