K'nex Pistol With Shells
7,808
12
122
This is a knex pistol that uses shells to help reload, however the shells are not required to fire the gun. If you find it hard to follow the instructions or would just like to comment, please feel free to do so. Thank you.
Step 1: Make the Shells
This is a picture of a shell. Make as many as you want, just make sure they are in pairs of two.
Step 2: The Barrel and Rams
This is the barrel, or barrels rather.
Pictures 1-2: These pictures are both of one piece, but you need to make two of them.
Picture 3: Add a grey/black rod to ONE of the pieces you made just now.
Picture 4: Make these pieces. (Yes, the rods HAVE TO BE the orange version of the red rods.)
Picture 5: This is the barrel, or barrels. It is pretty simple, all you use for it is a couple of grey rods, some dark grey connectors, and a few orange/brown connectors.
Picture 6-8: Put the rams in the barrels. Attach the piece with the grey rod attached to the front of the gun. Attach the other piece to the back of the gun.
Step 3: Build and Attatch the Supports.
Pretty simple.
Picture 1: Side view of the supports.
Picture 2: Top view.
Picture 3: Bottom view.
Picture 4: Attach here, to the front of the gun.
Picture 5: It should look like this after it is all built and attached.
Step 4: Trigger
Just look at the pictures and build.
Step 5: Trigger Guard
Follow the pics.
Pic 1:This is the bottom of the guard.
Pic 2:Then add this to the end of the guard.
Pic 3:Attach The trigger guard to the base.
Step 6: The Handle
Follow the pics.
Step 7: Loading and Fireing
Pic 1: Add the main rubberbands to the end of the barrel.
Pic 2: Attach the same rubberband to the tan connectors at end of the rams. (Note: the rams are cocked in this picture.) Also attach rubberbands to the noted areas. If the bands are too strong, then it won't work.
Pic 3: This is the shell. once you cock the gun, pull the trigger. Then cock the gun again and change the shells for loaded shells. Pull the trigger and repeat.
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    122 Discussions
    supah4x0rWhaleman
    guys, these are different opinions from different people you are all entitled to your own opinion just dont critisize others ok?
    Whalemansupah4x0r
    Eh what? Are you insinuating that by starting a comment with "Are you insinuating..." preceded by a one or two word question implies that I disagree with the comment?
    WhalemanILIKEPIE333
    Mao was China. Not Soviet Union. Marx was German and died before the Soviet Union was created. Castro was Cuban. Soviet Russia is different than "Communist" Countrynamehere (Most of these are really dictatorship, including the Soviet Union).
    ILIKEPIE333Whaleman
    I know this, I was talking about your pic Marx was a Russian Soviet Russia was controlled by the Communist party, just like the Nazis in Germany They are all Communist or Marxist (i.e. Marx)
    WhalemanILIKEPIE333
    Wilhelm Marx and Karl Marx are both Germans. Karl Marx is credited with founding communism. The Nationalsozialismus are Fascist, and actually blamed the Treaty of Versailles on the Jews and the Communists.
    ILIKEPIE333Whaleman
    I knew they were fascists, but I was comparing them to the communists (ironic, huh?), I wasn;t saying that they were communists
    DJ Radio
    This ible got added to my group cuz its a sear system.
