Knife Block
403,533
3,117
156
  • This quite unusual but practical knife block is a relatively fast and simple project for your CNC machine...
  • There is some manual work involved (edge rounding, glueing and sanding) but with the right tools it won't take too much time...
Step 1: Things You'll Need:
Bill of materials:
  • (Beech) plywood:
    • 700 x 290 x 15mm
    • 460 x 340 x 15mm
    • 350 x 340 x 15mm
    • 260 x 340 x 15mm
  • Magnet Ø25 x 5mm (NdFeB)
  • Some 6mm dowels
  • Wood glue
  • Clear varnish or walnut oil
  • 3x Felt pads
  • Your favourite kitchen knifes
Tools:
  • End mill (around 3mm)
  • Corner rounding bit
  • Sandpaper
Machinery:
  • CNC mill
  • Manual router
Software:
  • Estlcam or another CAM Software
  • A 2D CAD Program to customize the knife slots
Step 2: Overview:
  • Each main part consists of two respectively three 15mm boards that will later be glued together. It is much simpler to machine it this way than creating solid, thick parts...
  • Perfect alignment of the boards is ensured by some 6mm dowels...
  • The 3 main parts are held together by glued mortise / tenon joints. This is rock-solid and very simple to do on a CNC machine but you need to be aware of material thickness tolerances. If your material is considerably thicker or thinner than 15mm you should change the drawings accordingly - otherwise you'll face a lot of manual rework to fit the parts...
  • The shields knife slots need to be customized to match your blades - you can do this with most 2D CAD programs...
  • The sharpening steel is just held by a strong magnet inside the soldiers "helmet" - so it unfortunately won't work with ceramic ones...
Step 3: Lets Start:
Play the Video for step by step instructions...
Step 4: Project Files:
The .zip file below contains all required .dxf drawings and also the finished Estlcam project files...
Step 5: Some More Pictures:
9 People Made This Project!
  • Pie Contest
    Pie Contest
  • Trash to Treasure
    Trash to Treasure
  • Weaving Challenge
    Weaving Challenge
156 Discussions
ortegao
3 years ago
Does anyone knows the dimensions (size) of the finished product? I'm wondering how big it is, to see if it fits in my kitchen. I don't have a CNC machine nor the software to open the files. Thanks in advance!
Ghlooortegao
Reply 2 years ago
203mm tall is the figure from the piedestal to the helmet.
Try Inkscape for free to open vector files in real dimensions
Moose1973Ghloo
Reply 3 months ago
I tried that and it did not work
GhlooMoose1973
Reply 3 months ago
Try harder. ;o) Open a single .dxf in Inkscape, in File - Document properties set the document size to the object (i.e. with no gutters) and switch the units from px to mm. If needed, group individual objects. That will get you the exact dimensions (or will allow you to decrease the dimensions proportionally).
Molly35
2 years ago
How about a version if you dont have cnc? Last time i looked i have a 8 inch joiner, 20 in planer, about $2000 worth of phiel carving chisels. More power tools then home depot.
Cnc, great tool if your doing production. Or for someone who likes to set up a program that does the work. Helloooo, a five year old could do that....
Moose1973Molly35
Reply 3 months ago
Did you ever get the version to do without a cnc
Moose1973
Question 3 months ago on Step 4
I downloaded the zip files and was trying to look at them but can not file the program to look at them
MarkD414
Question 1 year ago on Introduction
can I get a picture so I can trace it on to my workpiece?
Bastian-B
1 year ago
Hey, based on your idea I made my own design. A spartan like warrior knife block. Have a look here.
Thanks for sharing you idea!
pjerz
1 year ago
That's a great design!
nathanrudolf
4 years ago on Introduction
Your knife block is great. I have The Ex, it is made of plastic, I've been wanting to make a wooden version. After reading comments there are two things that you can adapt from the Ex to make yours better.
1. from people talking about the knife getting dull from contact: just like the magnet you put on the sharpener, there are magnets in the Ex on top of each knife to hold it up, and the slot is larger so that it doesn't come in contact with the sharp edge of the blade.
2. the concern about the sharp blades sticking out the back as a hazard to children or yourself: as one person suggested, leather sheaths would work, and as you can see the Ex has plastic.
I love your concept and exicution, keep it up!
ac-dcnathanrudolf
Reply 2 years ago
Keep knives (and this rack) out of the reach of children young enough to not know better. Having a sheath on won't be enough, if they can still pull the knife out and play with it!
henrik von davyac-dc
Reply 2 years ago
Does this need to be said? Surely its a given to keep knives somewhere where young children can't reach them.....
RichFarwellnathanrudolf
Reply 2 years ago
I know this is an old post. But, I just love your "The Ex" knife holder. Thanks for sharing that pic.
mlacerda
2 years ago
Do you have, by any chance, the measures of the knives?
I'm Brazil, and I'm quite worried about the lenght and weight of the knives and if this little guy wouldn't lean forward....
maurvz800
2 years ago
Do you have a jpeg,or pdf pattern for these pieces to saw out?
Molly35
2 years ago
Lol, sorry i forgot. Who's the guy saying their could be liabilities because the knifes are exposed? Sounds like a form of PC. Its called common sense, oye!
xxxCHICAGOxxx
2 years ago
I've seen this same instructable a while ago, are the creator of that one or did you steal it?
BennexxxCHICAGOxxx
Reply 2 years ago
This Instructable was made in 2014. I think that's when you saw it first.
