Knex Gun
655
About: Finally back, this time with my new Ball Machine, Helios! If you like it, thanks! Otherwise, thanks anyways for knowing what it is!
This is my knex gun, you can store the ammo on top ( as seen ) and you even have sights. Please test this and see the range. I don't generally write the ranges as it differs on the angle and the rubber bands. This is my first gun instructable, so it may not be top notch, but I hope that it is acceptable.
Step 1: Parts List
Rods
Green - 56
White - 45
Grey - 1
Connectors
Dark Grey - 6
Light Grey - 2
Red - 8
Green - 4
Yellow - 12
White - 10
Flexi - 1 pair
Y-Clip - 2
Step 2: Body
Step 3: Barrel
Step 4: Trigger
Step 5: Firing Pin
Step 6: Mid-Supports
These are so that the gun doesn't thin out at the bottom.
Step 7: Rubber Bands
Step 8: Done!
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
    parshan
    5 years ago on Introduction
    In a knex war, if you run out of ammo, then simply break off one of the white rods on top and load and FIRE!!
