Kayak Step Cart
36,269
249
21
An alternative to the DIY PVC cart - easy to make, doubles as a step for loading / unloading and folds for convenient transportation / storage.  It doesn't get much easier than this.
Supplies:
Step 1: Folding Step Stool
Needing a kayak cart, I was looking for alternatives to measuring / cutting / gluing (cursing*&$#! / re-measuring / re-cutting / re-gluing) a PVC cart.  In the process, I came across this folding step stool.  (ranging in price from $10 - $15 online or local store)
Step 2: Axle
Cut a 3/8" threaded rod to 17" in length - grab a few nuts and washers along with a couple of 8" wheels.
Step 3: Drill
Drill out the center of the hinge with a 3/8" bit.
Step 4: Insert Axle
Slide the threaded rod through the hinge and center it.
Step 5: Lock in Axle
A washer on either side of the step, double nut to lock in place (it also gives proper spacing/clearance for the wheels).
Step 6: Add Wheels
A washer on either side of the wheel and another double nut set on the outside (end cap optional).
Step 7: Ready to Roll
Done - ready for use as a step to help load and unload.
Step 8: Fold
Collapses for convenient transportation and storage.
Step 9: Flipped to Position
Flipped into position.
Step 10: Add Padding
Your basic foam noodle padding - slits cut to slip over stool feet / edges. (foam held in place with Velcro cable ties found in any office supply store)
Step 11: Good to Go
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    21 Discussions
    alvarezmia1414three
    Question 3 days ago on Introduction
    You may think that I am stupid for asking this question. But here it goes anyway. Is the bottom of the kayak supposed to have 4 plugged holes? Or are they supposed to be opened?
    mean_ls
    9 months ago
    I made 2, but the hooks on my strap kept pulling out the side hinge so i drilled a couple holes on each side to attach a loop for the tie down. I used a 5/8 rod instead of 3/8 and also used that sticky shelf liner stuff and ponytail holders on the legs as the noodle was too slide-y. I wanted to use nyloc nuts on the ends but couldn't find any.
    macataq
    Question 10 months ago on Introduction
    maybe a dumb question, but what supports the center of the sponge pieces?
    thanx looks like a super idea
    Mac
    tonyi
    1 year ago
    What a great simple idea & design, for what could easily be a ~50 to $150 buy from the canoe shop.
    i have one of thoes colapsable steps for the kids, but now they are growing up and somewhat taller, i can now see a good reuse for it.
    Thanks for sharing.
    rickosaurus
    3 years ago
    This was a great cart. I definitly pushed it to it's limits though. I tried to stack both my kayaks on top of each other on it and it ended up breaking. My own fault. I'm gonna see if I can find a step with a higher weight limit next.
    3D-NM8ORrickosaurus
    Reply 3 years ago
    Glad you like the project. The limit for the stool I used is allegedly 300 lbs., but since the hinge is compromised and I'm sure the weight is not being distributed as intended/designed - that 300 number pretty much goes out the window. Just curious - what is the approx. combined weight of your kayaks and where did the cart fail/break?
    rickosaurus3D-NM8OR
    Reply 3 years ago
    I'd guess and say each kayak is around 50lbs so total would be around 100lbs. I wasn't expecting the stand to still hold 300lbs but I was curious to test it's limit. I think the hinge was still intact but one of the sides of the top broke.
    Thanks for posting this. I love the idea of using a folding step stool. It would give me the extra height I need to strap the kayak on the roof of my vehicle. BUT, can you use it as a step stool with the foam padding on there ?
    Glad you like the concept. I slip the foam padding off of the stool before I flip it over to use as a step, a seat or to store it. As mentioned, I use a couple of Velcro cable ties (similar to: http://www.officedepot.com/a/products/369220/VELCRO-Brand-GET-A-GRIP-Straps/) to hold the foam in place when using it as a cart. Hope that helps.
    demini
    4 years ago
    This was super easy. 15 minutes at most for building 2 of them. Would have been faster if we hadn't stopped to admire our work and grab more beers.
    Dryboater
    5 years ago
    Thank you for a great and easy alternative to $150 boat carts
    dkrall
    5 years ago
    wow, great idea. so simple. I'm going to use some old lawn mower wheels I have laying around. all I have to buy is a stool.
    rham243
    5 years ago
    Thanks so much! Built one this weekend and it works great. Found the stool and a pair of 7" wheels at Kmart, got all the hardware at Lowes. Cost all together around $25 to complete.
    redfoxtrystman
    5 years ago
    I'm going to use this idea. Me and my boys are going to build a canoe this summer. I'll use this for that thank you
    Jobar007
    5 years ago on Introduction
    That's a pretty good idea. I like it a lot. The only thing that I would change would be to swap out the threaded rod with a solid rod that I tapped the ends on for the bolts. It would eliminate the need for a second set of nuts to lock the first and be much stronger.
    By the way, what is the load rating on the stool that you purchased?
    3D-NM8ORJobar007
    Reply 5 years ago on Introduction
    The step I found at Kmart looks to be identical to the one found on Amazon (Kikkerland Rhino Easy Fold Step Stool). Rated up to 300 lbs.
