Knex Supercar Instructions
80,874
70
283
This instruction set shows how to build a Knex Supercar model. I improvised this model myself with all the pieces that I had. I used the free 3D CAD software Google SketchUp to create the 3D renderings.
You can download SketchUp for free at http://sketchup.google.com/download/
***SPECIAL EDITION***
Download the file for the entire model here
Included are not only photos and the SketchUp file for this model, but also for my 3 other Knex supercar models, as well as some random other experiments.
If the host doesn't work, try downloading from here
NOTE: You will need WinRAR to open the file. Download WinRAR here.
Step 1: Steering Module
The following set of instructions show the revolutionary steering system I developed. I discovered the basic principle design back when I was 13 lol. The construction is simpler than it looks. Just follow them through carefully. Good luck and enjoy :).
Step 2: Main Body Module
This is the central part of the model, which will contain the steering wheel and seats, as well as providing the necessary structural support for the front and back wheel modules.
Step 3: Steering Wheel, Dash Board, and Seats
The next step is to build the interior components such as the dashboard, steering wheel, and inclinable seats.
Step 4: Back Wheel Module
This module might be a little tricky to build, so I will do my best to illustrate the construction.
Step 5: Front Cover Module
This is probably the hardest stage to follow, because pieces are going to be bending at all sorts of angles and there are about 14 connection that you have to make to fit it to the main body. However this is the part that strengthens the entire front of the model together as well as gives it that dynamic look. Once you have completed this stage you can pretty much put the tires on and give it a test ride.
Step 6: Back Cover Module
The following stage will add the back cover including the fins. This will complete the chasis and framework. After this, you can put the tires on and give it a drive. However the tires are slightly modified so it is important that you look at the next step.
Step 7: Tires
Okay it is time to make the tires.
    • Woodworking Contest
      Woodworking Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    283 Discussions
    supaboss
    3 years ago
    Anyone Please help
    supaboss
    3 years ago
    I don't have enough 90 degree red connectors for the 2nd part of the back well module will I be able to replace them with green connectors?
    Thanks, looks like a great car!
    jkight
    4 years ago on Step 7
    I think I am going to need a ton more parts. I only have a single 521 value tub.
    pongopeter826
    5 years ago
    What car is this modeled after
    joshbuilder5
    5 years ago on Introduction
    It's a nice car, and I built it a while ago, but it had trouble with the tires. They wouldn't fit. If you could make another one that performs better, that would be awesome. :)
    ...okay, so when i posted that original comment i was kind of being stupid and closed minded. i just wanted to apologize to the author and whomever was upset or confused by this comment. this does truly look just like an Australian V8 Super car and not just a tuner or sports car. my bad every one ;)
    Cool dude. I tried to build your car 4 years ago before I was on this site.
    millju
    6 years ago on Introduction
    https://www.instructables.com/id/knex-bulldozer-instructions/
    millju
    https://www.instructables.com/id/knex-forklift-instructions/
    G.I. BRICK
    7 years ago on Step 5
    Yo, this car's dope man....I'm Lovin' it!!!
    jmtb123
    7 years ago on Introduction
    As whats his face said
    "k'nex is all about speed hot nasty speed"
    This car lives up to that about 2hrs making 2 days moding I might post the tut on my mods :) 5*
    blackboard
    7 years ago on Step 3
    and the car thats foling urs is going to maby have brakes and its defelinyt going to have a lockin and un locking door
    sammymom55
    Does anyone have any directions to make a Knex rubberband racecar?
    pguillemette
    Very wise steering module, much more solid than the one i had made ! I will make my own car though, considering I wouldn't have enough K'nex to complete this supercar.. lol ! (I want to make a convertible, with a retractable top)
