Keyboard Circuit Sheet Lampshade
38,278
426
70
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instr...
I had a really old keyboard lying around that I planned to use to make a Keylendar.  Upon opening it up I noticed that the circuit sheets were a really pretty bluey/green colour.  I thought this would make a great lampshade.
For the light source I used an LED puck light connected to a USB cable so that I can have it near my computer.  The light cast through the lampshade is not overly bright but it makes for nice mood lighting.
Step 1: Materials and Tools
  • Old or unwanted keyboard
  • Light and power source ( I used an LED puck light connected to a USB cable)
  • Metal tin
  • Glue
  • Clear packing tape
  • Hole punch
  • Screwdriver
Step 2: Measure and Cut the Sheet
The keyboard circuit sheets can vary in appearance so unfortunately there is no way of knowing whether you circuit sheets will be as pretty as these.
  • Dismantle your keyboard and extract your circuit sheets.
  • Roll the sheet into a cylindrical shape and fit into your base.
  • Mark where the sheet begins to overlap and cut off the excess
Step 3: Tape
Apply clear packing tape to one edge of the sheet, roll it into a cylinder and tape the edges together.  Fold any excess tape over the rim or cut off.
Step 4: Prepare Light
For the light source I used a LED puck light powered by my computer through a USB cable.
  • If you have never made a USB light before simply strip the end of the USB cable that is not connect to the computer.
  • You will have four wires inside, ignore the white and green ones (you can just cut these off), the red is positive and the black is negative.
  • Since the voltage from the cable is 5V and my puck light uses 3V a resistor is required.  Use http://ledcalc.com/ to assist you in finding the right resistor.
  • Connect the positive (red) wire to the resistor and the resistor the the positive part on the light then the negative(black) to the negative. The light should now work.
Glue the light onto the base of the lamp.
Step 5: Make a Hole for the Cable
We will need a hole in the lampshade for the cable to exit. With the hole punch make a hole on the circuit sheet cylinder just above the edge of the base and make a small slit from the hole to the bottom.  Slip the cable through the slit to sit in the hole.
Step 6: Glue Top and Bottom
Once the circuit sheet cylinder and light source is ready simply put it all together and glue the base and top on.
I used the metal lid and bottom of a container of bath salts.  The lid was used for the base since it had a nice rim.  I'm not entirely happy with the part that I used for the top but when I went back to the store to buy more of the same bath salts (with the nice lid that I could use) I was disappointed to find that they no longer sold them.  I've been on the look out ever since.
Keyboard vs. Mouse Speed Challenge
First Prize in the
  • Organization Contest
  • Tape Contest
    Tape Contest
  • Pie Contest
    Pie Contest
70 Discussions
ChrysNastroboy907
I no longer have it but I did take a picture of the model #, etc. The model number is SCORP104. I don't know if the rest of the info. is helpful.
longwinters
7 years ago on Introduction
Great idea: It's projects like this that make me glad I discovered this place.
You deserved the first prize.
NaturalCrafter
7 years ago on Step 6
This is a project I would love to do. Thanks for sharing.
ChrysNCrLz
Thanks, I think I lucked out with a really nice looking keyboard sheet.
CrLzChrysN
I'd say fortune favors the prepared- this and your tea lights are really nice circuitry artwork. Thanks for sharing!
SG1OniellChrysN
You're kidding? When did that happen? I was able to favorite several others today, and have probably 300 favorites or so. Why did this happen?
SG1OniellChrysN
I was going to say it didn't seem right, plus I was able to favorite others after it. I think the issue is that the bar that contains the steps at the top is blocking the favorite option at the top of the page. I would love to favorite this, you did a really great job with it. Perhaps after the contest bar goes away it will be able to display the favorite function, untill then, great job mate.
