K'NEX Robotic Suit Mark II
15,179
45
92
About: In my spare time I make robotic suits out of K'NEX
This is the second robotic suit, or kenexoskeleton that I have designed out of K'NEX. It is a completely revised version of my first suit, except for the helmet, and is stronger and more mobile. It took about a year to create and is composed of roughly 7,000 pieces.
See more pictures at https://www.facebook.com/pages/Alex-Nguyen-as-KNex-Robot/153178024715380
Supplies:
Step 1: Helmet
The helmet is the only piece I kept from my original suit. It also has eye flaps that can open and close.
Step 2: Torso
This piece was definitely the most challenging. It covers my whole torso, leaving only holes for the arms and head. However, it was still flexible enough that I could lean side to side and bend without limitations. It also opened along the center of the front so that I could easily step inside and put it on.
Step 3: Arms
The arms were the easiest part of the suit to create. I could fully bend my elbows, while the wrist was also able to rotate and bend. The fingers could move and grasp as well. The shoulders were also modified so that I was able to move my arms 360 degrees and even rotate them.
Step 4: Legs & Feet
The legs were improved so that I could walk normally, as well as run. I was able to bend my knee 90 degrees and also pivot on my ankle. Like the torso, my legs opened down the center and the foot folded out so that I could step in to wear it.
Step 5: Final Product
Once I had built all of the pieces, I attached them together and produced the result below. In order to hang it, I built a frame out of PVC pipes and used several elastic cords to suspend it from the shoulders. Putting it on was relatively easy, as I was able to open the torso and legs and just step inside.
Halloween Epic Costumes Challenge
Finalist in the
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
  • Gardening Contest
    Gardening Contest
92 Discussions
Knexosoldier
2 years ago
plz make a mark lll and email plz
The Knex Inventor
2 years ago
This is amazing! I may have to build one for myself!
rockzter928Gaming.
3 years ago
It would hurt like a mother of you fell while wearing that.
ProtectTheAlphaWolf
3 years ago
I've made some thing simular to this but not with as many pieces as this one and nowhere near as much detail as this one! you did a great job!
knexsoldier
3 years ago
the arm and torso were the most challenging
knexsoldier
3 years ago
hey I created my version based off your idea
theoriginalrage
3 years ago
I came here to look up info on how to mod my Keurig coffee maker and stumbled upon this. Best day ever. Awesome work!
EpicMinecrafter870
3 years ago
I am so making one and wearing it into a nerf war.
the potato
6 years ago on Step 4
i see you made it so theres no bottum of the foot so you can reduce part use and increase comfortability
