Knex Trammel of Archimedes
2,164
24
12
About: U.B. Electrical Engineering. I enjoy building with Knex and I have been using this site for a few years now. So, subscribe if you like what I do.
Hey guys!
I'm on winter break from college and got bored so I decided to pick back up an old hobby- knex. I built what I think is the first ever knex trammel of Archimedes. It's a truly fascinating machine with practical uses as it converts circular motion into oscillating linear motion. Unfortunately my break is almost over so I can't implement it into anything other than a mesmerizing kinetic sculpture. I made this in a few hours to prove the concept out of knex. It is a lot larger than I originally planned; however, it could be reduced in size rather easily. This mechanism has been made out of Lego by JK Brickworks, which is where I got my inspiration. My hope is that someone will take my proof of concept and make something innovative out of it. If you just want to see it in action, I've embedded a video; however I also made step by step instructions, so without further ado... happy building.
Note: This uses four cut white rods (step six shows modification to avoid the use of cut pieces) and the instructions also show the use of orange brace clips which are entirely optional.
-knextremist
Video URL (in case embedded video is not working for you): Knex Trammel of Archimedes
Supplies:
Step 1: Motor Housing
All additional instructions will be in image notes.
Step 2: The Base
Image notes.
Step 3: The Cap
This piece caps off the base and motor assembly. Image notes.
Step 4: Lower Track
The sled rides over top of this. Image notes.
Step 5: The Sled
This is the magic behind the trammel. The step after this shows instructions for using no cut pieces. Image notes.
Step 6: The Sled (No Cut Pieces)
This is the version with no cut rods, it is slightly less stable; however, it can be reinforced with a small layer of tape. Sorry these photos are so dark. Image notes.
Step 7: Upper Track
This keeps the sled in place. Image notes.
Step 8: Bracing
These are optional because...
Pro: they lock the upper track down
Con: they occasionally cause jams in the sled if the sled gets caught on them
Because the machine works both with and without these braces, it is up to you as to whether or not you want to put them on. Image notes.
Step 9: You're Done
Thanks for viewing. The hope here is that people can take the concept and do something innovative with it.
-knextremist
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    12 Discussions
    That_Jamie_S_Guy
    1 year ago
    I made a small one that almost worked but this ones awesome!
    The Knex Inventorknextremist
    Reply 2 years ago
    You're welcome! Yes, I can definitely see this being used in many other projects.
    random_builder
    2 years ago
    This is crazy! It doesn't seen like it would be possible to make something like this out of knex. Great job!
    random_builderknextremist
    Reply 2 years ago
    What could you make with it? Maybe you could make a ball machine element or lift with it, but I think it is good enough the way it is.
    GWorks
    2 years ago
    Very nice! Works smooth as silk. Impressive :)
    www139
    2 years ago
    This is absolutely amazing! I can see potential from this practically spilling out! Thank you so much for this inspiration!!
