KCS - Kitchen Cupboard Storage
2,605
31
4
About: Design Technology Teacher, Laser Engraving Enthusiast
Do you get frustrated trying to get your saucepans out of the cupboard each day? Is there wasted space in your kitchen cupboards? If so then this project could be for you.
Supplies:
Step 1: Materials & Equipment
Materials:
12mm Plywood
6G x 18mm coutersunk screws
PVA Glue
Equipment:
Woodworkers Vice
Band Saw
Table saw
Panel Saw
Phillips Head Screwdriver
Pencil
Trisquare
Ruler / Tape measure
Step 2: Design
The shelving unit was designed to provide multiple configurations. It is a simple yet sturdy design; each unit has been kept to a width of 400mm to ensure structural integrity. The design could be modified depending the requirements and dimensions of each cupboard.
Step 3: Cutting Out
Legs: Cut the legs out (400 x 200) on the table saw. Mark the steps (200 x 100), cut them out with a panel saw.
Cleats: Cut strips of 12mm Ply on the table saw (200 x 35)
Strips: Cut these on the table saw from 12mm Ply (400 x 35)
Step 4: Assembley
  1. Glue and glue cleats into place. Ensure that each pair of legs is opposite in orientation to each other.
  2. Dry fit the strips onto the legs.
  3. Pre-drill two holes into each end of the strips. To provide the most strength, offset the holes.
  4. Apply glue to each piece and screw down in place.
  5. Each strip was spaced by eye. If you wish for a uniform finish then a spacer could be used.
  6. Assembled, glued and screwed
Step 5: Finish
The shelving units could be sanded and waxed, lacquered if you wish. The units have provided additional storage and freed up space in other cupboards.
    • Classroom Science Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    4 Discussions
    jessyratfink
    2 years ago
    I need to go dig through the scrap wood in my garage - these are great!
    s.antcliff
    2 years ago
    Thanks, they were really easy to make and have made a big difference to my kitchen cupboards.
    Swansong
    2 years ago
    Those look nice! We need something like this to organize the cabinets :)
